ArcGIS.Core.Geometry Namespace / PolylineBuilderEx Class / CreatePolyline Method / CreatePolyline(Polygon,SpatialReference) Method
The polygon to create the polyline.
(Optional) The SpatialReference. The default value is null. If spatialReference is null, then the spatial reference will be inherited from polygon.
Example
    Convenience method to create a new instance of the Polyline class.
    Syntax
    public static Polyline CreatePolyline(
       Polygon polygon,
       SpatialReference spatialReference
    Public Overloads Shared Function CreatePolyline( _
       ByVal polygon As Polygon, _
       Optional ByVal spatialReference As SpatialReference _
    ) As Polyline
    Parameters
    polygon
    spatialReference
    Return Value
    Exceptions
    ExceptionDescription
    polygon is null.
    Remarks
    HasZ, HasM and HasID attributes are inherited from the input polygon.
    Example
    Construct a Polyline - from a Cubic Bezier
      polyline = PolylineBuilderEx.CreatePolyline(bezierSegment);
    Requirements
