Central Feature (Spatial Statistics Tools)
Summary
Identifies the most centrally located feature in a point, line, or polygon feature class.
Learn more about how Central Feature works
Illustration
Central Feature tool illustration
Usage
  • The feature associated with the smallest accumulated distance to all other features in the dataset is the most centrally located feature; this feature is selected and copied to a newly created Output Feature Class. It is possible to have more than one feature sharing the smallest accumulated distance to all other features. When this happens, all of these most centrally located features are copied to the Output Feature Class.
  • Accumulated distances are measured using Euclidean distance or Manhattan distance , as specified by the Distance Method parameter.
  • For line and polygon features, feature centroids are used in distance computations. For multipoints, polylines, or polygons with multiple parts, the centroid is computed using the weighted mean center of all feature parts. The weighting for point features is 1, for line features is length, and for polygon features is area.
  • This tool honors the 3D nature of your point data and will use x, y and z values in its calculations if z values are available. Since these results are 3D in nature, they will need to be visualized in a Scene. Be sure that you are running the analysis in a Scene or copy the result layer into a Scene for correct visualization of your analysis results.
  • Map layers can be used to define the Input Feature Class. When using a layer with a selection, only the selected features are included in the analysis.
  • The Case Field is used to group features for separate Central Feature computations. The Case Field can be of integer, date, or string type. Records with null values for the Case Field will be excluded from the analysis.
  • Self-potential is the distance or weight between a feature and itself. Often this weight is zero, but in some cases you may want to specify another fixed value or a different value for every feature (perhaps based on polygon size, for example).
    Caution:
    When using shapefiles, keep in mind that they cannot store null values. Tools or other procedures that create shapefiles from nonshapefile inputs may store or interpret null values as zero. In some cases, nulls are stored as very large negative values in shapefiles. This can lead to unexpected results. See Geoprocessing considerations for shapefile output for more information.
Parameters
Label Explanation Data type
Input Feature Class
The feature class containing a distribution of features from which to identify the most centrally located feature.
Feature Layer
The feature class that will contain the most centrally located feature in the Input Feature Class.
Feature Class
Distance Method
Specifies how distances are calculated from each feature to neighboring features.
  • Euclidean—The straight-line distance between two points (as the crow flies)
  • Manhattan—The distance between two points measured along axes at right angles (city block); calculated by summing the (absolute) difference between the x- and y-coordinates
String
Weight Field
(Optional)
The numeric field used to weight distances in the origin-destination distance matrix.
Field
Self Potential Weight Field
(Optional)
The field representing self-potential—the distance or weight between a feature and itself.
Field
Case Field
(Optional)
Field used to group features for separate central feature computations. The case field can be of integer, date, or string type.
Field
Environments
Output Coordinate System, Geographic Transformations, Current Workspace, Scratch Workspace, Maintain fully qualified field names, Output has M values, M Resolution, M Tolerance, Output has Z values, Default Output Z Value, Z Resolution, Z Tolerance, XY Resolution, XY Tolerance
Special cases
Feature geometry is projected to the Output Coordinate System prior to analysis.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
