Segmentation and Classification geoprocessing functions
Disponible avec une licence Spatial Analyst.
Disponible avec une licence Image Analyst.
The Segmentation and Classification geoprocessing functions enable you to prepare segmented rasters to create classified raster datasets.
The following table lists the available geoprocessing functions and provides a brief description of each.
Geoprocessing Function |
Description |
Classifies a raster dataset based on an Esri classifier definition file ( The |
Computes a confusion matrix with errors of omission and commission and derives a kappa index of agreement, Intersection over Union (IoU), and overall accuracy between the classified map and the reference data. |
Computes a set of attributes associated with the segmented image. The input raster can be a single-band or 3-band, 8-bit segmented image. |
Creates randomly sampled points for postclassification accuracy assessment. |
Converts labeled vector or raster data to deep learning training datasets using a remote sensing image. The output is a folder of image chips and a folder of metadata files in the specified format. |
Generates training samples from seed points, such as accuracy assessment points or training sample points. A typical use case is generating training samples from an existing source, such as a thematic raster or a feature class. |
Estimates the accuracy of individual training samples. The cross validation accuracy is computed using the previously generated classification training result in an |
Performs subpixel classification and calculates the fractional abundance of different land-cover types for individual pixels. |
Corrects segments or objects cut by tile boundaries during the segmentation process performed as a raster function. This tool is helpful for some regional processes, such as image segmentation, that have inconsistencies near image tile boundaries. This processing step is included in the Segment Mean Shift tool. It should only be used on a segmented image that was not created from that tool. |
Groups adjacent pixels that have similar spectral characteristics into segments. |
Generates an Esri classifier definition file ( |
Updates the |
