ArcGIS Reality Studio system requirements
Before installing or upgrading ArcGIS Reality Studio, ensure that your system meets the minimum requirements to run it. Also, learn what resources are recommended for best performance.
Hardware requirements
The minimum and recommended requirements to run ArcGIS Reality Studio are listed below. Minimum requirements will support the application but may not perform well. Best performance is gained using the recommended requirements.
Item |
Supported and recommended |
CPU |
Minimum: 6 cores, 12 threads. A processor supporting AVX2 instruction set is required. |
Recommended: 24 to 32 dual cores. |
Storage |
Minimum: 1 TB internal disk drive For performance reasons, avoid using USB drives. |
Recommended: 1 TB internal SSD disk processing directory |
Memory/RAM |
Minimum: 32 GB Required RAM is dependent on input data, project size, and configuration. Very large projects can require more RAM. See Additional system considerations for details. |
Recommended: 64 GB or more |
GPU |
Minimum: An integrated GPU that is supported by the manufacturer Certain products require a dedicated GPU for processing. See Additional system considerations for details. If multiple GPUs meet requirements, the GPU with highest compute capacity is used. |
Recommended: A dedicated NVIDIA GPU with CUDA compute capability 7.5 or later |
Dedicated (not shared) graphics memory |
Minimum: 4 GB of memory for display. |
Recommended: 16 GB or more for processing. |
Screen resolution |
Minimum: 1024x768 |
Recommended: 1080p or higher Higher resolutions, such as 4K, require more video memory and a more powerful GPU. |
Recommendations for network connections
Item |
Recommendation |
Workspace |
A network attached storage (NAS) with a 10 Gbps connection and sufficient capacity to store all projects in your workspace, including the produced results. |
Processing Nodes |
1 Gigabit connection for contributors. |
Cloud instances examples
The following are cloud instance types that meet hardware requirements:
Cloud instance type |
Recommendation |
Amazon Web Services (AWS) |
Recommended: g4dn.4xlarge (available as an ArcGIS Image Dedicated Pro Machine of type Large_GPU) Check the hardware requirements to ensure the virtual desktop has enough RAM for your project and the Elastic Block Store (EBS) storage meets the combined storage needs. |
Microsoft Azure |
Recommended: NV12s v3 (available as an ArcGIS Image Dedicated Pro Machine of type Large_GPU) Check the hardware requirements to ensure the virtual desktop has enough RAM for your project and the Locally Redundant Storage (LRS) storage meets the combined storage needs. |
Software requirements
The following are required to run ArcGIS Reality Studio.
Minimum software requirements
The following software must be installed separately before installing ArcGIS Reality Studio:
Software |
Minimum requirement |
Microsoft .NET |
Microsoft .NET Desktop Runtime 8.0.0 or a later patch release (8.0.1 and so on), using a Windows x64 installer, is required. Microsoft .NET Desktop Runtime is updated frequently. It is recommended that you install the latest patches as they become available. However, installing .NET 9 or any later version doesn't fulfill this software requirement. |
WebView2 Runtime |
Microsoft Edge WebView2 Runtime version 132 or later is required. If it is not already installed on the machine, use the Evergreen Bootstrapper or Evergreen Standalone Installer from Microsoft. Note:A per-machine installation (the default) of ArcGIS Reality Studio requires a per-machine installation of WebView2 Runtime. To do this, right-click the WebView2 installer and click Run as administrator. |
DirectX* |
Minimum: DirectX 11, feature level 11.0, Shader Model 5.0 |
OpenGL* |
Minimum: OpenGL 4.3 with the ARB_clip_control and EXT_texture_compression_s3tc extensions |
* If DirectX requirements are not met, OpenGL is automatically used. You can also manually change to OpenGL, such as when you suspect an issue with the DirectX driver.
Use the latest available driver.
Cloud storage services, such as Microsoft OneDrive and Google Drive, are not supported unless stated otherwise in the documentation about specific tools and functionality.
Additional software requirements
The following software must be installed separately to support certain ArcGIS Reality Studio workflows:
Software |
ArcGIS Coordinate Systems Data |
Some geographic transformations (for example, NTv2, GEOCON, and NADCON5) and vertical transformations based on geoids, quasi-geoids, or other conversion grids (for example, EGM and VERTCON) require files that are not installed with ArcGIS Reality Studio. This can lead to failed processes. |
Deep Learning Libraries |
To generate Gaussian splats, it is required that the supported deep learning libraries are installed. Note:No deep learning is performed in ArcGIS Reality Studio. Learn more about preparing ArcGIS Reality Studio for Gaussian splat generation |
ArcGIS Raster Data |
If your environment requires running ArcGIS Reality Studio offline, additional raster data must be installed on your machine so that all main processing steps can be performed. Learn more about preparing ArcGIS Reality Studio for offline use |
Supported operating systems
The software is supported on the Microsoft Windows operating systems listed below, as long as the operating system is also currently supported by its provider for general or public use.
Operating system |
Latest update or service pack tested |
Windows 11 Home, Pro, and Enterprise (64 bit) |
Sept 2025 update |
Windows Server 2025 Standard and Datacenter (64 bit) |
Sept 2025 update |
Windows Server 2022 Standard and Datacenter (64 bit) |
Sept 2025 update |
Windows Server 2019 Standard and Datacenter (64 bit) |
Sept 2025 update |
Prior and future updates or service packs for these operating system versions are supported unless otherwise stated. The operating system version and updates must also be supported by the operating system provider.
The Desktop Experience option is required on all versions of Windows Server.
System requirements vary depending on dataset size, process settings, and workspace configuration. To ensure successful processing, at least one workstation contributing to your workspace must meet the system requirements outlined in this section and the match requirements functionality of the workspace must be turned on.
Memory requirements
The following table describes the memory requirements for projects based on the number of images.
Project size |
Required RAM |
Up to 4,000 images |
32 GB |
Up to 10,000 images |
64 GB |
Up to 30,000 images |
128 GB |
Up to 65,000 images |
256 GB |
Reconstruction
The following sections describe requirements for reconstruction.
Tile size
You can define the tiling scheme for raster and point cloud products when creating a reconstruction. Specify the output raster pixel size, tile size, and tiling origin to meet project requirements without postprocessing.
Manually setting tile size can affect performance and memory usage. Use the following recommendations to determine maximum tile sizes based on available RAM and reconstruction scenario:
RAM |
Nadir scenario |
Oblique scenario |
Drone scenario |
64GB |
Max 2000 x raster pixel size |
Max 4000 x raster pixel size |
128GB or more |
Max 5000 x raster pixel size |
Tile size must be a multiple of the raster pixel size.
Gaussian splats requirements
If you select Gaussian splats as the output product, your processing machines must meet the following requirements:
Item |
GPU |
Minimum: NVIDIA GPU with CUDA compute capability 7.5 or later |
GPU VRAM |
Minimum: 8GB |
Recommended: 16GB or more |
Additional software requirement |
Licensing
A Single Use license is the only license type available for ArcGIS Reality Studio.
