ArcGIS.Desktop.Editing Namespace / EditOperation Class / ChangeParcelType Method / ChangeParcelType(ParcelLayer,SelectionSet,Layer,Layer) Method
The parcel fabric layer that has the parcels to be changed.
The source layers and feature OIDs of parcel polygon features.
The parcel layer type to change the selected parcel polygon features into.
Line layer that the editor listens to for database changes. This allows the use of the parcel edit token to return edit operation information on feature changes.
Example
    Change the parcel type of selected parcels.
    Syntax
    Parameters
    parcelLayer
    sourceFeatures
    destinationPolygonLayer
    destinationLineLayer
    Exceptions
    ExceptionDescription
    ParcelLayer, sourceFeatures and destinationPolygonLayer cannot be null.
    Insufficient license. This method requires a standard license.
    Example
    Change parcel type
    //add polygon layers and the feature ids to change the type on to a new Dictionary
    var ids = new List<long>(sourcePolygonL.GetSelection().GetObjectIDs());
    var sourceFeatures = new Dictionary<MapMember, List<long>>
      { sourcePolygonL, ids }
    try
      var editOper = new EditOperation()
        Name = "Change Parcel Type",
        ProgressMessage = "Change Parcel Type...",
        ShowModalMessageAfterFailure = true,
        SelectNewFeatures = true,
        SelectModifiedFeatures = false
      editOper.ChangeParcelType(myParcelFabricLayer, SelectionSet.FromDictionary(sourceFeatures), targetFeatLyr);
      if (!editOper.Execute())
        return editOper.ErrorMessage;
    catch (Exception ex)
      return ex.Message;
    return "";
    Requirements
