Feature Class To Feature Class (Conversion Tools)
Summary
Converts a feature class or feature layer to a feature class.
Legacy:
This is a deprecated tool. This functionality has been replaced by the Export Features tool.
Usage
Use the Field Map parameter to manage the fields and their content in the output dataset.
Add and remove fields from the fields list, reorder the fields list, and rename fields.
The default data type of an output field is the same as the data type of the first input field (of that name) it encounters. You can change the data type to another valid data type.
Use an action to determine how the values from one or multiple input fields will be merged into a single output field. The available actions are First, Last, Concatenate, Sum, Mean, Median, Mode, Minimum, Maximum, Standard Deviation, and Count.
When using the Concatenate action, you can specify a delimiter such as a comma or other characters. Click the start of the Delimiter text box to add the delimiter characters.
Standard Deviation is not a valid option for single input values.
Use the Export option
to save a field map as a .fieldmapfile.Use the Load option
to load a .fieldmapfile. The feature layer or dataset specified in the file must match the dataset used in the tool. Otherwise, the Field Map parameter will be reset.Use the Slice Text button
on text source fields to choose which characters from an input value will be extracted to the output field. To access the Slice Text button, hover over a text field in the input fields list; then specify the start and end character positions.Fields can also be mapped in Python script.
An SQL expression can be used to select a subset of features. For details about the syntax for the Expression parameter, see SQL reference for query expressions used in ArcGIS.
When converting geodatabase data that has subtypes or domains to a shapefile, both the subtype and domain codes and descriptions can be included in the output. Use the Transfer field domain descriptions geoprocessing environment to do this. By default, only domain and subtype codes will be included in the output, not descriptions.
Converting to shapefiles with subtype and domain descriptions may take more time (slower performance) than without descriptions. If subtype and domain descriptions are not required in the output, leave the Transfer field domain descriptions environment unchecked (
FalseorNOT_TRANSFER_DOMAINSin Python) for best performance.
Parameters
| Label | Explanation | Data type |
Input Features |
The feature class or feature layer that will be converted. |
Feature Layer |
Output Location |
The location where the output feature class will be created. This can be either a geodatabase or a folder. If the output location is a folder, the output will be a shapefile. |
Workspace; Feature Dataset |
Output Name |
The name of the output feature class. |
String |
Expression (Optional) |
An SQL expression used to select a subset of features. |
SQL Expression |
Field Map (Optional) |
The fields that will be transferred to the output dataset with their respective properties and source fields. The output includes all fields from the input dataset by default. Use the field map to add, delete, rename, and reorder fields, as well as change other field properties. The field map can also be used to combine values from two or more input fields into a single output field. |
Field Mappings |
Configuration Keyword (Optional) |
Specifies the default storage parameters (configurations) for geodatabases in a relational database management system (RDBMS). This setting is applicable only when using enterprise geodatabase tables. Configuration keywords are set by the database administrator. |
String |
Derived output
Output Feature Class |
The output feature class. |
Feature Class |
Environments
Current Workspace, Output Coordinate System, Extent, Geographic Transformations, XY Resolution, XY Tolerance, Output has M values, M Resolution, M Tolerance, Output has Z values, Default Output Z Value, Z Resolution, Z Tolerance, Maintain fully qualified field names, Output CONFIG Keyword, Maintain Attachments, Auto Commit, Output XY Domain, Output M Domain, Output Z Domain, Transfer Field Domain Descriptions, Preserve Global IDs
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
