Geocode Locations From Table (Geocoding Tools)
Summary
Geocodes hosted tables using locators hosted on an ArcGIS Enterprise portal, which creates a hosted feature layer containing the geocoded results.
This tool automates the process of geocoding tables published to the portal and saves the output to the portal. If you do not need to save the geocode results to the portal, use the Geocode Table pane or the Geocode Addresses tool.
You must have publisher or administrator privileges on the portal to run this tool. If you are a member of a custom role, ensure that the portal administrator has granted you the Publish hosted web layers privilege.
Usage
  • You can geocode addresses that are stored in a single field, divided into multiple fields, or stored in a single field and a country field. A single input field stores the complete address, for example, 303 Peachtree St NE, Atlanta, GA 30308. Multiple fields are supported if the input addresses are divided into multiple fields such as Address, City, State, and ZIP for a general United States address. A single input field that stores the complete address, for example, 303 Peachtree St NE, Atlanta, GA 30308, and a field that stores the country associated with the address, for example, USA, is also supported.
  • Some locators support multiple input address fields, such as Address, Address2, and Address3. In this case, the address component can be separated into multiple fields, and the address fields will be concatenated at the time of geocoding. For example, 100, Main st, and Apt 140 across three fields or 100 Main st and Apt 140 across two fields, both become 100 Main st Apt 140 when geocoding.
  • ArcGIS Enterprise 10.6 or later is required to use the tool.
  • Use a locator on the ArcGIS Enterprise portal that has been configured to use multiple threads to improve geocoding performance.
  • The input table must be a table that is hosted or has been published on an ArcGIS Enterprise portal. Hosted tables are considered part of hosted feature layers and must be created as an item in the portal before they can be used in the tool. For details, see Publish hosted feature layers.
  • The output hosted feature layer is saved in the same spatial reference as the address locator. You can change the spatial reference of the output feature layer by setting a different output coordinate system in the tool's environment settings.
  • The output hosted feature layer will contain all relevant geocoding information, such as score, status, and the matched address of each record, as well as the values from the original input table. The addresses can be rematched using the Rematch Addresses tool or the Rematch Addresses option that opens the Rematch Addresses pane. The geocoding results from this tool contain a static snapshot of the original input table, so adding or updating values in the original table will not update the results in the output feature service. Rerun the tool to create an output feature service that contains these changes.
    Learn more about rematching geocoding results
  • When using an input locator built with z-aware data, the tool will return output that is not z-aware. Only 2D output is supported in this tool.
  • The following parameters are not supported for all locators used for the Address Locator parameter value: Country or Region, Preferred Location Type, and Category.
  • The tool does not apply configurations from a locator view created in ArcGIS Pro 3.2 when using it as the Address Locator parameter value.
Parameters
Label Explanation Data type
Input Table
The table on the portal that contains the addresses or places that will be geocoded.
Record Set
Address Locator
The portal locator that will be used to geocode the input table from the portal.
You can choose a locator from the populated list of locators on the active portal or browse the active portal for other available locators. Locators that have been set as utility services on the active portal will be available by default. If the portal locator you want to use is not in the populated list, ask your portal administrator to add the locator as a portal utility service, and configure the locator for batch geocoding.
The ArcGIS World Geocoding Service is disabled for this tool. Use the Geocode Addresses tool if you want to use the ArcGIS World Geocoding Service.
Address Locator
Address Field Mapping
The address fields used by the locator are mapped to fields in the input table of addresses. Specify Single Field if the complete address is stored in one field in the input table, for example, 303 Peachtree St NE, Atlanta, GA 30308. Specify Multiple Fields if the input addresses are divided into multiple fields such as Address, City, State, and ZIP for a general United States address. Specify Single Field and Country Field if the complete address, for example, 303 Peachtree St NE, Atlanta, GA 30308, and the country, for example, USA, are divided into separate fields such as Address and Country.
Some locators support multiple input address fields, such as Address, Address2, and Address3. In this case, the address component can be separated into multiple fields, and the address fields will be concatenated at the time of geocoding. For example, 100, Main St, and Apt 140 across three fields or 100 Main St and Apt 140 across two fields, both become 100 Main St Apt 140 when geocoding.
If you do not map an optional input address field used by the locator to a field in the input table of addresses, specify that there is no mapping using <None> in place of a field name.
Field Info
Output Feature Layer Name
The name of the output geocoded feature layer that will be created on the portal.
String
Country or Region
(Optional)
The country or countries that the search will be limited to for the geocoded addresses. Specifying a country will improve the accuracy of geocoding in most cases. When no country is specified, geocoding is performed using all supported countries of the locator.
This parameter value will be overridden when you specify Single Field and Country Field for the Address Field Mapping parameter.
String
(Optional)
Specifies the preferred output geometry that will be returned for PointAddress matches. If the preferred location does not exist in the data, the default location of Address location will be returned. See the ArcGIS REST API web help for details about the locationType parameter for geocodeAddresses.
  • Address location—Geometry for geocode results that represent an address location such as a rooftop location, parcel centroid, or front door will be returned. This is the default.
  • Routing location—Geometry for geocode results that represent a location close to the side of the street that can be used for vehicle routing will be returned.
String
Category
(Optional)
Limits the types of places the locator searches, which eliminates false positive matches, unwanted address level matches, or disambiguates coordinate searches. This parameter can help speed up the search process. When no category is used, geocoding is performed using all supported categories. Not all category values are supported for all locations and countries.
See the ArcGIS REST API web help for details about category filtering.
String
Output Fields
(Optional)
Specifies the locator output fields that will be returned in the geocode results.
The original field names from the Input Table parameter value will be maintained if the Location Only, Minimal, or Minimal and User Fields option is specified.
This parameter can be used with input locators created with the Create Locator or Create Feature Locator tool published to Enterprise 10.9 or later. Composite locators that contain at least one locator created with the Create Address Locator tool do not support this parameter.
  • All—Includes all available locator output fields in the geocode results. This is the default.
  • Location Only—Stores the Shape field in the geocode results.
  • Minimal—Adds the following fields that describe the location and how well it matches information in the locator in the geocode results: Shape, Status, Score, Match_type, Match_addr, and Addr_type.
  • Minimal and User Fields—The MINIMAL fields, as well as any user-defined custom output fields, will be added and returned in the geocode results.
String
Derived output
Output Layer
A hyperlink to the output geocoded results feature layer in the portal. The name of the feature layer is derived from the Output Feature Layer Name value.
Feature Set
Environments
Output Coordinate System
Licensing information
  • Basic: Requires your account in ArcGIS Enterprise to have the Perform Analysis privilege
  • Standard: Requires your account in ArcGIS Enterprise to have the Perform Analysis privilege
  • Advanced: Requires your account in ArcGIS Enterprise to have the Perform Analysis privilege
