Frequently asked questions
Available with ArcGIS Pro Standard and Data Reviewer licenses.
What is the difference between Topology Rules and Data Reviewer?
Is there a limit to the number of features that can be validated using automated checks?
What is the difference between Attribute Rules and Data Reviewer?
How can I reuse my Reviewer batch jobs to create attribute rules?
What types of features are supported by Data Reviewer checks?
What is ArcGIS Data Reviewer?
ArcGIS Data Reviewer is an extension to ArcGIS Pro and ArcGIS Enterprise that automates, simplifies, standardizes, and improves quality control workflows to enable delivery of geospatial data you can trust. Lower data management costs reduce risk in decision-making through this unified set of capabilities that support detection, management, and reporting of errors in your data.
How is Data Reviewer licensed?
Data Reviewer is an integrated extension to ArcGIS Pro and ArcGIS Enterprise that supports quality control workflows across multiple industries and data types. In ArcGIS Pro, Data Reviewer is available for all license levels as an add-on to a Named User, Single Use, or Concurrent Use license type.
Learn more about ArcGIS Pro license types
In ArcGIS Enterprise, Data Reviewer is available for Standard and Advanced editions of ArcGIS GIS Server. This extension is a CPU-based license that is required for each GIS Server that is federated with the organization.
Learn more about ArcGIS GIS Server capabilities and extensions
Geodatabase topology and Data Reviewer are both capabilities that support the creation and management of high-quality data. There are advantages to using both capabilities in data management workflows. A key difference between these capabilities is the aspects of a feature's quality that can be assessed. Data Reviewer checks are used to assess multiple aspects of a feature's quality. This includes the ability to identify data quality issues related to a feature's integrity, attribution, as well as a feature's spatial relationship to other features. For a complete list of Data Reviewer checks, review the ArcGIS Data Reviewer Checks poster.
A geodatabase topology is used to enforce a spatial relationship between features in a geodatabase. This includes assessment of spatial relationships such as overlaps, intersections, and gaps. For a complete list of topology rules, review the ArcGIS Geodatabase Topology Rules poster.
Learn more about the components that define GIS data quality
No, there is no limit to the number of features that can be validated using automated checks.
The more features and quality checks there are, the longer it may take to validate. In extreme cases, the resulting errors from the validation process could exceed the number of features in the database.
Data Reviewer provides a library of no-code, ready-to-use checks based on attribute rule workflows. These checks can identify common errors in GIS data by filling out two to three parameters with just a few clicks. Additionally, Data Reviewer facilitates error life cycle management by highlighting the specific feature that is causing the error and tracking both the error and the review process. By comparison, ArcGIS Arcade-based attribute rules can provide more precise control in identifying errors but require familiarity with coding Arcade scripts.
Learn more about Data Reviewer checks
Why are some error features removed while others remain in the Error Inspector after I fix the errors in my data?
Data Reviewer attribute rule error features remain in the Error Inspector pane after they are fixed for traceability and error life cycle management. Traceability allows you to track and manage errors throughout the data validation process, ensuring that errors have been properly addressed. The error management process records which errors were identified and fixed, allowing you to track the history of data quality improvements.
The only error features that are removed are Arcade-based attribute validation rules. These errors only persist if the error condition they search for is still present. Once an error is fixed and the validation rules are re-evaluated, the Arcade-based validation errors are removed.
Learn more about the Data Reviewer error life cycle management
ArcMap-created Reviewer batch jobs are no longer supported. To convert existing batch jobs into attribute rules, you can use the Convert batch jobs to attribute rules tool to export batch jobs to validation attribute rules to automate the migration of data validation workflows to ArcGIS Pro and ArcGIS Enterprise.
Legacy:
Data quality workflows and related tools based on the Reviewer workspace have been deprecated and are no longer available. It is recommended that you migrate to ArcGIS Data Reviewer attribute rules-based workflows.
Data Reviewer checks support the following data types:
Point Features
Line Features
Polygon Features
Standalone Tables
Data Reviewer-based constraint and validation rules support these feature types in file, mobile, and feature services published from branch versioned enterprise geodatabases. Constraint attribute rules support these feature types in traditional versioned enterprise geodatabases.
Can I remove the Validation status field from my data?
No. Once a validation attribute rule has been authored on a dataset, the Validation status field is automatically generated in each feature class where the validation rule has been authored. This field cannot be deleted, even if you delete all other rules.
