An overview of the Modeling Spatial Relationships toolset
The Modeling Spatial Relationships toolset contains tools for exploring and quantifying data relationships.
In addition to analyzing spatial patterns, GIS analysis can be used to examine or quantify relationships among features. Use the Modeling Spatial Relationships tools to construct spatial weights matrices or model spatial relationships using various analysis techniques including regression, forest-based approaches, and maximum entropy methods.
Tool |
Description |
Calculates the spatial association between two continuous variables using the Lee's L statistic. |
Estimates the causal effect of a continuous exposure variable on a continuous outcome variable by approximating a randomized experiment and controlling for confounding variables. |
Measures local patterns of spatial association, or colocation, between two categories of point features using the colocation quotient statistic. |
Predicts the time until an event occurs based on the prior times to the event. Explanatory variables can be used to improve the predictions, and the tool can determine which variables increase or decrease the time until the event. |
Evaluates predictive model performance using cross-validation. This tool generates validation metrics for models created using the Forest-based and Boosted Classification and Regression, Generalized Linear Regression, and Presence-only Prediction tools. It allows you to specify the evaluation type (for example, K-fold or spatial K-fold), number of groups, and rare event balancing to ensure robust and unbiased model assessment. |
Evaluates how variables influence predictions from a spatial statistics model ( |
Evaluates all possible combinations of the input candidate explanatory variables, looking for OLS models that best explain the dependent variable within the context of user-specified criteria. |
Creates models and generates predictions using one of two supervised machine learning methods: an adaptation of the random forest algorithm developed by Leo Breiman and Adele Cutler or the Extreme Gradient Boosting (XGBoost) algorithm developed by Tianqi Chen and Carlos Guestrin. Predictions can be performed for both categorical variables (classification) and continuous variables (regression). Explanatory variables can take the form of fields in the attribute table of the training features, raster datasets, and distance features used to calculate proximity values for use as additional variables. In addition to validation of model performance based on the training data, predictions can be made to either features or a prediction raster. |
Performs generalized linear regression (GLR) to generate predictions or to model a dependent variable in terms of its relationship to a set of explanatory variables. This tool can be used to fit continuous (OLS), binary (logistic), and count (Poisson) models. |
Constructs a spatial weights matrix file ( |
Generates a spatial weights matrix file ( |
Performs Geographically Weighted Regression (GWR), a local form of linear regression used to model spatially varying relationships. |
Analyzes two variables for statistically significant relationships using local entropy. Each feature is classified into one of six categories based on the type of relationship. The output can be used to visualize areas where the variables are related and explore how their relationship changes across the study area. |
Performs Multiscale Geographically Weighted Regression (MGWR), which is a local form of linear regression that models spatially varying relationships. |
Performs global Ordinary Least Squares (OLS) linear regression to generate predictions or to model a dependent variable in terms of its relationships to a set of explanatory variables. |
Predicts continuous or categorical values using a trained spatial statistics model ( |
Enhances data for predictive workflows in the Forest-based and Boosted Classification and Regression, Generalized Linear Regression, and Presence-only Prediction tools, as well as other models. This involves splitting features into training and testing sets, extracting variables from rasters and distance features, balancing data for better classification accuracy, and conducting spatial thinning on biased spatial data. |
Models the presence of a phenomenon given known presence locations and explanatory variables using a maximum entropy approach (MaxEnt). The tool provides output features and rasters that include the probability of presence and can be applied to problems in which only presence is known and absence is not known. |
Measures the degree of spatial association between two regionalizations of the same study area in which each regionalization is composed of a set of categories, called zones. The association between the regionalizations is determined by the area overlap between zones of each regionalization. The association is highest when each zone of one regionalization closely corresponds to a zone of the other regionalization. Similarly, spatial association is lowest when the zones of one regionalization have large overlap with many different zones of the other regionalization. The primary output of the tool is a global measure of spatial association between the categorical variables: a single number ranging from 0 (no correspondence) to 1 (perfect spatial alignment of zones). Optionally, this global association can be calculated and visualized for specific zones of either regionalization or for specific combinations of zones between regionalizations. |
Estimates a global spatial regression model for a point or polygon feature class. |
