ArcGIS.Core.Data Namespace / CoreDataExtensions Class / MarkAsExceptionInEditOperation Method
The ArcGIS.Core.Data.Topology instance to mark the errors as exceptions.
The topology error to be marked as an exception.
    Marks the topology error specified by topologyError as an exception. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Shared Sub MarkAsExceptionInEditOperation( _
       ByVal topology As Topology, _
       ByVal topologyError As TopologyError _
    public static void MarkAsExceptionInEditOperation(
       Topology topology,
       TopologyError topologyError
    Parameters
    topology
    topologyError
    Exceptions
    ExceptionDescription
    topologyError is null.
    Cannot find a layer in the active map that connects to the same geodatabase as that of the Topology.
    A geodatabase-related exception has occurred.
    Remarks
    Requirements
