Evaluate Predictions with Cross-validation (Spatial Statistics Tools)
Summary
Evaluates predictive model performance using cross-validation. This tool generates validation metrics for models created using the Forest-based and Boosted Classification and Regression, Generalized Linear Regression, and Presence-only Prediction tools. It allows you to specify the evaluation type (for example, K-fold or spatial K-fold), number of groups, and rare event balancing to ensure robust and unbiased model assessment.
Learn more about how Evaluate Predictions with Cross-validation works
Illustration
Evaluate Predictions with Cross-validation tool illustration
Usage
  • The Evaluation Type parameter has the following options for splitting features into groups:
    • Spatial k-fold—Use spatial cross validation to evaluate how a model will predict to features that are geographically outside of the training data's study area.
    • Random k-fold—Use random cross validation to evaluate how a model will predict to features that are geographically within the training data's study area.
  • When using classification to predict rare events or unbalanced categories, use the Balancing Type parameter to balance the number of samples within each categorical level. Test the different balancing methods in this tool; then, select the balancing method that performed best and run it on the full training dataset before predicting using the Prepare Data for Prediction tool.
  • Cross-validation is not used to generate a single model or model file. It generates accuracy metrics that can be used to assess how well a model and its parameters predict data that was excluded when the model was trained.
  • This tool will not accept analysis features that were first oversampled in the Prepare Data for Prediction tool, that is, balanced using random oversampling or SMOTE. Oversampled data can not be used in a validation set due to data leakage.
  • Parameters in the original prediction tool are honored. However, for analysis results from the Forest-based and Boosted Classification and Regression tool, the validation data is set to 0. If the Optimize Parameters parameter was used in the Forest-based and Boosted Classification and Regression tool, the optimal parameters from the original tool run will be used in running cross validation.
  • The tool creates the following outputs:
    • Output Features—Records the training dataset and the training and predicting results of each feature in the training dataset.
    • Output Validation Table—Records the evaluation metrics for each validation run.
    The tool also creates many useful geoprocessing messages, including the Average Out of Sample Diagnostic Statistics table.
Parameters
Label Explanation Data type
Analysis Result Features
The feature class containing the training output results from the Forest-based and Boosted Classification and Regression, Generalized Linear Regression, or Presence-only Prediction tool. The prediction training results will be evaluated with cross validation.
Feature Layer
Output Features
The output features that will contain the original independent variables, dependent variable, and additional fields summarizing the cross-validation results.
Feature Class
The output table that will contain evaluation metrics for each cross-validation run.
Table
Analysis Input Features
The input features that will be used in the predictive analysis that produced the analysis result features.
Feature Layer
Evaluation Type
(Optional)
Specifies the method that will be used to split the Analysis Result Features parameter value into k groups.
  • Random k-fold—The analysis result features will be randomly split into k groups. Each group will contain the same, or a similar, number of features. If predicting categories (classification), every category in the dependent variable will appear in each training group. This is the default.
  • Spatial k-fold—The analysis result features will be spatially split into k groups using k-means clustering on the input polygon centroids or points. If predicting categories (classification), every category in the dependent variable will appear in each training group. Each group is spatially separate from the others.
String
Number of Groups
(Optional)
The number of groups that the Analysis Result Features parameter value will be split into. The number of groups must be larger than 1. The default is 10.
Long
Balancing Type
(Optional)
Specifies the method that will be used to balance the number of samples of each dependent variable category in the training group. This parameter is active if the original model predicted a categorical variable.
  • None—The analysis result features will not be balanced. This is the default.
  • Random Undersampling—Random features will be removed from each nonminority class until the number of features matches the number of features in the minority class.
  • Tomek Undersampling—Features in each nonminority class that are close to the features in the minority class will be removed. This method will improve the boundary between the classes; however, each class may have a different number of features.
  • K-Medoids Undersampling—Features in the nonminority class that are not representative of the class will be removed until the number of features matches the number of features in the minority class.
  • Random Oversampling—Features in the minority class will be randomly duplicated until the number of features matches the number of features in the majority class.
  • SMOTE (Oversampling)—Synthetic features will be generated for the minority class by interpolating between existing features until the number of features matches the number of features in the majority class.
String
Environments
Random number generator, Output Coordinate System, Parallel Processing Factor
Licensing information
  • Basic: Limited
    Spatial Analyst is required to use rasters.
  • Standard: Limited
  • Advanced: Limited
