Initialize a custom diagram layer definition on a template
Use the Create Diagram Layer Definition tool to initialize a custom diagram layer definition on a template.
This tool must be used in ArcGIS Pro, as it takes an input network layer referenced from an active map and prepares the network diagram composite layer for all diagrams that are based on the input template according to the layers in the input active map. After running with its default settings, each network diagram based on the input template displays the following:
One layer for each utility network or trace network layer representing network features in the active map specified as the input.
A set of extra layers that can be relevant or not to your template dedicated to the representation of the following types of network elements:
Connectivity associations and structural attachments represented as polylines in diagrams
Container polygon features, line features, and edge objects that can be transformed as points in diagrams
Container point features and container junction objects that can be transformed as polygons in diagrams
Junction objects represented as points in diagrams
Edge objects represented as polylines in diagrams
One layer, Reduction Edges, dedicated to the representation of aggregated network elements between two junctions.
Two layers, Virtual Connectivity and Inferred Connectivity, representing implicit connections created during the generation of diagrams representing portions of telecom domain networks.
The tool systematically discards layers present in the input map that are out of the utility network or trace network.
Regarding the settings initialized for the layers under the diagram layer, you will note the following:
Each layer representing network features in the network map exists under the diagram layer with identical settings (the same layers and labeling properties, visibility, query filters, and so on).
This is true except for network layers present with joins in the network map even if the layer or labeling settings are not based on a joined field. In this case, the tool systematically initializes basic layer settings for the corresponding layer under the diagram layer. If you want the corresponding layer under the diagram layer to keep identical settings as in the network map, you must remove all joins on the layer prior to running the Create Diagram Layer Definition tool.
In addition, if layers are in subtype group layers in the network map, those subtype group layers are kept under the diagram layer. This is true for the subtype group layers you can set up using the Add Preset > Subtype Group Layer command on the Map tab, but it is not true for standard group layers. When the layers in the network map are standard group layers, those groups are dissolved on the built network diagram layer. There is no standard group layer under a composite layer; each layer displays at the same level in that case.
Any layer representing container junction objects, junction objects, and edge objects is created as a standard layer under the diagram layer by default, even if it exists in the input network map as a subtype group table.
You must consider the specific Subtype Layer option in the Create Diagram Layer Definition tool for each nonspatial objects layer to decide whether you want to represent them as subtype group layers on the diagram side.
The order of the layers under the network diagram layer is the same as the order of the layers in the network map.
With the above in mind, it's recommended that you create a specific map to use as input for the Create Diagram Layer Definition tool. Since working with map services that reference a large number of layers impacts performance, if you intend to access your network diagrams through a map service, think about the network features and network objects that give meaning to your diagram template when building this specific map. For example, there are some Remove Feature rules configured on your template to discard all the transmission network features. In this case, you don't want layers under the network diagram layer to represent transmission diagram features. To prevent the creation of these layers, ensure that you have no layer referencing transmission features in the map you use as input for the Create Diagram Layer Definition tool.
The following steps describe how to configure a specific input map and set up the Create Diagram Layer Definition tool to initialize a custom diagram layer definition on a template.
Requirements and prerequisites
The requirements and prerequisites when initializing a diagram layer definition on a template are as follows:
This operation must be run from either a utility network or trace network in a file or mobile geodatabase, or a database connection to the utility network or trace network in an enterprise geodatabase. When working with a utility network or trace network in an enterprise geodatabase, you can't work from a service.
For the case of a database connection to a utility network or trace network in an enterprise geodatabase, you must connect using the credentials of the database network owner; that is, using the database utility network owner or database trace network owner credentials.
When working with a database connection to a utility network or trace network in an enterprise geodatabase, you must sign in to your ArcGIS Enterprise portal using the credentials of the portal network owner; that is, using the portal utility network owner or portal trace network owner credentials.
Initialize a custom diagram layer definition on your template
To initialize a custom diagram layer definition on a template, complete the following steps:
Start ArcGIS Pro.
When working with a utility network or trace network in an enterprise geodatabase, sign in to your ArcGIS Enterprise portal using the credentials of the portal network owner—that is, using the portal utility network owner or portal trace network owner credentials.
Load a project or create one.
Depending on the geodatabase you want to work with, do one of the following:
When working with a utility network or trace network in a file or mobile geodatabase, add the file or mobile geodatabase to the project.
When working with a utility network or trace network in an enterprise geodatabase, add the database connection file to the project or create one.
Caution:
Make sure the utility network or trace network is registered as branch versioned and you are connecting using the credentials of the database network owner—that is, using the database utility network owner or database trace network owner credentials.
Activate a map that already references your network data through a database connection, a file or mobile geodatabase, or create a map by doing one of the following:
Initialize a custom diagram layer definition on your template using simple layers to display all network source classes:
In the Catalog pane, on the Project tab, under Databases, expand your geodatabase item and right-click the utility network or trace network.
Click Add To A New Map.
If you are prompted to add all source classes that participate in the utility network or trace network to the map, click Yes.
Initialize a custom diagram layer definition on your template using preset subtype group layers:
Create a map and click your template.
On the Map tab, click Add Preset and click Subtype Group Layer.
Browse to your geodatabase, select all the network source classes under the network dataset, and click OK.
In the Catalog pane, on the Project tab, under Databases, expand your geodatabase item and drag the utility network or trace network to the active map.
You can also combine simple layers for some source classes and preset subtype group layers for others.
Make a copy of the map. Then, open and activate this map copy.
This copy will be used as input for the Create Diagram Layer Definition tool.
For each layer in this map, verify what the layer or subtype layer represents and remove those layers and subtype layers that are not relevant to your diagram template. For example, if your template is configured to expand all container point features of the network, remove the layers that represent point distribution assemblies or structure junctions.
Verify that there is no join on layers. Remove the join for those with one.
For each layer remaining in the map, optionally do the following:
Split layers according to existing filters.
Change the name of the layer.
Set the layer appearance options.
Set the layer labeling options.
Reorder the layers or subtypes under subtype group layers in the map.
If there are query filters set on one or more layers in the map to hide specific network features, optionally remove these filters so those features can be represented in generated diagrams:
In the Contents pane, right-click the layer and click Properties.
On the Layer Properties dialog box, click the Definition Query tab.
Click Clear Expression at the bottom of the tab or modify the query expression to filter out the features you want to see in your diagrams.
Click OK.
Search for Create Diagram Layer Definition in the Geoprocessing pane search box and open the tool.
Click the Input Network field drop-down arrow and select the network layer referenced in the active map.
In the Input Diagram Template list, select the template for which you want to create the diagram layer definition.
Ensure the Overwrite all layers option is checked.
Expand the Additional Sublayers section and optionally do the following:
Uncheck System Junctions if your diagrams will not contain system junctions.
Keep Connectivity Associations checked if your template is configured to represent connectivity associations, in other words, if it is configured to run an Add Connectivity Associations rule or a Trace rule.
Keep Structural Attachments selected if your template is configured to represent structural attachment associations, in other words, if it is configured to run an Add Structural Attachments rule.
Keep the Schematic Edges option checked in the following situations:
Your template is configured to run Reduce Junction or Collapse Container rules
Your template is set up to run a Trace rule based on the Circuit trace type on a telecom domain network.
In the Points for edges reduced as junctions and collapsed polygons list, identify each network source layer that represents line features or edge objects. If there is no Reduce Edge rule configured on your template to reduce the related diagram features, remove this layer. Identify each network source layer that represents container polygon features. If there is no Collapse Container rule configured on your template to collapse the related diagram features, remove this layer.
In the Polygons for containers list, identify each network source layer that represents container point features or container junction objects. If there is a Collapse Container rule configured on your template to collapse the related diagram features or a Remove Feature rule to remove them, remove this layer.
In the Points for junction objects list, identify each network source layer that represents junction objects. If there is a Collapse Container rule configured on your template to collapse the related diagram features or a Remove Feature rule to remove them, remove this layer.
In the Polylines for edge objects list, identify each network source layer that represents edge objects. If there is a Collapse Container rule configured on your template to collapse the related diagram features or a Remove Feature rule to remove them, remove this layer.
For each layer retained in steps 15e through 15h above, check the Subtype Layer check box if you want the related layer to be created using preset subtype group layers. Otherwise, the layer will use simple layer representation categorized per subtype.
Click Run.
Verify diagram layer definition initialization
To verify that the diagram layer definition is initialized the way you want, on the modified template, complete the following steps:
Select a set of network elements from the layers and object tables referenced in the active map.
Generate a temporary diagram based on your template.
In the Manage group on the Network Diagram tab, click All Layers so all layers currently set on the related diagram template are present in the Contents pane under the network diagram layer, even those not used.
Verify that these layers display in the same manner as the network features in the active geographic map.
If there is anything on this network diagram layer that is not suitable, you may have to do one of the following:
Reinitialize the diagram layer definition on your template by completing steps 7 through 15 above again. This involves refining the layers in the map you built during steps 7 through 9 and running the Create Diagram Layer Definition tool for your template using this map.
Edit the layers under the newly generated network diagram layer and import those new settings as a new diagram layer definition on the template.
Caution:
When consuming the network through a service, an additional step is required to get the modified diagram template fully operational on the network service: you must connect to your ArcGIS Server, and stop and restart this service.
Important:
When consuming the network through a service, you must consider the layer definition currently initialized on your template regarding the other templates and think whether it can be shared with other templates to limit the number of various diagram layer definition across your diagram templates.
