ArcGIS.Core.CIM Namespace / CIMExpressionMediaInfo Class
Properties Methods Events
    CIMExpressionMediaInfo Class Members
    The following tables list the members exposed by CIMExpressionMediaInfo.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the column. (Inherited from ArcGIS.Core.CIM.CIMMediaInfo)
    Public Property Gets or sets the column span. (Inherited from ArcGIS.Core.CIM.CIMMediaInfo)
    Public Property Gets or sets the Arcade expression used to evaluate and return the media infos.
    Public Property Gets or sets the amount of time in RefreshRateUnit to wait between refreshing the media info. (Inherited from ArcGIS.Core.CIM.CIMMediaInfo)
    Public Property Gets or sets the units for the amount of time to wait between refreshing the media. (Inherited from ArcGIS.Core.CIM.CIMMediaInfo)
    Public Property Gets or sets the row. (Inherited from ArcGIS.Core.CIM.CIMMediaInfo)
    Public Property Gets or sets the row span. (Inherited from ArcGIS.Core.CIM.CIMMediaInfo)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMExpressionMediaInfo.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMExpressionMediaInfo with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMExpressionMediaInfo and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
