ArcGIS.Desktop.Layouts Namespace / ElementFactory Class / CreateGraphicElement Method / CreateGraphicElement(IElementContainer,CIMGraphic,String,Boolean,ElementInfo) Method
The parent element container
The input graphic
Element name (optional)
Select after create flag (default is true) (optional)
Additional element properties (optional)
Example
    Create a GraphicElement based on the input ArcGIS.Core.CIM.CIMGraphic and element properties. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function CreateGraphicElement( _
       ByVal elementContainer As IElementContainer, _
       ByVal cimGraphic As CIMGraphic, _
       Optional ByVal elementName As String, _
       Optional ByVal select As Boolean, _
       Optional ByVal elementInfo As ElementInfo _
    ) As GraphicElement
    Parameters
    elementContainer
    cimGraphic
    The input graphic
    elementName
    select
    elementInfo
    Return Value
    Exceptions
    ExceptionDescription
    Value cannot be null: graphic
    Remarks
    Refer to GraphicFactory for creating ArcGIS.Core.CIM.CIMGraphic.If the element container is a Layout then the element gets added to the root level of the layout TOC at the top most position. If the element container is a GroupElement then it gets added to the group at the topmost position.
    Example
    Create Ellipse Graphic Element
      //Note: Must be on QueuedTask.Run
      //Build geometry
      Coordinate2D center = new Coordinate2D(2, 2.75);
      var eabElp = new EllipticArcBuilderEx(center, 0, 1, 0.45,
                                          ArcOrientation.ArcClockwise);
      var ellipse = eabElp.ToSegment();
      //Set symbology, create and add element to layout
      CIMStroke outline = SymbolFactory.Instance.ConstructStroke(
                                      ColorFactory.Instance.GreenRGB, 2.0,
                              SimpleLineStyle.Dot);
      CIMPolygonSymbol ellipseSym = SymbolFactory.Instance.ConstructPolygonSymbol(
                                ColorFactory.Instance.GreyRGB, SimpleFillStyle.Vertical,
                                                        outline);
      var poly = PolygonBuilderEx.CreatePolygon(
        PolylineBuilderEx.CreatePolyline(ellipse, AttributeFlags.AllAttributes));
      var elpElm = ElementFactory.Instance.CreateGraphicElement(
        layout, poly, ellipseSym, "New Ellipse");
    Create Lasso Line, Freehand Graphic Element
      //Build geometry
      List<Coordinate2D> plCoords = new List<Coordinate2D>();
      plCoords.Add(new Coordinate2D(1.5, 10.5));
      plCoords.Add(new Coordinate2D(1.25, 9.5));
      plCoords.Add(new Coordinate2D(1, 10.5));
      plCoords.Add(new Coordinate2D(0.75, 9.5));
      plCoords.Add(new Coordinate2D(0.5, 10.5));
      plCoords.Add(new Coordinate2D(0.5, 1));
      plCoords.Add(new Coordinate2D(0.75, 2));
      plCoords.Add(new Coordinate2D(1, 1));
      Polyline linePl = PolylineBuilderEx.CreatePolyline(plCoords);
      CIMLineSymbol lineSym = SymbolFactory.Instance.ConstructLineSymbol(
                ColorFactory.Instance.BlackRGB, 2.0, SimpleLineStyle.Solid);
      //var graphic = GraphicFactory.Instance.CreateShapeGraphic(linePl, lineSym);
      var ge = ElementFactory.Instance.CreateGraphicElement(
                              layout, linePl, lineSym, "New Freehand");
    Create Lasso Polygon, Freehand Element
      List<Coordinate2D> plyCoords = new List<Coordinate2D>();
      plyCoords.Add(new Coordinate2D(1, 1));
      plyCoords.Add(new Coordinate2D(1.25, 2));
      plyCoords.Add(new Coordinate2D(1.5, 1.1));
      plyCoords.Add(new Coordinate2D(1.75, 2));
      plyCoords.Add(new Coordinate2D(2, 1.1));
      plyCoords.Add(new Coordinate2D(2.25, 2));
      plyCoords.Add(new Coordinate2D(2.5, 1.1));
      plyCoords.Add(new Coordinate2D(2.75, 2));
      plyCoords.Add(new Coordinate2D(3, 1));
      Polygon poly = PolygonBuilderEx.CreatePolygon(plyCoords);
      CIMPolygonSymbol polySym = SymbolFactory.Instance.ConstructPolygonSymbol(
               ColorFactory.Instance.RedRGB, SimpleFillStyle.ForwardDiagonal, outline);
        layout, poly, polySym, "New Lasso");
    Create Line Element
      //Build geometry
      plCoords.Add(new Coordinate2D(1, 8.5));
      plCoords.Add(new Coordinate2D(1.66, 9));
      plCoords.Add(new Coordinate2D(2.33, 8.1));
      plCoords.Add(new Coordinate2D(3, 8.5));
      //Reference a line symbol in a style
      var ProjectStyles = Project.Current.GetItems<StyleProjectItem>();
      StyleProjectItem style = ProjectStyles.First(x => x.Name == "ArcGIS 2D");
      var symStyle = style.SearchSymbols(StyleItemType.LineSymbol, "Line with 2 Markers")[0];
      CIMLineSymbol lineSym = symStyle.Symbol as CIMLineSymbol;
      lineSym.SetSize(20);
      //CIMLineSymbol lineSym = SymbolFactory.Instance.ConstructLineSymbol(ColorFactory.Instance.BlueRGB, 4.0, SimpleLineStyle.Solid);
        layout, linePl, lineSym, "New Line");
    Create Point Element
      //Note: Must be on QueuedTask.Run(() => { ...
      //Build geometry
      Coordinate2D coord2D = new Coordinate2D(2.0, 10.0);
      //Reference a point symbol in a style
      StyleProjectItem stylePrjItm = Project.Current.GetItems<StyleProjectItem>()
                .FirstOrDefault(item => item.Name == "ArcGIS 2D");
      SymbolStyleItem symStyleItm = stylePrjItm.SearchSymbols(
                            StyleItemType.PointSymbol, "City Hall")[0];
      CIMPointSymbol pointSym = symStyleItm.Symbol as CIMPointSymbol;
      pointSym.SetSize(50);
      var elemInfo = new ElementInfo()
        CustomProperties = new List<CIMStringMap>() {
        new CIMStringMap() { Key = "Key1", Value = "Value1"},
        new CIMStringMap() { Key = "Key2", Value = "Value2"}
        Anchor = Anchor.TopRightCorner,
        Rotation = 45.0
      var graphic = GraphicFactory.Instance.CreateSimpleGraphic(
                                    coord2D.ToMapPoint(), pointSym);
        layout, graphic, "New Point", true, elemInfo);
    Create Polygon Element
      //Build geometry
      plyCoords.Add(new Coordinate2D(1, 7));
      plyCoords.Add(new Coordinate2D(2, 7));
      plyCoords.Add(new Coordinate2D(2, 6.7));
      plyCoords.Add(new Coordinate2D(3, 6.7));
      plyCoords.Add(new Coordinate2D(3, 6.1));
      plyCoords.Add(new Coordinate2D(1, 6.1));
        ColorFactory.Instance.BlueRGB, 2.0, SimpleLineStyle.DashDotDot);
        layout, poly, polySym, "New Polygon", false);
    Create Rectangle Element
      //Build geometry
      Coordinate2D ll = new Coordinate2D(1.0, 4.75);
      Coordinate2D ur = new Coordinate2D(3.0, 5.75);
      Envelope env = EnvelopeBuilderEx.CreateEnvelope(ll, ur);
        ColorFactory.Instance.BlackRGB, 5.0, SimpleLineStyle.Solid);
        ColorFactory.Instance.GreenRGB, SimpleFillStyle.DiagonalCross, outline);
      var ge = GraphicFactory.Instance.CreateSimpleGraphic(env, polySym);
        Anchor = Anchor.CenterPoint,
        Rotation = 45.0,
        CornerRounding = 5.0
        layout, env, polySym, "New Rectangle", false, elemInfo);
    Create Bezier Curve Element
      //Build geometry
      Coordinate2D pt1 = new Coordinate2D(1, 7.5);
      Coordinate2D pt2 = new Coordinate2D(1.66, 8);
      Coordinate2D pt3 = new Coordinate2D(2.33, 7.1);
      Coordinate2D pt4 = new Coordinate2D(3, 7.5);
      var bez = new CubicBezierBuilderEx(pt1, pt2, pt3, pt4);
      var bezSeg = bez.ToSegment();
      Polyline bezPl = PolylineBuilderEx.CreatePolyline(bezSeg, AttributeFlags.AllAttributes);
        ColorFactory.Instance.RedRGB, 4.0, SimpleLineStyle.DashDot);
      ElementFactory.Instance.CreateGraphicElement(layout, bezPl, lineSym, "New Bezier");
    Create Graphic Element using CIMGraphic
      //Note: on the QueuedTask
      //Place symbol on the layout
      MapPoint location = MapPointBuilderEx.CreateMapPoint(new Coordinate2D(9, 1));
      //specify a symbol
      var pt_symbol = SymbolFactory.Instance.ConstructPointSymbol(
                            ColorFactory.Instance.GreenRGB);
      //create a CIMGraphic
      var graphic = new CIMPointGraphic()
        Symbol = pt_symbol.MakeSymbolReference(),
        Location = location //center of map
      //Or use GraphicFactory
      var graphicFactory = GraphicFactory.Instance.CreateSimpleGraphic(location, pt_symbol);
      ElementFactory.Instance.CreateGraphicElement(layout, graphic);
      ElementFactory.Instance.CreateGraphicElement(layout, graphicFactory);
    Create Graphic Element using CIMSymbol
      //specify a symbol
      ElementFactory.Instance.CreateGraphicElement(layout, location, pt_symbol);
    Create point graphic with symbology
      //Create a simple 2D point graphic and apply an existing point style item as the symbology.
      //Build 2D point geometry
      //(optionally) Reference a point symbol in a style
      StyleProjectItem ptStylePrjItm = Project.Current.GetItems<StyleProjectItem>()
      SymbolStyleItem ptSymStyleItm = ptStylePrjItm.SearchSymbols(
      CIMPointSymbol pointSym = ptSymStyleItm.Symbol as CIMPointSymbol;
      //An alternative simple symbol is also commented out below.
      //This would eliminate the four optional lines of code above that
      //reference a style.
      //CIMPointSymbol pointSym = SymbolFactory.Instance.ConstructPointSymbol(
      //                  ColorFactory.Instance.RedRGB, 25.0, SimpleMarkerStyle.Star);
      GraphicElement ptElm = ElementFactory.Instance.CreateGraphicElement(
                                     layout, coord2D.ToMapPoint(), pointSym);
      ptElm.SetName("New Point");
    Create line graphic with symbology
      //Create a simple 2D line graphic and apply an existing line
      //style item as the symbology.
      //Build 2d line geometry
      //(optionally) Reference a line symbol in a style
      StyleProjectItem lnStylePrjItm = Project.Current.GetItems<StyleProjectItem>()
      SymbolStyleItem lnSymStyleItm = lnStylePrjItm.SearchSymbols(
      CIMLineSymbol lineSym = lnSymStyleItm.Symbol as CIMLineSymbol;
      //         ColorFactory.Instance.BlueRGB, 4.0, SimpleLineStyle.Solid);
      GraphicElement lineElm = ElementFactory.Instance.CreateGraphicElement(
                                                  layout, linePl, lineSym);
      lineElm.SetName("New Line");
    Create rectangle graphic with simple symbology
      //Create a simple 2D rectangle graphic and apply simple fill and
      //outline symbols.
      //Build 2D envelope geometry
      Coordinate2D rec_ll = new Coordinate2D(1.0, 4.75);
      Coordinate2D rec_ur = new Coordinate2D(3.0, 5.75);
      Envelope rec_env = EnvelopeBuilderEx.CreateEnvelope(rec_ll, rec_ur);
      GraphicElement recElm = ElementFactory.Instance.CreateGraphicElement(
        layout, rec_env, polySym, "New Rectangle");
      //Or use Predefined shape
      GraphicElement recElm2 = ElementFactory.Instance.CreatePredefinedShapeGraphicElement(
                                layout, PredefinedShape.Rectangle, rec_env, polySym,
                                "New Rectangle2");
    Create Picture Graphic Element using CIMSymbol
      //Build geometry
      Coordinate2D ll = new Coordinate2D(0.5, 1);
      Coordinate2D ur = new Coordinate2D(2.5, 2);
      //Create and add element to layout
      string picPath = System.IO.Path.Combine(Environment.GetFolderPath(Environment.SpecialFolder.MyPictures),
        "SamplePicture.jpg");
      var pic_gr = ElementFactory.Instance.CreatePictureGraphicElement(
        layout, env.Center, picPath, "New Picture", true, new ElementInfo() { Anchor = Anchor.CenterPoint });
    Translates a point in map coordinates to a point in page coordinates
      var pointSymbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.BlackRGB, 8);
      //Convert the clicked point in client coordinates to the corresponding map coordinates.
      //clicked point can be from a Map Tool's HandleMouseDownAsync callback.
      //MapViewMouseButtonEventArgs ClientPoint property.
      Point clickedPoint;
      var clickedMapPoint = MapView.Active.ClientToMap(clickedPoint);
      ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(string.Format("X: {0} Y: {1} Z: {2}",
          mapPoint.X, mapPoint.Y, mapPoint.Z), "Map Coordinates");
      //Get the corresponding layout point
      var pointOnLayoutFrame = mapFrame.MapToPage(mapPoint);
      //Create a point graphic on the Layout.
      var cimGraphicElement = new CIMPointGraphic
        Location = pointOnLayoutFrame,
        Symbol = pointSymbol.MakeSymbolReference()
      var cimGraphicElement2 = GraphicFactory.Instance.CreateSimpleGraphic(
              pointOnLayoutFrame, pointSymbol);
      ElementFactory.Instance.CreateGraphicElement(layout, cimGraphicElement);
      ElementFactory.Instance.CreateGraphicElement(layout, cimGraphicElement2);
    Requirements
