Summarize Percent Change (Crime Analysis and Safety Tools)
Summary
Calculates the percent change for features that correspond with point features representing two equal comparison time periods.
Usage
  • The Input Current Period Point Features and Input Previous Period Point Features parameter values can be created by performing date and time selections on a larger dataset and saving the selections to new layers.
  • The following fields will be added to the output:
    • CUR_CNT—The number of points from the Input Current Period Point Features parameter values that are coincident with the Input Features parameter values.
    • PREV_CNT—The number of points from the Input Previous Period Point Features parameter values that are coincident with the Input Features parameter values.
    • DIFF_CNT—The difference between the CUR_CNT and PREV_CNT fields.
    • PERC—The percentage of change between the CUR_CNT and PREV_CNT fields. This is calculated using the formula
      \(((C \space - \space P) \space / \space P) \space * \space 100\)
      where C is the current count and P is the previous count. If the previous count is 0, the percent change value is null. When the percent change value is null, these features are designated as no percentage in output symbology classification.
Parameters
Label Explanation Data type
Input Features
The coincident features from which comparison time periods will be counted and compared.
Feature Layer
The point features filtered to the most recent comparison time period.
For example, you can filter for crimes from the previous 14 days.
Feature Layer
The point features filtered to the time period immediately preceding the current period. This time period must be of equal length to the current period to provide an accurate comparison.
For example, if the current period contains features from January 15 to January 28, the previous period contains features from January 1 to January 14.
Feature Layer
Output Feature Class
The output feature class containing difference counts and percent change calculations for the time period comparison.
Feature Class
Search Radius
(Optional)
The maximum distance from the Input Features parameter value that a point feature will be considered coincident.
This parameter is only active when point or line features are used as the input features.
Linear Unit
Environments
Current Workspace, Scratch Workspace, Output Coordinate System, Geographic Transformations, Extent, XY Resolution, XY Tolerance, Output has M values, M Resolution, M Tolerance, Output has Z values, Default Output Z Value, Z Resolution, Z Tolerance, Maintain fully qualified field names, Output CONFIG Keyword, Maintain Attachments, Auto Commit, Output XY Domain, Output M Domain, Output Z Domain
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
