Automate reconcile and post operations for sync-enabled branch versioned data
Version administrators can use Python scripting to automate a scheduled reconciliation of replica versions after mobile workers have synchronized edits to data included in branch versioning.
This workflow is applicable for managing replica versions that were created using a sync-enabled web feature layer (feature service) with branch versioned data.
Learn more about working with offline maps with branch versioned data
This workflow is specific to branch versioning. Traditional versioning requires different administration tasks. If you are using traditional versioning, you can also automate reconcile and post operations using Python.
Applicable scenario
The Python example in the next section uses the feature service ArcGIS REST API and ArcPy functions to reconcile and post replica versions with validation attribute rules in place. The following describes when you'd use the code sample and what the sample script does.
This script is an example of a workflow with a specific data setup. Your workflows may not follow this exact data model, but the concepts and script logic may still be used to customize an automated script for your organization. For example, you may not use validation rules, but you can alter the script to remove the evaluation of validation rules. Also, in some cases when using validation rules, you may want to reconcile, run validation, and post each version individually before running the evaluate operation to ensure the validation includes edits made by all other editors.
Prerequisite:
In this example, the data setup is as follows:
The web feature layer must be sync-enabled, contain branch versioned data, and have been published with the version management capability enabled and with the Create a version for each downloaded map option selected, which requires ArcGIS Enterprise 10.8.1 or later.
Replicas were created when a map containing the web feature layer was taken offline.
The credentials provided for the portal user in the script must be for a member of either the default portal Administrator role or a custom role that has the version management privilege granted to it.
In this example, the data also has validation attribute rules applied and the validation server capability enabled. This is not a requirement to work with replica versions, but it provides a way to ensure data integrity.
The following is a summary of steps you will script after you ensure that the prerequisites are met:
Get a list of the replica versions for the feature service (web feature layer) using the
replicasresource in ArcGIS REST API.Use the
versionsInfosresource in ArcGIS REST API to get the properties of the version.Using these properties, create a filter to get only the versions in which the evaluation date is null or the modified date is greater than the last evaluation date (meaning edits have been made since the last evaluation). Append the names of the versions that satisfy the filter to the
listOfVersionsToValidatelist that will be evaluated.For each version in the evaluation list, use the
evaluateoperation in ArcGIS REST API to evaluate the validation attribute rules on the service.If the evaluation is successful with no errors returned, the replica version is ready to reconcile and post. If the evaluation is successful but errors are returned, don't post the edits; generate a message so that the errors can be manually inspected and fixed.
For replica versions that were successfully evaluated with no errors, run the Reconcile Versions tool with the option to post edits.
Run the Reconcile Versions tool with the option to reconcile only (no post) on all replica versions.
Code example
The Python code example below completes the operations listed above. This script includes an option to generate a log file that captures the output of each completed operation and can be viewed after the script completes.
# Import modules
import arcpy, traceback, urllib, json, urllib.request, urllib.parse, os, urllib.error, datetime
# Overwrite the reconcile log output each time the script is run
arcpy.env.overwriteOutput = True
# Script parameters
serviceName = "MyServiceName"
baseURL = "https://MyServer.MyDomain.com"
portalAdmin = "MyAdminUser"
portalAdminPwd = "MyAdmin.Password"
logFileScript = "C:/Logs/validateRecPostScriptLog.txt"
logfileOutputRecPost = 'C:/Logs/reconcile_log.txt'
# Choose to output a log file for the script
outputScriptReport = True
# Define functions
def openURL(url, params=None):
"""This function used to open a URL and returns the json response"""
try:
request_params = {'f':'pjson'}
if params:
request_params.update(params)
encodedParams = urllib.parse.urlencode(request_params)
request = urllib.request.urlopen(url, encodedParams.encode('UTF-8'))
response = request.read()
json_response = json.loads(response)
return json_response
except:
print (traceback.format_exc())
def versionInfo(versionOwner=""):
"""This function queries the versions owned by the versionOwner.
It returns a list of dictionaries."""
vmsUrlinfo = "{}/server/rest/services/{}/VersionManagementServer/versionInfos?&ownerFilter={}&includeHidden=&f=json&token={}".format(baseURL, serviceName, versionOwner, token)
response = openURL(vmsUrlinfo)
if response['success'] == True:
versionsDict = response['versions']
return versionsDict
else:
return("Unable to get version info")
def evaluateUrl(validationUrl, validate_params):
"""This function runs evaluate on the validation server
It returns the json response."""
evalJsonResp = openURL(validationUrl, validate_params)
if evalJsonResp['success'] == False:
return [False, evalJsonResp]
else:
return [True, evalJsonResp]
def generateMessage(msg, print_statement=True):
"""This function generates messages as the script runs. If print_statement
is set to True, print to the screen. If outputScriptReport is set to true,
write the message to the logfile"""
if outputScriptReport == True:
with open(logFileScript, 'a') as log_file:
log_file.write(msg + "\n")
if print_statement == True:
print(msg)
def recPostVersions(versionList, post):
"""This function runs the Reconcile Versions GP tool to reconcile
and optionally post to the feature service"""
if post == True:
postVersion = "POST"
elif post == False:
postVersion = "NO_POST"
# Reconcile and post the replica versions
# This tool is set to abort if there are conflicts and detects conflicts by object
arcpy.management.ReconcileVersions(featureService,
'ALL_VERSIONS',
'sde.DEFAULT',
versionList,
'NO_LOCK_ACQUIRED',
'ABORT_CONFLICTS',
'BY_OBJECT',
'FAVOR_EDIT_VERSION',
postVersion,
'KEEP_VERSION',
logfileOutputRecPost)
generateMessage(arcpy.GetMessages()+"\n")
# Start execution
generateMessage('Starting Validation/Reconcile/Post Automation Script... {:%Y-%b-%d %H:%M:%S}\n'.format(datetime.datetime.now()))
# Sign in to ArcGIS Enterprise
signIntoPortal = arcpy.SignInToPortal(baseURL+"/portal", portalAdmin, portalAdminPwd)
generateMessage("Signed into ArcGIS Enterprise {} as user {}".format(baseURL+"/portal", portalAdmin))
# Get the token returned by the SignIntoPortal arcpy function to use for making REST requests
token = signIntoPortal['token']
# Build the feature service URL
featureService = "{}/server/rest/services/{}/FeatureServer".format(baseURL, serviceName)
# Get a list of the replica versions from the REST endpoint
listOfRepVersions = []
replicaVersionsURL = featureService + "/replicas?returnVersion=true&f=pjson"
repVersionsJson = openURL(replicaVersionsURL, signIntoPortal)
for repVersion in repVersionsJson:
versionName = repVersion['replicaVersion']
listOfRepVersions.append(versionName)
# Create an empty list to append version names to validate
listOfVersionsToValidate = []
# Iterate through each version returned by the versionInfo() function to find
# the versions that need to be validated that are also in the listOfRepVersions list
for version in versionInfo():
print("")
# Parse the version info response, which is a python dictionary/json
# If the version name is sde.DEFAULT, pass since we do not want to evaluate the default version
if version['versionName'] == "sde.DEFAULT":
pass
# If the modifiedDate property is null, pass
elif version['modifiedDate'] == "None":
pass
# If the evaluation date is null, append the version name to the list to listOfVersions to be evaluated
elif version['evaluationDate'] == None:
if version['versionName'] in listOfRepVersions:
listOfVersionsToValidate.append(version['versionName'])
# If the evaluation date is not null, but it has been modifed since the last evaluation, add it to the list to be validated
elif version['evaluationDate'] != None and version['modifiedDate'] > version['evaluationDate']:
# If none of these conditions are met
else:
generateMessage("Version {} will not be validated.".format(version['versionName']))
# Validate versions
generateMessage('The following versions will be validated: {}\n'.format(listOfVersionsToValidate))
# Create lists to contain versions where the validation passed or failed
failEval = []
passEval = []
# For each version in the list of versions, build the json request needed to validate
for i in listOfVersionsToValidate:
validate_params = { "gdbVersion": i,
"sessionId": "",
"evaluationArea": "",
"changesInVersion": "true",
"selection": "",
"evaluationType": '["validationRules"]',
"returnEdits": "true",
"async": "false",
"f": "pjson",
"token": token
# Build the REST URL used to validate the service
validationUrl = baseURL + "/server/rest/services/"+ serviceName +"/ValidationServer/evaluate"
# Call the evalVersion() function to validate the version
evalVersion = evaluateUrl(validationUrl, validate_params)
# If the evaluate failed, append to the failEval list
if evalVersion[0] == False:
generateMessage("Evalution of version {} failed".format(i))
generateMessage(str(evalVersion[1]))
failEval.append(i)
# If the evaluate passed, check to see if errors were returned
elif evalVersion[0] == True:
# If errors are returned, only reconcile this version
if evalVersion[1]['errorsIdentified'] != 0:
generateMessage("{} Errors were identified in version {}.\nThe version will be reconciled but will not be posted.\n".format((str(evalVersion[1]['errorsIdentified'])),i))
generateMessage(str(evalVersion[1]), False)
# If errors were not found this version can be posted
else:
generateMessage("Evaluation of version {} passed with no errors identified.\nThis version will be reconciled and posted.\n".format(i))
passEval.append(i)
# The versions that passed validation should be reconciled/posted
generateMessage('\nThe following versions passed validation and will be reconciled and posted: {}\n'.format(passEval))
# Run recPostVersions on the list of versions that passed evaluation with the option to post
recPostVersions(passEval, True)
# Open the reconcile log file and append the results to our report
with open(logfileOutputRecPost, 'r') as openRecLog:
generateMessage(openRecLog.read(), False)
# Run recPostVersions with the option to reconcile all replica versions, no post
recPostVersions(listOfRepVersions, False)
# Script execution complete
generateMessage('Validate, Reconcile, & Post Script Complete.')
