Describe Space Time Cube (Space Time Pattern Mining Tools)
Summary
Summarizes the contents and characteristics of a space-time cube. The tool describes the temporal and spatial extent of the space-time cube, the variables in the space-time cube, the analyses performed on each variable, and the 2D and 3D display themes available for each variable.
Illustration
Usage
This tool accepts netCDF files created by various tools in the Space Time Pattern Mining toolbox.
The tool has the following potential applications:
Determine the time and geometry of a space-time cube. This may help with selecting appropriate parameters for the tools in the Space Time Pattern Analysis toolset and the Time Series Forecasting toolset.
View the analysis history performed on the space-time cube. This reveals which display theme options are available in the Visualize Space Time Cube in 2D and Visualize Space Time Cube in 3D tools. The display theme options for a space-time cube layer are not listed.
Learn more about the display themes for a space-time cube layer
The geoprocessing messages describe the characteristics and contents of the input space-time cube. To access the messages, hover over the progress bar, click the pop-out button, or expand the messages section in the Geoprocessing pane. The messages include the following information:
The date and time that the space-time cube was created.
The version of ArcGIS Pro used to create the space-time cube.
The type of space-time cube. The possible types include Defined Location Cube, Grid Cube, Defined Location Cube (from a multidimensional raster), Forecast Cube, and Subset Cube. To learn more about the different types of space-time cubes, see How Create Space Time Cube works.
If the space-time cube was created using the Create Space Time Cube From Multidimensional Raster Layer tool in ArcGIS Pro 2.8 or earlier, the displayed type will be Defined Locations Cube rather than Defined Locations Cube (from a multidimensional raster).
The Space Time Cube Characteristics section that describes the space and time properties of the space-time cube. For details on these characteristics, see How Create Space Time Cube works.
The Space Time Cube Contents section in which each row corresponds to a variable in the input space-time cube. Each row includes the summary statistics of the variable, the tool that created the variable (along with the aggregation and fill type), and the display theme options that are available to visualize in a space-time cube layer and tools in the Space Time Cube Visualization toolset.
If the space-time cube was created using the Create Space Time Cube By Aggregating Points tool, the messages will include one or more subsections under the Space Time Cube Location and Bins section. The Count subsection and each optional Summary Field subsection includes the number of bins and locations that contained at least one point. The sparseness (percentage of bins containing a zero count) is also listed in the table in the Count subsection.
If the space-time cube was created using a tool from the Time Series Forecasting toolset, the messages will include the Forecast Details section that summarizes the forecast methods that were applied.
The messages will include one or more sections under Space Time Cube Trends. The sections include the overall Mann-Kendall trend statistic for each variable in the space-time cube.
If a value is specified for the Output Characteristics Table parameter, the tool will create a table that includes the space and time characteristics of the input space-time cube. The values in the characteristics table are also displayed in the geoprocessing messages. These values can be used in ModelBuilder to create a space-time analysis workflow.
If a value is specified for the Output Spatial Extent Features parameter, the tool will output a polygon feature class with a single rectangle that represents the extent of the input space-time cube. If the input space-time cube was created using the Create Space Time Cube From Defined Locations tool using a single point, a point feature class will be created instead of a polygon feature class. If the space-time cube was created from a template cube, the extent will reflect the extent of the template cube.
The Output Spatial Extent Features parameter value may not reflect the extent of the space-time cube locations if a template cube or the Extent environment was used when the space-time cube was created.
Parameters
| Label | Explanation | Data type |
Input Space Time Cube |
The space-time cube that will be described. Space-time cubes have an |
File |
Output Characteristics Table (Optional) |
The table containing summary information about the input space-time cube. |
Table |
Output Spatial Extent Features (Optional) |
A feature class with a single rectangle that represents the spatial extent of the input space-time cube. |
Feature Class |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
