Federate a site with ArcGIS Enterprise on Azure
The base ArcGIS Enterprise deployment created using ArcGIS Enterprise Cloud Builder for Microsoft Azure includes a GIS Server site that is configured as the hosting server. You can enable additional functionality by adding the following ArcGIS Server sites to an ArcGIS Enterprise deployment created with Cloud Builder:
  • ArcGIS Data Pipelines Server
    ArcGIS Data Pipelines Server is a required component of ArcGIS Data Pipelines.
  • ArcGIS GeoEvent Server
    Add a GeoEvent Server site to enable real-time, event-based data streams to your organization and to archive streamed data.
    To archive the real-time data streamed through GeoEvent Server, the hosting server must be configured with a spatiotemporal big data store. If you did not create a spatiotemporal big data store when you deployed ArcGIS Enterprise, add one.
  • ArcGIS Image Server
    Add an Image Server site to the deployment so that image services you publish to the federated Image Server automatically create items in the ArcGIS Enterprise organization. If members of the organization need to run raster analysis tools, you can configure this site as the raster analysis server.
    Add a second ArcGIS Image Server site to the deployment if you require an image hosting server to host the image layers generated when members of the organization run raster analysis tools.
  • ArcGIS Knowledge Server
    An ArcGIS Knowledge Server site is a required component of ArcGIS Knowledge.
    The hosting server must have an ArcGIS Data Store graph store configured for you to use the ArcGIS Knowledge Server site.
  • ArcGIS Mission Server
    An ArcGIS Mission Server site is a required component of ArcGIS Mission.
  • ArcGIS Notebook Server
    ArcGIS Notebook Server is a federated server that allows you to use Python to perform spatial analysis, create data science and machine learning workflows, manage GIS data, and automate administrative tasks for ArcGIS Enterprise.
    To use ArcGIS Notebook Server, you must install and configure Mirantis Container Runtime on the ArcGIS Notebook Server instance on Azure.
  • ArcGIS Reality Server
    ArcGIS Reality Server is a federated server that allows you to manage and process collections of overlapping images from different sources and generate high-fidelity 2D and 3D products.
  • ArcGIS Video Server
    ArcGIS Video Server is a federated server that allows you to publish or stream videos with a geospatial component to use as another type of spatial layer in your GIS.
  • ArcGIS Workflow Manager Server
    An ArcGIS Workflow Manager Server site is a required component of ArcGIS Workflow Manager.
    See License Workflow Manager for licensing requirements.
  • GIS Server
    You can federate additional GIS Server sites with the ArcGIS Enterprise deployment to run map and feature services you publish from ArcGIS Pro. When you publish to a federated server, the services are automatically added as items in the organization.
Obtain a license from Esri
Each of the types of federated sites listed above requires a license.
When these licenses are available to your Esri account, you can download them from My Esri.
Note that you must have an additional ArcGIS GIS Server license (beyond the one used for your hosting server) to federate an additional GIS Server site with an ArcGIS Enterprise deployment.
Connect to Azure from Cloud Builder and choose the site type
Start Cloud Builder, sign in to your Microsoft Azure account, and specify the type of federated server site to create.
  1. Start ArcGIS Enterprise Cloud Builder for Microsoft Azure.
  2. Sign in to Microsoft Azure.
    If you have an Azure Government subscription and want to use the Microsoft Azure Government cloud, check U.S. Government Cloud.
    The Azure account you use to connect requires the following roles at a minimum:
    • The Azure Reader role at the subscription scope level
    • The Azure Contributor role at the resource group scope level if you will use resource groups that you create outside Cloud Builder
  3. Choose a Microsoft Entra ID tenant and click Next.
  4. Choose the Azure subscription that contains the ArcGIS Enterprise deployment to which you want to add an ArcGIS Server site, and click Next.
  5. Ensure that the V2 Sites option is selected, and click Deploy a new site.
    You can no longer add federated servers to V1 deployments.
  6. Choose Federated Server.
  7. Choose one of the site types depending on the functionality you need.
    • GIS Server
    • GeoEvent Server
    • Image Server
    • Notebook Server
    • Mission Server
    • Workflow Manager Server
    • Knowledge Server
    • Reality Server
    • Data Pipelines Server
    • Video Server
  8. Click Next to proceed to the Site Options settings.
Specify site options
Specify a resource group, choose how many machines to include in the site, and choose the virtual machine image that will be used to create the machines.
  1. From the Deployment resource group drop-down list, choose the resource group used by the ArcGIS Enterprise deployment with which you are federating the new ArcGIS Server site.
  2. If you're federating an ArcGIS Image Server site, choose one of the following Server function options:
    • Image hosting—Choose this option if the site will host dynamic image services for the ArcGIS Enterprise deployment. If you choose this option, you must include a raster store with the deployment. Each ArcGIS Enterprise deployment can have one image hosting site.
    • Raster analysis—Choose this option if you're adding the site to provide raster analysis functionality for the ArcGIS Enterprise deployment. If you choose this option, you must include a raster store with the deployment. Each ArcGIS Enterprise deployment can have one raster analysis site.
    • None—Choose this option if the site doesn't need to fill either of the other two roles and if users will primarily publish cached image services. You can have as many of these federated sites as you require.
    See Configure and deploy raster analytics and Configure and deploy image hosting for information about these roles.
  3. To avoid duplication of Azure resource names in resource groups, Cloud Builder allows you to prefix resources with a specified string. Check Prefix Azure Resource Manager (ARM) resource names with, and provide up to three alphanumeric characters.
    Cloud Builder automatically populates this value with a random two-character string. To change the string, provide a different prefix to add to Azure resource names such as load balancers and availability sets.
    Prefixes must start with an alphabetic character.
    Adding a prefix avoids duplication of resource names and allows you to categorize resources according to your requirements for managing in the Azure portal or billing.
    For disaster recovery configurations, create multiple resource groups with the same prefix.
  4. Choose the machine image to use: a managed image, an image in the Azure Compute Gallery, or an image you create.
    The image must exist in the same region used by the ArcGIS Enterprise deployment with which you are federating the new ArcGIS Server site.
    • To use an Esri image, choose the image from the drop-down list.
    • To use an image from the image list, choose Managed images, and choose the image from the drop-down list.
    • To use a machine image in the Azure Compute Gallery, choose the gallery from the Select gallery drop-down list, choose the machine image from the Select image drop-down list, choose the ArcGIS software version to include on the image from the Select version drop-down list, and choose the Azure region from the Select region list. The region should be the same as where your resource group is deployed.
    • To create an image from a source VHD file, choose Managed images, and do the following:
    1. Click the Add button next to Select image.
    2. Provide a name for the image, and click Check availability to ensure that the name is unique.
      The image name can contain only letters, numbers, underscores (_), dots (.), and hyphens (-). The name must start with a letter or number and end with a letter, number, or underscore.
    3. Choose or create a resource group in which to store the image.
    4. Choose the region in which to create the image.
      Use the same region that contains the .vhd file from which you create the image.
    5. For Source disk, click the button to browse to the .vhd file in your storage account. Choose the storage account that contains the file, choose the file, and click OK.
      The storage accounts available on the Select image disk dialog box are based on the region you chose in the previous step.
    6. Choose one of the following disk drive type to use for the image:
      • SSD—A premium solid-state drive
      • Standard SSD—A standard solid-state drive
    7. For Size, choose the image size.
      The image size determines the minimum size of the operating system disk (C:\) of the virtual machine created from the image. You can increase the size of the provisioned disk for the virtual machine created from the image, but you cannot decrease the size below the image size.
      See the Microsoft Azure documentation for more information about Azure managed disks.
    8. Click Create to create the image.
  5. Optionally, add one or more user-assigned managed identities for authentication purposes when accessing an Azure Blob storage container used for the configuration store or cloud storage data stores.
    1. Click the Add button in the Assign User Assigned Managed Identity section.
    2. Choose the subscription that contains the identity.
    3. Choose the user-assigned managed identity from the Identity drop-down list, and click Add.
    Tip:
    A user-assigned managed identity is required if you will enable Azure Monitor Log Analytics.
    The Azure Storage Blob Data Owner role and Storage Table Data Contributor role must be assigned to the user-assigned managed identity to access the configuration store. See the Microsoft Azure documentation for instructions to assign a role to a user-assigned managed identity.
  6. Click Next to proceed to the Federation Options settings.
Specify an ArcGIS Enterprise deployment
Complete the following steps to specify the ArcGIS Enterprise deployment to which the federated server will be added.
  1. Choose your ArcGIS Enterprise deployment from the drop-down list.
  2. Provide the username and password for the login you specified for the site administrator when you created the ArcGIS Enterprise deployment.
  3. Click Next to proceed to the Machine Options settings.
Specify machine options
Specify credentials for the virtual machine administrator and enable optional machine settings such as automatic shutdown and automatic operating system updates. You can also add the machines to the same Azure Active Directory domain as the ArcGIS Enterprise deployment.
Additional options on this Cloud Builder page vary depending on whether you create a single-machine or multiple-machine site and what type of federated server you create.
  1. Provide a username and password for Machine administrator.
    This is the Windows login you will use to administer the virtual machines in the site, and you will need it when you upgrade the deployment. The same login and password are used for all machines in the site.
    The username must contain three or more characters and contain no spaces, and it cannot be admin or administrator. The password must meet Windows Server complexity requirements.
  2. Choose the time zone you want the virtual machines to use.
  3. Click Domain join options to add the federated server machines to the same Azure Active Directory as the ArcGIS Enterprise deployment.
    1. On the Domain Join Options dialog box, check the Join existing Windows domain check box.
    2. Provide the name of the Azure Active Directory domain.
    3. Provide the username and password for the domain administrator.
    4. Click Apply.
  4. If you check the Enable automatic operating system updates check box, Microsoft Azure will apply updates to the operating systems on the virtual machines.
  5. Optionally, check Enable trusted launch to secure the virtual machines in the deployment.
    This option is only available if you use a compute gallery image or Esri image to create the deployment. Refer to the Microsoft Azure documentation for a description of trusted launch functionality.
    You can additionally enable the following options for trusted launch:
  6. If you do not require access to the deployment during specific hours of the day, you can configure the machines to shut down at a specific time each day. To do this, check the Enable daily automatic shutdown check box, and set the shutdown time from the drop-down list.
    The time is in the time zone you chose for the virtual machines.
    Shutting down machines allows you to save money because the machines are not running when you do not need them. However, the machines do not automatically restart; you must restart each machine in the deployment when you need them again. You can restart the machines from Cloud Builder or the Microsoft Azure portal.
  7. Optionally, if you are federating an ArcGIS Image Server site to be used as a raster analytics server, or you are federating an ArcGIS Reality Server site, check the Install GPU extension option.
    A GPU extension is required if you will subsequently configure deep learning raster analytics on the machines.
    For an ArcGIS Reality Server site, the GPU extension is required to generate Gaussian Splats products.
    You must use a GPU-based machine when you configure machines; otherwise, the GPU extension will not be installed.
  8. Optionally, if you are federating an ArcGIS Video Server site, you can specify the port numbers to use for livestreaming videos.
    Default ports are provided. You can change them now, or use after you deploy.
    The maximum UDP port range you can assign in Azure is 101. For example, the default values for the minimum and maximum ports defining the range are 50100 and 50200, which is 101 ports.
  9. Click Next to define where system directories will persist.
Define system directory locations
Choose where to create the ArcGIS Server configuration store and directories for the federated server.
You must use a file share (step 1) for ArcGIS Data Pipelines Server and ArcGIS Video Server; cloud storage is not supported for these types of sites.
  1. To keep the ArcGIS Server configuration store and directories in a shared directory on a virtual machine, follow these steps:
    1. Choose Store server configuration store and server directories on a file share.
    2. Choose one of the following options for the virtual machine.
      • File share on first machine—Uses a shared directory on the first machine created for the ArcGIS Server site.
      • File share on separate virtual machine—Uses a shared directory on an additional virtual machine that Cloud Builder will create.
      • File share of base deployment—Uses the file share of the ArcGIS Enterprise.
      • Existing file share path—Provide the path to a file share on an existing virtual machine.
  2. To keep the ArcGIS Server configuration store in a cloud storage location and the ArcGIS Server directories in a shared directory, follow the steps below:
    1. Choose Store server configuration store in cloud storage and the server directories on a file share.
    2. Choose one of the following options for the virtual machine for the ArcGIS Server directories.
    3. In the Cloud Storage Options section, choose a storage account from the drop-down list, or click the Create button and define a new storage account.
    4. Choose an authentication type to access the storage account.
      • ServicePrincipal—If you configured a service principal for the account specified in the previous step, provide the tenant ID, client ID, and client secret for the service principal. See the Microsoft Azure help for an explanation of service principals.
        The Azure Storage Blob Data Owner role and Storage Table Data Contributor role must be assigned to the service principal.
      • AccessKey—When you choose this option, Cloud Builder will obtain the access key for the account.
      • UserAssignedIdentity—To use this option, you must have added a user-assigned managed identity when you defined site options. Choose the identity from the drop-down list.
  3. To keep the ArcGIS Server configuration store and the ArcGIS Server directories in a cloud storage location, follow the steps below:
    This option is not available for ArcGIS Notebook Server or ArcGIS Mission Server sites.
    1. Choose Store server configuration and server directories in cloud storage and provide information in the Cloud Services Options section.
    2. For Storage account, click the Options button to choose the account for the location of the Blob Storage container.
    3. Choose or create a Blob Storage container to use for the ArcGIS Server configuration store and system directories.
      The choices you make for the storage account populate the Server system directories Blob container folder path field with the container path.
    4. For Service Bus namespace, choose or create a Service Bus namespace.
      See the Microsoft Azure help for information about Service Bus namespaces and queues.
    5. For Cosmos DB account, choose or create a Microsoft Azure Cosmos DB for NoSQL account for the location of the Azure Cosmos DB for NoSQL database.
    6. For Cosmos DB database, choose or create the database to store the configuration store of the ArcGIS Server site and related tables.
    7. Choose an authentication type to access the storage account and Azure Cosmos DB for NoSQL database.
      You must assign the following Azure roles if you use a service principal or user-assigned managed identity:
      • Storage Account Contributor and Storage Blob Data Owner roles to the storage account
      • Service Bus Data Owner role to the Service Bus Namespace
      • Cosmos DB Operator and Cosmos DB Built-in Data Contributor roles to the Cosmos DB account.
    8. Click Next to proceed to the Data Store Options settings.
  4. Click Next.
    • If you're creating a GIS Server site, ArcGIS Image Server site, or ArcGIS Reality Server site, clicking Next takes you to the Database Options settings.
    • For other federated server types, clicking Next takes you to the Machine Specifications settings.
Choose database options
You can register a database with the GIS Server site or ArcGIS Image Server site that you add as a federated server. Use the database to store source data for ArcGIS Server web services.
If you are federating an ArcGIS Reality Server site or federating an ArcGIS Image Server to fill the image hosting or raster analysis role, you must register a database and it must contain a geodatabase.
Tip:
  • When you register a database at the time of adding the federated server site, the database always contains an enterprise geodatabase.
  • You can use Cloud Builder to add a database to the site after you finish federating. When you register the database after creating and federating the site, you have additional options for registration; however, these additional options are only applicable when you register the database with a GIS Server site.
  1. Choose the type of database to register with the site.
    • If you do not want to register a database with the site at this time, choose None from the Database type drop-down menu and proceed to the next step.
    • If you choose a database service (Microsoft Azure SQL Database, Microsoft Azure SQL Managed Instance, or Microsoft Azure Database for PostgreSQL), create or choose an existing database server and database, and provide a username and password for the database administrator and a username and password for a user who has permissions to create data in the database.
      If these resources don't exist, Cloud Builder will create them.
      Cloud Builder only creates Flexible Server instances of Microsoft Azure Database for PostgreSQL. However, if you have an existing single-server instance, you can choose it from the Database server drop-down menu.
    • If you choose Microsoft SQL Server, follow these steps to create and register a database:
    1. In the Database server field, provide a name for the virtual machine that will host the Microsoft SQL Server database.
    2. In the Database field, provide a name for the database.
      The name must meet SQL Server requirements.
    3. Choose a SQL Server version from the Image drop-down menu.
    4. Use the default machine type and size, or click the Configure virtual machine button to specify the disk types, machine type, and disk sizes for the virtual machine. Click Apply to save the machine settings.
    5. Type a username and password for the database administrator.
      This username and password will also be used for the machine administrator.
    6. Type a username and password for a database user who will have permissions to create objects in the database.
  2. Click Next.
Add cloud storage
If you're creating a GIS Server site or ArcGIS Image Server site that is not filling the function of image hosting server or raster analysis server, you can register a cloud storage location with the site as a data store. This is similar to registering a cloud store in ArcGIS Server Manager. This does not create a data store item in ArcGIS Enterprise. If you require a data store item, do not add the cloud storage location in Cloud Builder; instead, add the data store item after the deployment is created.
If you are creating an ArcGIS Image Server site that is filling the function of image hosting or raster analysis server or if you are creating an ArcGIS Reality Server site, you must create a cloud storage location and register it as part of the site's raster store. The cloud storage location is required to store service data or the data generated as a result of analysis on these sites.
  1. Click the Register a Cloud Data Store from Azure Blob Storage button .
  2. Click the Browse button to choose a folder in an existing Blob storage container, or create a container.
    The Select Blob Container window appears.
  3. Choose an existing storage account from the Storage account drop-down list, or click the Create button to create an account.
  4. From the Authentication type drop-down list, choose the method to use to authenticate connections to the container as follows:
    • UserAssignedIdentity—This option is available if you added a user-assigned managed identity to the machines in the deployment when you configured the site options. If you choose this option, choose one of the identities from the Identity drop-down menu.
    • SASToken—Provide the token in the SAS Token text box. See the Microsoft Azure help for information about SAS tokens for Blob storage containers.
    • ServicePrincipal—If you configured a service principal for the account used for the deployment, provide the tenant ID, client ID, and client secret for the service principal. See the Microsoft Azure help for an explanation of service principals.
      To use the storage location as a raster store or to store service caches, the Azure Storage Blob Data Contributor role must be assigned to the service principal. To use the storage location as a user-managed cloud storage data store, the Azure Storage Blob Data Reader role must be assigned to the service principal.
  5. Choose an existing folder or subfolder in the storage account, or click the Create a container button to define a new container name.
  6. Click OK to close the Select Blob Container window.
  7. Optionally, check the box next to one of the following options to register the cloud storage location for additional uses:
    • Register as raster store—For ArcGIS Image Server sites, checking this box registers the cloud storage location to store output from raster analysis tools. For ArcGIS Reality Server sites, checking this box registers the cloud storage location to store the source images and reality mapping products generated by the Reality Server site.
      For ArcGIS Image Server sites that will function as an image hosting server or raster analytics server, and for ArcGIS Reality Server sites, you must check Register as raster store.
    • Register as cache directory—For GIS Server or ArcGIS Image Server sites, checking this box registers the cloud storage location to build and store caches for the cached image and map services that are published to the site.
  8. Optionally, for GIS Server sites, check the Register as cache directory check box to use the cloud storage location to build and store caches for cached map services (map image layers) that are published to the GIS Server site.
  9. Click Add to register the cloud storage location with the site as a data store.
  10. Click Next to proceed to the Machine Specification settings.
Define machine specifications
You can specify the number of machines in the ArcGIS Server site, the names of the machines in the site, the name of the file server machine, and the specifications for each of the machines.
  1. Click the plus (+) or minus (-) buttons to change the number of machines in the ArcGIS Server site.
  2. Optionally, provide a different name for any of the machines in the deployment.
    All machines in the same deployment should include the same two- or three-character prefix.
  3. To change the type and size of any of the virtual machines, and to add disks to any of the machines, click the Configure virtual machine button .
    To generate Gaussian Splat products on an ArcGIS Reality Server site, choose a virtual machine with GPU (a CPU with a minimum of 64 GB of RAM, NVIDIA GPU with a minimum of 8 GB VRAM, and a compute capability of 7.5 or higher). Also ensure that the machine has enough disk space (≥1 TB SSD).
  4. Click Next to proceed to the License and Credentials settings.
Provide licenses and credentials
Specify the ArcGIS Server license file, a URL context for the site, as well as authentication information for the site and Windows service administrators.
  1. Browse to the location of your ArcGIS Server license file.
    The license must include the server type you chose on the Site Options settings page.
  2. Provide a context name for the ArcGIS Server site's URL.
    The context is the identifier in the URL that routes you to the correct site.
    For example, in the following URL, mygisserver is the context: https://mydeployment.example.com/mygisserver.
  3. Provide a username and password for the site administrator.
    This is the ArcGIS Server primary site administrator account. Keep track of this information, because you will need it when you manage the deployment.
  4. Provide a username and password for the ArcGIS service account, which is the Windows login under which the ArcGIS Server service will run.
  5. Click Next to proceed to the Deployment Options settings.
Specify deployment options
Deployment options include specifying storage locations for deployment artifacts and choosing logging settings.
  1. Choose or create a storage account for the deployment. To create a storage account, do the following:
    1. Provide a name for the storage account.
      Names must be unique. Click Check availability to confirm that the storage account name is unique.
    2. Choose the Azure region where the storage account will reside.
    3. Choose an existing resource group for the storage account, or click the Create button to create one.
    4. Choose the type of redundancy for the storage account: Geo-Redundant, Locally Redundant, or Read-Access Geo-Redundant.
      See Azure Storage redundancy in the Microsoft Azure documentation for a description of each option.
    5. Specify the kind of Azure storage account to use: Storage (a legacy account type), StorageV2 (a basic account type), or BlobStorage (only supports Azure Blob Storage).
    6. Once the storage account is created, click Close.
  2. Optionally, enable monitoring for the site by checking the box next to Enable monitoring using Azure Monitor Log Analytics.
    1. Choose or create a workspace where log analytics will be stored.
    2. Optionally, check the box next to Enable ArcGIS Server logs that can be transferred to Azure Monitor to copy ArcGIS Server log files to Azure Monitor.
      This option is not available for federated ArcGIS Data Pipelines Server, ArcGIS Mission Server, ArcGIS Notebook Server, or ArcGIS Video Server sites.
    3. From the Azure monitoring agent user ID drop-down list, choose the user-assigned managed identity you specified with the site options.
      This information is required to enable Azure Monitor Log Analytics.
  3. Optionally, if you are federating an ArcGIS Notebook Server site, check the Install Docker engine binaries as Docker Runtime check box and provide the path to Docker Engine installation files.
    Confirm that the Docker Engine version you use is supported for the ArcGIS Notebook Server version that you deploy.
    If you do not check Install Docker engine binaries as Docker Runtime and provide Docker Engine installation files, you must complete postdeployment configuration for the ArcGIS Notebook Server site.
  4. If you are federating an ArcGIS Image Server site to use for raster analysis, optionally provide the location of Deep Learning Libraries for ArcGIS Server to perform Deep Learning tasks.
    The installer is available from My Esri. Download the Windows version of the installer.
  5. If you federating an ArcGIS Reality Server site, optionally check the check boxes next to additional following software that you require and provide the path to the software self-extracting installation files:
    • Deep Learning Libraries for ArcGIS Server—Install the Deep Learning Libraries for ArcGIS Server if you will generate Gaussian Splats products.
    • ArcGIS Coordinate Systems Data—Install ArcGIS Coordinate Systems Data if you require supplementary coordinate system files for certain geographic and vertical transformations.
    • ArcGIS Raster Data—This installation is recommended for satellite imagery processing when you don’t have a DEM. ArcGIS Raster Data provides a DEM to use as the default elevation source instead of using the World Elevation service. Because the elevation source data is not fetched over the internet, satellite imagery takes less time to process.
    • DJI Camera Support for ArcGIS Server—Separate installation packages are required for specified DJI thermal cameras.
    These installers are available when you sign into your account in My Esri. Download the Windows versions of these installers.
  6. Optionally, upload a Microsoft PowerShell script that runs on all machines in the deployment, including the new site. To do so, complete the following substeps:
    1. For Script file path in the Post Deployment Script section, provide the location and name of the script file.
      You can paste the path into the text box, or click the options button to browse to the file's location.
    2. For Timeout (in minutes), define the amount of time, in minutes, to allow the script to run.
      If the script does not complete in the time specified, Cloud Builder will end the process. The minimum timeout is five minutes; the maximum is 300 minutes.
    3. If the script requires parameters to run, provide those in the Script parameters text box.
      Syntax for the parameters is -<parameter> <value>.
    4. Keep the default setting for Run script as ArcGIS service account.
      The script runs using the ArcGIS service account that you specified on the Licenses and Credentials page. It is recommended that you use this account because it does not have elevated privileges. If you uncheck this option, the script runs using the local system account on each machine.
    Tip:
    Failure of the postdeployment script does not prevent the new site from being added. If the postdeployment script fails, you'll receive a success message with warnings.
  7. Click Next to view a summary of your settings.
Review the summary and federate the site
Ensure the ArcGIS Server deployment contains what you need, and create and federate the site.
You can also estimate costs for the infrastructure you chose and export the deployment options so you can automate the creation of future federated server sites.
  1. Review the settings in the Summary pane. If you need to change a setting, click Back to return to the relevant page.
    Tip:
    Click Save summary to save the site configuration information to a text file so you can refer to it for information such as usernames or machine names.
  2. Click Generate cost estimate to calculate the approximate cost of the Azure infrastructure you will use in the deployment. When you finish generating the estimate, click Close.
    This estimate does not include data storage costs.
  3. Click Save automation artifacts to export a .zip file containing information and files you can use in automation scripts to re-create this deployment, and do the following:
    1. Browse to a location on the local disk where the archive file will be created and provide a name for the file.
    2. Choose the type of automation format with which you will use the artifacts.
    3. Click Generate to create the file.
  4. When all settings are correct and you have saved the files you need, click Finish to create the ArcGIS Server site.
  5. If you federated an ArcGIS Notebook Server site and you did not check the box to install Docker Engine binaries when you configured the Machine Options settings, you must complete the following steps after the Notebook Server site is created and federated:
    1. Make a Remote Desktop connection to each ArcGIS Notebook Server machine on Azure.
    2. Install and configure Mirantis Container Runtime on each ArcGIS Notebook Server machine.
    3. Copy the ArcGIS images to the ArcGIS Notebook Server machines and run the post installation utility.
      See Configure ArcGIS Notebook Server after installation (Windows containers) for instructions.
  6. If you federated an ArcGIS GeoEvent Server site, open Global Settings in ArcGIS GeoEvent Manager and set the REST Receiver Base URL to the external fully qualified domain name for the site (https://<fqdn>/).
