An overview of the Measuring Geographic Distributions toolset
Measuring the distribution of a set of features allows you to calculate a value that represents a characteristic of the distribution, such as the center, compactness, or orientation. You can use this value to track changes in the distribution over time or compare distributions of different features.
Using the tools in the Measuring Geographic Distributions toolset, you can answer questions such as the following:
  • Where's the center?
  • What's the shape and orientation of the data?
  • How dispersed are the features?
The Measuring Geographic Distributions toolset contains the following tools:
Tool
Central Feature
Identifies the most centrally located feature in a point, line, or polygon feature class.
Decompose Spatial Structure
Decomposes a feature class and neighborhood into a set of spatial components. The components represent potential spatial patterns among the features, such as clusters or trends.
Directional Distribution
Creates standard deviational ellipses or ellipsoids to summarize the spatial characteristics of geographic features: central tendency, dispersion, and directional trends.
Directional Trend
Creates a scatter plot chart on a feature layer displaying the trend of data values in a particular direction.
Linear Directional Mean
Identifies the mean direction, length, and geographic center for a set of lines.
Mean Center
Identifies the geographic center (or the center of concentration) for a set of features.
Median Center
Identifies the location that minimizes overall Euclidean distance to the features in a dataset.
Neighborhood Summary Statistics
Calculates summary statistics of one or more numeric fields using local neighborhoods around each feature. The local statistics include mean (average), median, standard deviation, interquartile range, skewness, and quantile imbalance. All statistics can be geographically weighted using kernels to give more influence to neighbors closer to the focal feature. Various neighborhood types can be used, including distance band, number of neighbors, polygon contiguity, Delaunay triangulation, and spatial weights matrix files (.swm). Summary statistics are also calculated for the distances to the neighbors of each feature.
Standard Distance
Measures the degree to which features are concentrated or dispersed around the geometric mean center.
