Area Solar Radiation (Spatial Analyst Tools)
Summary
Derives incoming solar radiation from a raster surface.
Legacy:
This tool is deprecated and will be removed in a future release.
The Raster Solar Radiation tool provides enhanced functionality or performance.
Learn more about how solar radiation is calculated
Usage
  • Calculating insolation can be very time consuming, where the calculations for a large digital elevation model (DEM) can take several hours, and for a very large DEM, even days. You may wish to do some test runs with a coarser resolution or subset of your data to ensure the settings are correct before committing a run with the full-resolution data.
  • The output radiation rasters will always be floating-point type and have units of watt hours per square meter (WH/m2). The direct duration raster output will be integer with unit hours.
  • The latitude for the site area (units: decimal degree, positive for the northern hemisphere and negative for the southern hemisphere) is used in calculations such as solar declination and solar position.
    The analysis is designed specifically for local landscape scales, so it is generally acceptable to use one latitude value for the whole DEM. With larger datasets, such as for states, countries, or continents, the insolation results will differ significantly at different latitudes (greater than 1 degree). To analyze broader geographic regions, you must divide the study area into zones with different latitudes.
  • For multiday time configurations, the maximum range of days is a total of one year (365 days, or 366 days for leap years). If the start day is greater than the end day, the time calculations will proceed into the following year.
    For example, [start day, end day] = [365, 31] represents December 31 to January 31 of the following year. For the example of [1, 2], the time is inclusive for the first day from 0:00 hours (January 1) to 0:00 (January 2). The start day and end day cannot be equal.
  • The year value for time configuration is used to determine a leap year. It does not have any other influence on the solar radiation analysis, as the calculations are a function of the time period determined by Julian days.
  • For within-day time configurations, the maximum range of time is one day (24 hours). Calculations will not be performed across days (for example, from 12:00 p.m. to 12:00 p.m. the next day). The start time must be less than the end time.
  • For within-day time configurations, the start and end times are displayed as solar time (units: decimal hours). Use the time conversion dialog box window to convert the local standard time and local solar time (HMS). When converting local standard time to solar time, the program accounts for equation of time.
  • The use of a z-factor is essential for correcting calculations when the surface z-units are expressed in units different from the ground x,y units. For accurate results, the z-units should be the same as the x,y ground units. If the units are not the same, use a z-factor to convert z-units to x,y units. For example, if the x,y units are meters and the z-units are feet, you can specify a z-factor of 0.3048 to convert feet to meters.
  • It is recommended that you have the data in a projected coordinate system with units of meters. If you run the analysis with a spherical coordinate system, you must specify an appropriate z-factor for that latitude. The following is a list of appropriate z-factors to use if the x,y units are decimal degrees and the z-units are meters:
    Latitude Z-factor
    0        0.00000898
    10       0.00000912
    20       0.00000956
    30       0.00001036
    40       0.00001171
    50       0.00001395
    60       0.00001792
    70       0.00002619
    80       0.00005156
  • The latitude for the site area (units: decimal degree, positive for the northern hemisphere and negative for the southern hemisphere) is used in calculations such as solar declination and solar position. Because the solar analysis is designed for landscape scales and local scales, it is acceptable to use one latitude value for the whole DEM. For broader geographic regions, you must divide the study area into zones with different latitudes.
  • For input surface rasters containing a spatial reference, the mean latitude is automatically calculated; otherwise, the latitude default is 45 degrees. When using an input layer, the spatial reference of the data frame is used.
  • Sky size is the resolution of the viewshed, sky map, and sun map rasters that are used in the radiation calculations (units: cells per side). These are upward-looking, hemispherical raster representations of the sky and do not have a geographic coordinate system. These rasters are square (equal number of rows and columns).
    The following are recommended sky size values when a time configuration of a whole year or multiple days is used:
    • For a 1 day interval, use a sky size of 1000 and above.
    • For a 0.25 day interval, use a sky size of 2000 and above.
    • For a 0.1 hour interval, use a sky size of 4000 and above.
    Increasing the sky size increases calculation accuracy but also increases calculation time considerably.
  • When the day interval setting is small (for example, < 14 days), use a larger sky size. During analysis, the sun map (determined by the sky size) is used to represent sun positions (tracks) for particular time periods to calculate direct radiation. With smaller day intervals, if the sky size resolution is not large enough, sun tracks may overlap, resulting in zero or lower radiation values for that track. Increasing the resolution provides a more accurate result.
  • The maximum sky size value is 10,000. A value of 200 is the default and is sufficient for whole DEMs with large day intervals (for example, > 14 days). A sky size value of 512 is sufficient for calculations at point locations where calculation time is less of an issue. At smaller day intervals (for example, < 14 days), it is recommended that you use higher values. For example, to calculate insolation for a location at the equator with day interval = 1, use a sky size of 2,800 or above.
  • Day intervals greater than 3 are recommended, as sun tracks within three days typically overlap, depending on sky size and time of year. For calculations of the whole year with monthly interval, day interval is disabled and the program uses calendar month intervals. The default value is 14.
  • Because the viewshed calculation can be highly intensive, horizon angles are only traced for the number of calculation directions specified. Valid values must be multiples of 8 (8, 16, 24, 32, and so on). Typically, a value of 8 or 16 is adequate for areas with gentle topography, and a value of 32 is adequate for complex topography. The default value is 32.
  • The number of calculation directions needed is related to the resolution of the input DEM. Natural terrain at 30-meters resolution is usually quite smooth, so fewer directions are sufficient for most situations (16 or 32). With finer DEMs, and particularly with human-made structures incorporated in the DEMs, the number of directions needs to increase. Increasing the number of directions increases accuracy but also increase calculation time.
  • The Create outputs for each interval parameter allows for the flexibility to calculate insolation integrated over a specified time period or insolation for each interval in a time series. For example, for the within-day time period with an hour interval of one, checking this parameter will create hourly insolation values; otherwise, insolation integrated for the entire day will be calculated.
  • The Create outputs for each interval parameter affects the format and number of output radiation files. When checked, the output raster will contain multiple bands that correspond to the radiation or duration values for each time interval (hour interval when time configuration is less than one day, or day interval when multiple days).
  • The diffuse proportion is the fraction of global normal radiation flux that is diffuse. Values range from 0 to 1. This value should be set according to atmospheric conditions. Typical values are 0.2 for very clear sky conditions and 0.3 for generally clear sky conditions.
  • The amount of solar radiation received by the surface is only a portion of what would be received outside the atmosphere. Transmittivity is a property of the atmosphere that is expressed as the ratio of the energy (averaged overall wavelengths) reaching the earth's surface to that which is received at the upper limit of the atmosphere (extraterrestrial). Values range from 0 (no transmission) to 1 (complete transmission). Typically observed values are 0.6 or 0.7 for very clear sky conditions and 0.5 for a generally clear sky.
    The value for the energy received at the earth's surface is at the shortest path through the atmosphere (that is, the sun is at the zenith, or directly overhead) and for sea level. For areas beyond Tropic of Capricorn and Tropic of Cancer, the sun can never be at the exact zenith, even at noon; however, this value still refers to the moment when the sun is at the zenith. Because the algorithm corrects for elevation effects, transmittivity should always be given for sea level.
    Transmittivity has an inverse relation with the diffuse proportion parameter.
  • See Analysis environments and Spatial Analyst for additional details on the geoprocessing environments that apply to this tool.
Parameters
Label Explanation Data type
Input raster
The input elevation surface raster.
Raster Layer
Latitude
(Optional)
The latitude for the site area. The units are decimal degrees with positive values for the northern hemisphere and negative values for the southern hemisphere.
Double
Sky size / Resolution
(Optional)
The resolution or sky size for the viewshed, sky map, and sun map rasters. The units are cells.
The default is a raster of 200 by 200 cells.
Long
Time configuration
(Optional)
Specifies the time period that will be used for the calculations.
  • Special days—Solar insolation will be calculated for the solstice days (summer and winter) and the equinox days (when the insolation for both spring and fall equinox are the same).
  • Within day—Calculations will be performed for a specified time period within a single day.
    Select the Julian day and provide the start and end times. When the start time and the end time are the same, instantaneous insolation will be calculated. When the start time is before sunrise and the end time is after sunset, insolation will be calculated for the whole day.
    • To enter the correct day, use the calendar button to open the Calendar dialog box.
  • Multiple days—Calculations will be performed for a specific multiple-day period within a year.
    Specify the start year, start day, and end day. When the end day is smaller than the start day, the end day is considered to be in the following year. The default time configuration starts on day 5 and ends on day 160 of the current Julian year.
    • To enter the correct days, use the calendar button to open the Calendar dialog box.
  • Whole year—Calculations will be performed for an entire year using monthly intervals for calculations.
    If the Create outputs for each interval parameter is checked, output files will be created for each month; otherwise, a single output will be created for the whole year.
Time configuration
Day interval
(Optional)
The time interval through the year (units: days) that will be used to calculate sky sectors for the sun map.
The default value is 14 (biweekly).
Long
Hour interval
(Optional)
The time interval through the day (units: hours) that will be used to calculate sky sectors for the sun map.
The default value is 0.5.
Double
(Optional)
Specifies whether a single total insolation value will be calculated for all locations or multiple values will be calculated for the specified hour and day interval.
  • Checked—Multiple radiation values will be calculated for each time interval over the entire time configuration. The number of outputs depends on the hour or day interval. For example, for a whole year with monthly intervals, the result will contain 12 output radiation values for each location. The output raster will contain multiple bands that correspond to the radiation or duration values for each time interval.
  • Unchecked—A single total radiation value will be calculated for the entire time configuration. This is the default.
Boolean
Z factor
(Optional)
The number of ground x,y units in one surface z-unit.
The z-factor adjusts the units of measure for the z-units when they are different from the x,y units of the input surface. The z-values of the input surface are multiplied by the z-factor when calculating the final output surface.
If the x,y units and z-units are in the same units of measure, the z-factor is 1. This is the default.
If the x,y units and z-units are in different units of measure, the z-factor must be set to the appropriate factor or the results will be incorrect.
For example, if the z-units are feet and the x,y units are meters, use a z-factor of 0.3048 to convert the z-units from feet to meters (1 foot = 0.3048 meter).
Double
Slope and aspect input type
(Optional)
Specifies how slope and aspect information will be derived for analysis.
  • From the input surface raster—The slope and aspect rasters will be calculated from the input surface raster. This is the default.
  • From a flat surface—Constant values of zero will be used for slope and aspect.
String
Calculation directions
(Optional)
The number of azimuth directions that will be used when calculating the viewshed.
Valid values must be multiples of 8 (8, 16, 24, 32, and so on). The default value is 32 directions, which is adequate for complex topography.
Long
Zenith divisions
(Optional)
The number of zenith divisions that will be used to create sky sectors in the sky map.
The default is eight divisions (relative to zenith). Values must be greater than zero and less than half the sky size value.
Long
Azimuth divisions
(Optional)
The number of azimuth divisions that will be used to create sky sectors in the sky map.
The default is eight divisions (relative to north). Valid values must be multiples of 8. Values must be greater than zero and less than 160.
Long
Diffuse model type
(Optional)
Specifies the type of diffuse radiation model that will be used.
  • Uniform sky—The uniform diffuse model will be used. The incoming diffuse radiation is the same from all sky directions. This is the default.
  • Standard overcast sky—The standard overcast diffuse model will be used. The incoming diffuse radiation flux varies with the zenith angle.
String
Diffuse proportion
(Optional)
The proportion of global normal radiation flux that is diffuse. Values range from 0 to 1.
Set this value according to atmospheric conditions. The default value is 0.3 for generally clear sky conditions.
Double
Transmittivity
(Optional)
The fraction of radiation that passes through the atmosphere (averaged overall wavelengths). Values range from 0 (no transmission) to 1 (all transmission).
The default is 0.5 for a generally clear sky.
Double
Output direct radiation raster
(Optional)
The output raster representing the direct incoming solar radiation for each location.
The output has units of watt hours per square meter (WH/m2).
Raster Dataset
Output diffuse radiation raster
(Optional)
The output raster representing the diffuse incoming solar radiation for each location.
Raster Dataset
Output direct duration raster
(Optional)
The output raster representing the duration of direct incoming solar radiation.
The output has units of hours.
Raster Dataset
Return value
Output global radiation raster
The output raster representing the global radiation or total amount of incoming solar insolation (direct + diffuse) calculated for each location of the input surface.
Raster
Environments
Auto Commit, Cell Size, Cell Size Projection Method, Current Workspace, Extent, Geographic Transformations, Mask, Output CONFIG Keyword, Output Coordinate System, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Requires Spatial Analyst
  • Standard: Requires Spatial Analyst
  • Advanced: Requires Spatial Analyst
