ArcGIS.Core.CIM Namespace / CIMChartDimensionalProfileBand Class
Properties Methods Events
    CIMChartDimensionalProfileBand Class Members
    The following tables list the members exposed by CIMChartDimensionalProfileBand.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the band ID.
    Public Property Gets or sets the dimension to be plotted on the y axis.
    Public Property Gets or sets the dimension values corresponding to the dimension to be plotted on the y axis.
    Public Property Gets or sets the labels for dimension values.
    Public Property Gets or sets the symbols for dimension values.
    Public Property Gets or sets the label.
    Public Property Gets or sets the index of the location this definition corresponds to.
    Public Property Gets or sets the symbol.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMChartDimensionalProfileBand.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMChartDimensionalProfileBand with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMChartDimensionalProfileBand and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
