Generate Multitemporal Coherence (Image Analyst Tools)
Summary
Generates a false color composite image using ground range detected and the coherence products. Each band in the composite is composed of different synthetic aperture radar (SAR) acquisitions, which are derived from complex radar products.
Usage
  • In SAR applications, multitemporal coherence is necessary for ensuring accurate change detection, classification, and deformation monitoring by assessing the temporal change of backscatter signals across multiple SAR acquisitions.
  • The input must be terrain corrected SAR data. Use the Apply Geometric Terrain Correction tool to orthorectify input radar data.
  • For more information about how to set up the bands, see Two image MTC composite and Four image MTC composite.
Parameters
Label Explanation Data type
Input Radar Data for Red Band
The input ground range detected or coherence radar data for the red band.
Raster Dataset; Raster Layer
Input Radar Data for Green Band
The input ground range detected or coherence radar data for the green band.
Input Radar Data for Blue Band
The input ground range detected or coherence radar data for the blue band.
Output Radar Data
The output multitemporal coherence dataset.
Raster Dataset
Polarization Bands
(Optional)
The polarization band that will be interfered.
The first band is the default.
String
Environments
Cell Alignment, Cell Size, Compression, Current Workspace, Extent, Geographic Transformations, GPU ID, NoData, Output Coordinate System, Parallel Processing Factor, Processor Type, Pyramid, Raster Statistics, Resampling Method, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Requires Image Analyst
  • Standard: Requires Image Analyst
  • Advanced: Requires Image Analyst
