ArcGIS.Desktop.Layouts Namespace / LayoutTool Class
    LayoutTool Class Properties
    For a list of all members of this type, see LayoutTool members.
    Public Properties
     NameDescription
    Public Property Gets the active element container.
    Public Property Gets or sets the command label as it appears in the ribbon and customize dialog. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets or sets the mouse pointer for this tool. (Inherited from ArcGIS.Desktop.Framework.Contracts.Tool)
    Public PropertyGets or sets the supplementary text that appears with the Tooltip only when the command is disabled. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets or sets a boolean to specify whether the control is enabled. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets the DAML identifier. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public PropertyGets or sets whether the ArcGIS.Desktop.Framework.Contracts.Button is checked. (Inherited from ArcGIS.Desktop.Framework.Contracts.Button)
    Public Property Gets or sets the large representation of the command, this may be an image or a xaml element. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets or sets the small representation of the command, this may be an image or a xaml element. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets or sets a brief description of the command that appears in a small pop-up window when a user pauses the mouse pointer over an element, such as over a Button. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets or sets a one or two word label that appears above the tooltip. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Top
    Protected Properties
     NameDescription
    Protected Property Gets or sets the DAML ID of the context menu for the tool.
    Protected Property Gets or sets the DAML ID of the toolbar to display for the tool.
    Protected Property Gets a read only ShortCut collection for the current tool. (Inherited from ArcGIS.Desktop.Framework.Contracts.Tool)
    Protected PropertyGets or sets the number of sides for a regular polygon. Use when SketchType = ArcGIS.Desktop.Mapping.SketchGeometryType.RegularPolygon or SketchType = ArcGIS.Desktop.Mapping.SketchGeometryType.RegularPolyline.
    Protected Property Gets the symbol to use for the sketch.
    Protected Property Gets or sets the type or shape of the geometry to be created by the sketch.
    Protected Property Gets or sets whether to use snapping to precisely sketch on the active view. The default value is false.
    Top
