Upgrade ArcGIS Notebook Server
Upgrading ArcGIS Notebook Server provides your organization with the latest features and improvements to the software, while preserving your users' existing notebooks. If you are upgrading your ArcGIS Enterprise deployment, you must also upgrade ArcGIS Notebook Server to the same version.
The ArcGIS Notebook Server setup package detects whether you have an existing installation of a previous version of ArcGIS Notebook Server on your machine. If you do, it can upgrade the software.
You must also install new container images from Esri, providing your users with the appropriate notebook runtimes. The notebook runtimes from the previous version will remain in the site; users can still run notebooks using those runtimes. However, if your users want to use functionality introduced at the latest version, they must update the runtime of their notebooks.
If any notebooks were using custom runtimes, you must rebuild and reregister the custom runtimes on the Windows notebook server and update the runtime settings for the associated notebook items.
Notebook runtimes will be retired following the ArcGIS Enterprise Life Cycle. A notebook runtime will be retired at the same time the associated version of ArcGIS Enterprise is retired. Notebooks should not use retired runtimes and should be updated to a supported runtime.
Upgrading the ArcGIS Enterprise portal will also update the sample notebooks available in the site's gallery.
Multiple-machine ArcGIS Notebook Server sites are supported. If you have a single-machine site and want to expand your ArcGIS Notebook Server site to multiple machines after upgrading, follow the steps to join additional machines to the site after you finish upgrading.
The upgrade process for ArcGIS Notebook Server is an in-place upgrade that does not require uninstalling and reinstalling software. The site will be down during the upgrade process, and users will be unable to access or run notebooks until the upgrade is complete.
Follow the steps below to upgrade ArcGIS Notebook Server.
Prepare to upgrade
Before upgrading, review the following information:
  • You can access all of the necessary files in My Esri before upgrading, including the latest container images.
  • For ArcGIS Notebook Server to function correctly, its version must match the version of the portal with which it's federated.
  • If your notebook server is currently in read-only mode, turn the mode off before beginning the upgrade process.
  • Install a container engine for ArcGIS Notebook Server.
  • Upgrade your ArcGIS Enterprise deployment.
  • Upgrade any other servers, including ArcGIS Notebook Server.
  • Do not uninstall your existing ArcGIS Notebook Server. The ArcGIS Notebook Server setup and command line installers are designed to detect and upgrade an existing installation of ArcGIS Notebook Server components.
  • Do not unfederate your ArcGIS Notebook Server site from the portal or remove its designation as the portal's notebook server at any point during the upgrade process. This adversely impacts the existing notebooks hosted by the portal.
  • You can upgrade ArcGIS Notebook Server using either the setup program or the command line installer. Choose one of these methods to upgrade.
  • Before upgrading, clear the caches of all web browsers used on the ArcGIS Notebook Server machine.
Move the workspace directory
This process is required for single-machine ArcGIS Notebook Server deployments on Linux that have a workspace directory in the notebook server installation directory.
You do not need to perform this step if the workspace directory is already located outside of the Notebook Server installation directory.
  1. Sign in to your ArcGIS Enterprise portal as an administrator and open ArcGIS Notebook Server Manager.
  2. Click the Settings tab.
  3. Click Directories.
  4. Determine whether the current path to the arcgisworkspace directory is in the ArcGIS Notebook Server installation directory.
    <installdir>/arcgis/notebook/directories/arcgisworkspace
    If the arcgisworkspace directory is in the ArcGIS Notebook Server installation directory, you must move the workspace directory to a location outside the installation directory before you can upgrade.
    If the arcgisworkspace directory is not in the ArcGIS Notebook Server installation directory, you do not need to perform the remaining steps in this section.
  5. Click Edit for the arcgisworkspace directory.
  6. Replace the existing directory path value with the new path for the arcgisworkspace directory that is outside the installation directory.
    <installdir>/arcgis/arcgisnotebookserver/directories/arcgisworkspace
  7. Click Save.
  8. Manually copy all of the contents from the previous arcgisworkspace directory to the new arcgisworkspace directory.
Update configuration store location
This process is required for ArcGIS Notebook Server Linux deployments that have a configuration store in the Notebook Server installation directory. See Specify the configuration store location for more information.
You do not have to perform this step if the site uses a cloud-based configuration store or if the configuration store is already located outside of the Notebook Server installation directory.
  3. Click Configuration store.
  4. Check if the configuration store is located under the Notebook Server installation directory.
    Example directory: /installation_directory/arcgis/notebookserver/usr/config-store.
  5. If the configuration store is located under the Notebook Server installation directory, move the configuration to an external location by performing the following steps:
    1. Update the path to the new location.
      Example directory: /installation_directory/arcgisnotebookserver/usr/config-store.
    2. Click Yes to move the current configuration.
    3. Click Save.
Update server directories
This process is required for ArcGIS Notebook Server Linux deployments that have server directories in the Notebook Server installation directory.
You do not have to perform this step if the server directory is already located outside of the Notebook Server installation directory.
  4. Check if the arcgisoutput, arcgisjobs, and arcgissystem directories are under the installation directory.
    /installation_directory/arcgis/notebookserver/usr/directories
  5. If they are located under the installation directory, perform the following steps for each directory.
    1. Click Edit.
    2. Update the path to the new location.
      Example directory: /installation_directory/arcgisnotebookserver/usr/directories/<server directory>.
    3. Click Save.
Update logs directory
This process is required for ArcGIS Notebook Server Linux deployments that have the logs directory in the Notebook Server installation directory.
You do not have to perform this step if the logs directory is already located outside of the Notebook Server installation directory.
  3. Click Logs.
  4. Check if the logs directory is under the installation directory.
  5. If it is under the installation directory, perform the following steps to move it to an external location.
      Example directory: /installation_directory/arcgisnotebookserver/logs.
    2. Click Save.
    3. Manually copy all contents from the old logs directory to the new location.
Back up the deployment
Before you upgrade, it's recommended that you make backups of the deployment.
See Back up and restore ArcGIS Notebook Server for more information.
Upgrade container engine
Upgrade your container engine to a supported version.
On a multi-machine Notebook Server site, perform this step on each machine.
Upgrade using the setup program
Use the setup file to upgrade ArcGIS Notebook Server. After upgrading the setup, you must upgrade the ArcGIS Notebook Server site using the configuration wizard or the upgrade site utility.
If you have a multiple-machine site, follow steps 1 through 3 for one machine, and repeat those steps for each machine in the site.
ArcGIS Notebook Server is designed to detect and upgrade an existing installation of ArcGIS Notebook Server components.
To upgrade using the setup program, complete the following steps:
  1. Run ./Setup from the location where ArcGIS Notebook Server was extracted and follow the prompts to complete the upgrade.
    The setup must be run as the user account that installed the existing ArcGIS Notebook Server. During installation, the setup program identifies the existing installation, and you are prompted to confirm the upgrade. Enter choice y to proceed with the installation.
    This uninstalls the previous version of ArcGIS Notebook Server and installs the upgraded version of ArcGIS Notebook Server.
  2. After the upgrade utility has completed, reauthorize the ArcGIS Notebook Server software. Use the software authorization wizard to complete the authorization.
  3. Open the configuration wizard using the URL listed at the end of upgrading the installation and follow the on-screen instructions to upgrade the site.
  4. For a multiple-machine site, follow steps 1 through 3 for each machine in the site.
Upgrade from the command line
To upgrade from the command line, complete the following steps:
  1. To start the upgrade, run ./Setup from the location where ArcGIS Notebook Server was extracted, with the argument shown in the example below, and follow the prompts to complete the upgrade.
    <untar directory>/Setup -l yes -m silent
  2. After the upgrade utility has completed, reauthorize the ArcGIS Notebook Server software. Run the software authorization with the following syntax to authorize ArcGIS Notebook Server silently:
    <ArcGIS Notebook Server install directory>/tools/authorizeSoftware
    Run the following command to view all options for authorization:
    <ArcGIS Notebook Server install directory>/tools/authorizeSoftware --help
    See the Authorize in a disconnected environment section below for information about authorizing ArcGIS Notebook Server installations in a disconnected environment.
  3. Upgrade the site using the upgradesite command line utility.
    This utility has two parameters:
    • -s—When included in the command, this prompts the utility to run the upgrade. The upgrade won't run without -s. This is intended as a safeguard to ensure you only run the upgrade when you're ready.
    • -h—Displays the help for the tool. When the command is run without -s, the help also displays.
    By default, the upgradesite utility is available at ${HOME}/arcgis/notebookserver/tools/upgradesiteutility/upgradesite.sh.
    Before upgrading, review the preparation information at the beginning of this topic. When you are ready to upgrade, open a command terminal on the machine you're upgrading. Browse to the directory where the utility is located, and run the following command:
    > ./upgradesite.sh -s
    The utility displays progress reports and stops when the upgrade is complete.
  4. For a multiple-machine site, follow steps 1 through 3 for each machine in the site, and continue to the steps in the next section.
Authorize silently
After the upgrade utility has completed, you must reauthorize the ArcGIS Notebook Server software.
You can authorize ArcGIS Notebook Server in a disconnected environment using a provisioning (.prvc) file. During the process, a file is generated for you to send to Esri to complete the process.
  1. At the prompt, run the command provided below after the ArcGIS Notebook Server upgrade is complete:
    <ArcGIS Notebook Server installation directory>/tools/authorizeSoftware -f <full path to the .prvc file> -o <full path to authorization file output>
  2. When the output information file has been created, do one of the following:
    • Browse to the Esri self-service site. Follow the instructions on the screen to upload the authorization information file and download the .ecp authorization file.
    • Send the authorization information file by email to authorize@esri.com. Esri will send an .ecp authorization file back to you in an email.
  3. When you receive the .ecp authorization file using either method above, run the authorizeSoftware script again to process it and complete the server authorization process:
    <ArcGIS Notebook Server installation directory>/tools/authorizeSoftware -f <full path to the .ecp file>
Repeat this workflow for each machine running ArcGIS Notebook Server.
Steps after upgrading
Before the upgraded and reauthorized ArcGIS Notebook Server site can be used, you must run the post installation utility to add the new Docker container images to the site. You must also replace the ArcGIS Web Adaptor instances registered with the site to match the new version.
Run the post installation utility
To run the post installation utility, complete the following steps:
  1. Open a terminal using the ArcGIS Notebook Server installation account.
  2. Change the working directory to the ArcGIS Notebook Server tools folder.
    By default, this path is ${HOME}/arcgis/notebookserver/tools/postInstallUtility.
  3. Optionally, refer to the utility's help by running the following command:
    ./PostInstallUtility.sh -h
  4. ArcGIS Notebook Server requires a container engine to be installed on your machine. Determine whether a container engine is active on your machine by running the following command:
    ./PostInstallUtility.sh -d
    1. If Docker installation requirements are not met, install it now.
  5. Download the runtime images necessary for your setup from My Esri:
    • ArcGIS Notebook Server Python Container Image (Standard)
    • ArcGIS Notebook Server Python Container Image (Advanced)
      The Advanced runtime is only necessary if you have an ArcGIS Notebook Server Advanced license.
  6. Install the runtime image or images by specifying their file paths.
    The image should be zipped in the .tar.gz format.
    Ensure that your machine has at least 75 GB of available disk space.
    If you have an Advanced license, ensure you install both container images, as your users may still need to use the Standard runtime.
    Run the following command:
    ./PostInstallUtility.sh -l <path of .tar.gz Docker image>
Older images are not automatically removed. You must manually update the runtimes associated with each notebook to the newer version before you delete the previous runtime images.
Replace ArcGIS Web Adaptor instances
To replace ArcGIS Web Adaptor instances, complete the following steps:
  1. Unregister the previous instance of ArcGIS Web Adaptor from the site and uninstall it.
    1. Sign in to your ArcGIS Notebook Server Administrator Directory.
    2. Browse to System > Web Adaptors > registered machine.
    3. Click Unregister Web Adaptor.
  2. Install a new instance of ArcGIS Web Adaptor and configure it with ArcGIS Notebook Server.
    Once the deployment upgrade is complete, you can use the functionality introduced at the latest version.
The ArcGIS Notebook Server site is now ready to host ArcGIS Notebooks.
Update the runtimes of existing notebooks and web tools
This process must be performed by each notebook author to upgrade their notebooks and notebook web tools to use the latest notebook runtimes.
  1. Follow the steps in Change a notebook runtime to update the runtime of each notebook item to the latest notebook runtime.
  2. If a notebook is published as a web tool, overwrite the web tool after updating the notebook runtime.
  3. If any notebooks were running custom runtimes, update the custom runtime and update the runtime settings for the associated notebook items.
Remove previous notebook runtimes
Optionally, you can remove previous versions of the ArcGIS Notebook Server runtimes image to free up disk space.
Caution:
Ensure that all existing notebooks have been updated to use the most recent version of the ArcGIS Notebook Server runtimes image before removing previous versions.
  1. Open a command prompt as an administrator.
  2. Enter the following command to see the list of your current images and note the IMAGE ID of the previous version you want to remove.
    docker images -a
  3. Enter the following command to remove the previous runtime version.
    docker image rm <IMAGE ID>
ArcGIS Notebook Server on Windows containers is supported on Windows Server 2022 and Windows Server 2025.
If you have a previous installation of ArcGIS Notebook Server on Windows Server 2019, you must upgrade the operating system prior to upgrading to ArcGIS Notebook Server on Windows containers. Alternatively, you can perform a fresh installation of ArcGIS Notebook Server on Windows Server 2022 or Windows Server 2025 and configure it as the Notebook Server server for your ArcGIS Enterprise deployment.
Upgrade ArcGIS Notebook Server installed on a supported Windows OS
To upgrade ArcGIS Notebook Server on Windows Server 2022 or Windows Server 2025, complete the following steps:
  1. Upgrade your ArcGIS Enterprise deployment.
  2. If you are upgrading from 11.3 or earlier, uninstall ArcGIS Notebook Server samples data either using the ArcGIS Notebook Server Samples Data uninstaller or the command line.
    To uninstall from the command line, run the following command:
    msiexec /x {3A9E12F6-7D4B-4DA2-BA2C-C9D0E900CF94} /qb
  3. Upgrade ArcGIS Notebook Server using the setup program or the command line.
  4. Unregister the previous instance of ArcGIS Web Adaptor from your site.
  5. Uninstall ArcGIS Web Adaptor.
  6. Install a new instance of ArcGIS Web Adaptor and configure it with ArcGIS Notebook Server.
    Ensure the same web adaptor instance name is maintained.
  7. Upgrade your container engine.
  8. Install the most recent ArcGIS Notebook Server Windows container images.
  9. Ensure that each notebook author updates the runtime of their existing notebook items and web tools to the most recent ArcGIS Notebook Server runtime.
    See the Change a notebook runtime section for more information.
    If a notebook is published as a web tool, you must overwrite that web tool after updating the notebook runtime.
    If any notebooks were running custom runtimes, you must rebuild and reregister the custom runtimes on the Windows notebook server and update the runtime settings for the associated notebook items.
    Update the memory and CPU usage settings configured in your runtimes.
  10. Optionally, remove the previous version of the ArcGIS Notebook Server runtimes image to free up disk space.
    Caution:
    Ensure that all existing notebooks have been updated to use the most recent version of the ArcGIS Notebook Server runtime image.
    1. List the images.
      docker images -a
    2. Note the IMAGE ID corresponding to the previous version of the ArcGIS Notebook Server runtime image.
    3. Remove the image.
Upgrade ArcGIS Notebook Server on Windows Server 2022 and migrate from Linux containers to Windows containers
To upgrade ArcGIS Notebook Server on Windows Server 2022 from a previous installation and migrate from Linux containers to Windows containers, complete the following steps:
  7. Once your notebook server has restarted and the administrator site directory is accessible, sign in as an administrative user.
  8. Click Notebooks > Runtimes.
  9. Run Restore Factory Runtimes.
    This will update the Esri notebook runtimes to use the Windows container-based notebook runtime images.
  10. Uninstall Docker Desktop.
  11. Install Mirantis Container Runtime or Docker Engine from binaries.
  12. Install the most recent ArcGIS Notebook Server Windows container images.
    For a multimachine site, repeat steps 3 and 10 through 12 for each machine in your site.
  13. Ensure that each notebook author updates the runtime of their existing notebook items and web tools to the most recent ArcGIS Notebook Server runtime.
  14. Update the memory and CPU usage settings configured in your runtimes.
Upgrade from ArcGIS Notebook Server on Windows Server 2019 with Linux containers to ArcGIS Notebook Server on Windows Server 2022 or Windows Server 2025 with Windows containers
To upgrade to ArcGIS Enterprise on Windows Server 2022 or Windows Server 2025 with ArcGIS Notebook Server on Windows containers from a previous installation on Windows Server 2019 with Linux containers, complete the following steps:
  1. Remove ArcGIS Notebook Server from ArcGIS Enterprise with the following substeps:
    1. Sign in to the ArcGIS Portal Directory administrator location as an administrator for your organization.
      The URL is https://webadaptorhost.domain.com/arcgis/portaladmin, where arcgis is the name of the web adaptor registered with your portal.
    2. Click Federation > Servers.
    3. Choose the notebook server you want to unfederate.
    4. Click Unfederate.
  2. Upgrade your ArcGIS Enterprise deployment.
  3. On the new notebook server machine, set up prerequisite software.
  4. Install ArcGIS Notebook Server.
  5. Configure ArcGIS Notebook Server after installation.
  6. Create a site.
  7. Install and configure ArcGIS Web Adaptor.
  8. For a multimachine site, repeat steps 4 and 5 on each machine and join additional machines to the site.
  9. Configure ArcGIS Notebook Server with the portal.
  10. Ensure that each notebook author updates the runtime of their existing notebook items and web tools to the most recent ArcGIS Notebook Server runtime.
  11. Update the memory and CPU usage settings configured in your runtimes.
Configure a disconnected deployment
If you are configuring ArcGIS Notebook Server in an environment with no internet access or where internet access is prohibited by your organization, see Configure a disconnected deployment.
