Register Linux hosts
You can register Linux hosts and Amazon Elastic Compute Cloud (EC2) Linux instances to collect system health and performance metrics, such as CPU speed and available memory.
Each host must have its own installation of ArcGIS Monitor Agent. Once Monitor Agent is registered with Monitor Server, the host is automatically registered for monitoring.
Prerequisites for monitoring
The following prerequisites are necessary for monitoring Linux hosts:
Register Linux hosts for monitoring
You must be assigned the Administrator or Manager role to register components.
  1. Install Monitor Agent on the Linux host that you want to register.
  2. Start a terminal session on the Monitor Agent machine with the ArcGIS Monitor account.
  3. Run the command below, editing the command line parameters to include the root URL to Monitor Server and your username and password.
    ./<Monitor Agent installation location>/arcgis-monitor-agent admin:system:register --server-url <https://monitorserver.example.com:30443/arcgis> --username <user> --password <password>
    The following is an example:
    $HOME/arcgis/monitor/agent/arcgis-monitor-agent admin:system:register --server-url https://monitorserver.example.com:30443/arcgis --username jdoe --password "my password"
    The Monitor Agent instance is registered with Monitor Server. The host machine is automatically registered as a Linux host component and added to the list of monitored components on the Monitoring page.
Once a component is registered, you can configure alert rules and add the component to collections.
Other software component types, such as ArcGIS software and databases, are automatically discovered on the host machine and must be registered individually to enable monitoring.
Observers
The following table describes the observers that are responsible for collecting attribute and metric data:
Observer name
Inventory - Host Linux
This observer scans for changes and manages attribute data and component relationships across the Linux host.
The default interval for this observer is 15 minutes; however, you can configure it to run at longer intervals since changes to the host's configuration are typically infrequent.
Metrics - Host Linux
This observer collects Linux host metric data.
The default interval for this observer is 1 minute to retrieve data frequently. It is recommended that you do not run this observer at longer intervals.
Collected attributes
The subsections below describe the attributes that are collected for Linux hosts.
Host attributes
The following table lists the attributes that are collected for Linux hosts:
Attribute name
Data type
Class
The instance type (virtual or physical)
String
CPU cores logical
The CPU's total number of logical cores
Integer
CPU cores physical
The CPU's total number of physical cores
Integer
CPU name
The CPU name and model information
String
CPU speed
The speed of the host's CPU
Float
Memory total
The host's total amount of memory (RAM)
Float
Network speed
The speed of the network
Integer
Started at
The date and time the host was last started
Datetime
UTC offset
The host's UTC time zone offset
Integer
Version
The software version of the operating system
String
Storage attributes
The following table lists the attribute collected for a Linux host's storage resources:
Attribute name
Data type
Storage total
The size of the volume
Float
Collected metrics
The subsections below describe the metrics that are collected for Linux hosts.
Host metrics
The following table lists the metrics that are collected for Linux hosts:
Metric name
Data type
Unit
Connectivity
The agent's ability to successfully connect to the component.
Float
Percent
CPU Cores Utilized
The number of logical CPU cores in use.
Float
Total
CPU Utilized
The proportion of CPU resources in use.
Values approaching 100 percent may indicate that more resources are needed to handle the workload.
Float
Percent
Memory Available
The total amount of physical memory available.
Float
Gigabytes
Memory Used
The amount of memory in use.
Float
Gigabytes
Memory Utilized
The proportion of memory in use.
Float
Percent
Network Incoming
The rate of network data received.
Float
Megabits/second
Network Incoming Utilized
The proportion of incoming network bandwidth in use.
Float
Percent
Network Outgoing
The rate of network data sent.
Float
Megabits/second
Network Outgoing Utilized
The proportion of outgoing network bandwidth in use.
Float
Percent
Pagefile Available
The total pagefile or swap memory resources available.
Float
Gigabytes
Pagefile Used
The total pagefile or swap memory resources in use.
Float
Gigabytes
Pagefile Utilized
The proportion of pagefile or swap memory resources in use.
Float
Percent
Process metrics
Monitor collects information about the following processes:
  • arcgisserver
  • arcsoc
  • arcgisportal
  • geoeventserver
  • python
  • sqlserver
  • postgres
  • oracle
The following table lists the metrics collected for a Linux host's processes:
Metric name
Data type
Unit
Process CPU Utilized
The proportion of CPU resources in use by the process.
Float
Percent
Process Instances
The total number of process instances that are running.
Float
Total
Process Memory Used
The amount of memory resources in use by the process.
Float
Gigabytes
Process Memory Utilized
The proportion of memory in use by the process.
Float
Percent
Storage metrics
The following table lists the metrics collected for a Linux host's storage resources:
Metric name
Data type
Unit
Storage Capacity Available
The amount of available storage space
Float
Gigabytes
Storage Capacity Used
The amount of storage space in use
Float
Gigabytes
Storage Capacity Utilized
The proportion of storage capacity in use
Float
Percent
Storage Read Rate
The speed at which data is read from the disk
Float
Gigabytes/second
Storage Write Rate
The speed at which data is written to the disk
Float
Gigabytes/second
Default alert rules
The following table lists the default alert rules that are configured for Linux hosts:
Metric name
Aggregation
Operator
Info threshold
Warning threshold
Critical threshold
Samples
Connectivity
Average
Is less than
100
CPU Utilized
Average
Is greater than
75
90
Memory Utilized
Average
Is greater than
75
90
Pagefile Utilized
Average
Is greater than
75
90
Average
Is greater than
75
90
Average
Is greater than
75
90
Average
Is greater than
75
90
The default alert rules in the table above are the rules that are configured for components when Monitor is first deployed. If your Monitor administrator has configured default alert rules for the Monitor deployment, the values for the rules above may vary.
Component relationships
The subsections below describe the relationships that are automatically formed with registered Linux host components.
Storage
The host's inventory observer detects local storage devices attached to the host machine and forms individual relationships between the host component and each storage subcomponent.
If a host component is unregistered in Monitor, all relationships to the host component are removed, and its storage subcomponents are unregistered.
ArcGIS Data Store
The host's inventory observer detects the arcgisdatastore system service running on the host machine. If the detected Data Store instance is configured as a relational data store and registered for monitoring, a relationship is formed between the host component and the ArcGIS Data Store component.
For highly available Data Store deployments with multiple hosts, each host machine and Data Store instance in the deployment must be registered for relationships to be formed between the individual Data Store components and participating host machines.
ArcGIS GeoEvent Server
The host's inventory observer detects the arcgisgeoevent system service running on the host machine. If the detected GeoEvent Server instance is registered for monitoring, a relationship is formed between the host component and the ArcGIS GeoEvent Server component.
GeoEvent Server does not support highly available deployments.
ArcGIS Server
The host's inventory observer detects the arcgisserver system service running on the host machine. If the detected ArcGIS Server instance is registered for monitoring, a relationship is formed between the host component and the ArcGIS Server component.
For highly available ArcGIS Server deployments with multiple hosts, each host machine and ArcGIS Server instance in the deployment must be registered for monitoring for relationships to be formed between the individual host machines and ArcGIS Server components.
Portal for ArcGIS
The host's inventory observer detects the arcgisportal system service running on the host machine. If the detected Portal for ArcGIS instance is registered for monitoring, a relationship is formed between the host component and the Portal for ArcGIS component.
For highly available Portal for ArcGIS deployments with multiple hosts, each host machine and Portal for ArcGIS instance in the deployment must be registered for monitoring for relationships to be formed between the individual host machines and Portal for ArcGIS components.
Microsoft SQL Server
The host's inventory observer detects system services with the mssql-server prefix running on the host machine. If the detected SQL Server instance contains one or more databases that are registered for monitoring, individual relationships are formed between the host component and each registered SQL Server database component.
Oracle
The host's inventory observer detects system services with the oracle prefix running on the host machine. If the detected Oracle instance contains one or more databases that are registered for monitoring, individual relationships are formed between the host component and each registered Oracle database component.
PostgreSQL
The host's inventory observer detects system services with the postgres prefix running on the host machine. If the detected PostgreSQL instance contains one or more databases that are registered for monitoring, individual relationships are formed between the host component and each registered PostgreSQL database component.
