Mean Center (Spatial Statistics Tools)
Summary
Identifies the geographic center (or the center of concentration) for a set of features.
Learn more about how Mean Center works
Illustration
Mean Center tool illustration
Usage
  • The mean center is a point constructed from the average x, y and if available, z values for the input feature centroids.
  • This tool requires projected data to accurately measure distances.
  • The x, y and z values for the mean center point features are attributes in the Output Feature Class. The values are stored in the fields XCOORD, YCOORD and ZCOORD.
  • The Case Field is used to group features for separate mean center computations. When a Case Field is specified, the input features are first grouped according to case field values, and then a mean center is calculated for each group. The case field can be of integer, date, or string type. Records with NULL values for the Case Field will be excluded from analysis.
  • The Dimension Field is any numeric field in the input feature class. The Mean Center tool will compute the average for all values in that field and include the result in the output feature class.
  • This tool honors the 3D nature of your point data and will use x, y and z values in its calculations if z values are available. Since these results are 3D in nature, they will need to be visualized in a Scene. Be sure that you are running the analysis in a Scene or copy the result layer into a Scene for correct visualization of your analysis results.
  • For line and polygon features, feature centroids are used in distance computations. For multipoints, polylines, or polygons with multiple parts, the centroid is computed using the weighted mean center of all feature parts. The weighting for point features is 1, for line features is length, and for polygon features is area.
  • Map layers can be used to define the Input Feature Class. When using a layer with a selection, only the selected features are included in the analysis.
    Caution:
    When using shapefiles, keep in mind that they cannot store null values. Tools or other procedures that create shapefiles from nonshapefile inputs may store or interpret null values as zero. In some cases, nulls are stored as very large negative values in shapefiles. This can lead to unexpected results. See Geoprocessing considerations for shapefile output for more information.
Parameters
Label Explanation Data type
Input Feature Class
A feature class for which the mean center will be calculated.
Feature Layer
A point feature class that will contain the features representing the mean centers of the input feature class.
Feature Class
Weight Field
(Optional)
The numeric field used to create a weighted mean center.
Field
Case Field
(Optional)
Field used to group features for separate mean center calculations. The case field can be of integer, date, or string type.
Field
Dimension Field
(Optional)
A numeric field containing attribute values from which an average value will be calculated.
Field
Environments
Output Coordinate System, Geographic Transformations, Current Workspace, Scratch Workspace, Maintain fully qualified field names, Output has M values, M Resolution, M Tolerance, Output has Z values, Default Output Z Value, Z Resolution, Z Tolerance, XY Resolution, XY Tolerance
Special cases
Feature geometry is projected to the Output Coordinate System prior to analysis. All mathematical computations are based on the Output Coordinate System spatial reference.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
