ArcGIS.Desktop.Mapping Namespace / GraphicsLayerExtensions Class / AddElement Method / AddElement(GraphicsLayer,CIMGraphic,String,Boolean,ElementInfo) Method
The graphic to be added. Cannot be null
An element name (optional)
True to set the element selected after the add (default is true) (optional)
Additional element properties or null (optional)
Example
    Add a ArcGIS.Desktop.Layouts.GraphicElement based on the ArcGIS.Core.CIM.CIMGraphic. This method must be called on the MCT.Use QueuedTask.Run.
    Syntax
    Public Overloads Shared Function AddElement( _
       ByVal graphicsLayer As GraphicsLayer, _
       ByVal cimGraphic As CIMGraphic, _
       Optional ByVal elementName As String, _
       Optional ByVal select As Boolean, _
       Optional ByVal elementInfo As ElementInfo _
    ) As GraphicElement
    Parameters
    graphicsLayer
    cimGraphic
    elementName
    select
    elementInfo
    Return Value
    Exceptions
    ExceptionDescription
    Value cannot be null: cimGraphic
    Map has reached maximum graphics count limit of 4000 elements. One or more elements cannot be created.
    Map has reached maximum graphics size limit of 10 MB. One or more elements cannot be created.
    Remarks
    A ArcGIS.Desktop.Layouts.GraphicElement is created that contains the cimGraphic. The geometry of the graphic cannot be empty or null. If the symbology is not set then a default symbology is applied.
    o ArcGIS.Core.CIM.CIMInkGraphic is not supported
    o ArcGIS.Core.CIM.CIMMultiPatchGraphic is not supported
    The map view displaying the graphics layer should be initialized.
    Example
    Translates a point in page coordinates to a point in map coordinates.
      var pointSymbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.BlackRGB, 8);
      var activeMapView = MapView.Active;
      await QueuedTask.Run(() =>
        var graphicsLayer = activeMapView.Map.GetLayersAsFlattenedList().OfType<GraphicsLayer>().FirstOrDefault();
        //Get a point in the center of the Map frame
        var mapFrameCenterPoint = mapFrame.GetBounds().CenterCoordinate;
        //Convert to MapPoint
        var pointInMapFrame = MapPointBuilderEx.CreateMapPoint(mapFrameCenterPoint);
        //Find the corresponding point in the MapView
        var pointOnMap = mapFrame.PageToMap(pointInMapFrame);
        //Create a point graphic on the MapView.
        var cimGraphicElement = new CIMPointGraphic
          Location = pointOnMap,
          Symbol = pointSymbol.MakeSymbolReference()
        graphicsLayer.AddElement(cimGraphicElement);
    Get the map clipping geometry
      var mapWithClip = MapView.Active.Map;
        //If clipping is set to ArcGIS.Core.CIM.ClippingMode.None or ArcGIS.Core.CIM.ClippingMode.MapSeries null is returned
        //If clipping is set to ArcGIS.Core.CIM.ClippingMode.MapExtent the ArcGIS.Core.CIM.CIMMap.CustomFullExtent is returned.
        //Otherwise, if clipping is set to ArcGIS.Core.CIM.ClippingMode.CustomShape the custom clip polygon is returned.
        var poly = mapWithClip.GetClipGeometry();
        //You can use the polygon returned
        //For example: We make a polygon graphic element and add it to a Graphics Layer.
        var gl = mapWithClip.GetLayersAsFlattenedList().OfType<GraphicsLayer>().FirstOrDefault();
        if (gl == null)
          return;
        var polygonSymbol = SymbolFactory.Instance.ConstructPolygonSymbol(CIMColor.CreateRGBColor(255, 255, 0));
        var cimGraphicElement = new CIMPolygonGraphic
          Polygon = poly,
          Symbol = polygonSymbol.MakeSymbolReference()
        gl.AddElement(cimGraphicElement);
    Point Graphic Element using CIMGraphic
        //Place symbol in the center of the map
        var extent = mapView.Extent;
        var location = extent.Center;
        //specify a symbol
        var pt_symbol = SymbolFactory.Instance.ConstructPointSymbol(
                              ColorFactory.Instance.GreenRGB);
        //create a CIMGraphic
        var graphic = new CIMPointGraphic()
          Symbol = pt_symbol.MakeSymbolReference(),
          Location = location //center of map
        graphicsLayer.AddElement(graphic);
    Line Graphic Element using CIMGraphic
        //Place a line symbol using the extent's lower left and upper right corner.
        //get the lower left corner of the extent
        var pointFromCoordinates = new Coordinate2D(extent.XMin, extent.YMin);
        //get the upper right corner of the extent
        var pointToCoordinates = new Coordinate2D(extent.XMax, extent.YMax);
        List<Coordinate2D> points = new List<Coordinate2D> { pointFromCoordinates, pointToCoordinates };
        //create the polyline
        var lineSegment = PolylineBuilderEx.CreatePolyline(points);
        //specify a symbol
        var line_symbol = SymbolFactory.Instance.ConstructLineSymbol(
        var graphic = new CIMLineGraphic()
          Symbol = line_symbol.MakeSymbolReference(),
          Line = lineSegment,
    Polygon Graphic Element using CIMGraphic
        //Place a polygon symbol using the mapview extent geometry
        //Contract the extent
        var polygonEnv = extent.Expand(-100000, -90000, false);
        //create a polygon using the envelope
        var polygon = PolygonBuilderEx.CreatePolygon(polygonEnv);
        //specify a symbol
        var poly_symbol = SymbolFactory.Instance.ConstructPolygonSymbol(
        var graphic = new CIMPolygonGraphic()
          Symbol = poly_symbol.MakeSymbolReference(),
          Polygon = polygon,
    Multi-point Graphic Element using CIMGraphic
        //Place a multipoint graphic using the mapview extent geometry
        //Create MultipPoints from the polygon
        var multiPoints = MultipointBuilderEx.CreateMultipoint(polygon);
        //specify a symbol
        var point_symbol = SymbolFactory.Instance.ConstructPointSymbol(
        var graphic = new CIMMultipointGraphic
          Symbol = point_symbol.MakeSymbolReference(),
          Multipoint = multiPoints
    Add the Most Recent Location To A Graphics Layer
        // get the last location
        var pt = DeviceLocationService.Instance.GetCurrentSnapshot()?.GetPositionAsMapPoint();
        if (pt != null)
          //Create a point symbol
          var ptSymbol = SymbolFactory.Instance.ConstructPointSymbol(
                            CIMColor.CreateRGBColor(125, 125, 0), 10, SimpleMarkerStyle.Triangle);
          //Add a graphic to the graphics layer
          graphicsLayer.AddElement(pt, ptSymbol);
          //unselect it
          graphicsLayer.ClearSelection();
    Graphic Element using CIMSymbol
        //specify a symbol
        graphicsLayer.AddElement(location, pt_symbol);
    Text Graphic Element
        //specify a text symbol
        var text_symbol = SymbolFactory.Instance.ConstructTextSymbol
        (ColorFactory.Instance.BlackRGB, 8.5, "Corbel", "Regular");
        graphicsLayer.AddElement(location, text_symbol, "Text Example");
    Requirements
