Work with color schemes
Color schemes are ranges of color that are applied to various types of symbols and their components. With feature layer symbology, there are four main types of color schemes: continuous, discrete, random, and multipart. A fifth color scheme type—the bivariate color scheme—is used exclusively with bivariate colors symbology. To learn about the differences between these types, see Color schemes.
Raster and imagery data use different symbology types, and their use of color schemes differs from feature layers. To adjust the color scheme of a raster or image, see Change the symbology of imagery.
Apply a color scheme to a feature layer
The color scheme that is applied to a layer can be changed in the Symbology pane for the layer. The list of color schemes is filtered depending on the type of layer being symbolized. You can pick a new color scheme from the list, or search for a color scheme, or edit a color scheme to create a new one.
The following types of feature symbology support the use of color schemes:
Color schemes are also used when you vary the symbology of a feature layer by color. See Vary symbology by color.
To change the color scheme used to symbolize a layer, complete the following steps:
Select the feature layer in the Contents pane.
On the Feature Layer tab, in the Drawing group, click the Symbology button
.In the Symbology pane, on the Primary symbology tab
, click the Color scheme drop-down menu.Choose a color scheme from the list of available schemes. Hover over a color scheme to see its name, or check Show names to show the descriptive names of all the color schemes.
The list includes color schemes in project styles that are suitable for the primary symbology type of the feature layer. Optionally, check Show all to list all available color schemes in the project styles instead.
Click a color scheme to apply it immediately to the symbol classes.
If a selection of symbol classes exists, the color scheme is applied only to the selected classes.
To find additional color schemes or to search for color schemes by a keyword, click More color schemes at the bottom of the drop-down list.
On the Choose a color scheme dialog box, use the drop-down menu in the upper-right corner to focus the search to only Project styles or to All styles.
Project styles are the styles the project is connected to and can include system styles, custom styles, and your Favorites style. All styles are all the project styles and all the system styles, whether they are connected to the project or not.
At the top of the Choose a color scheme dialog box, type a search term to find color schemes.
The Name, Category, and Tags of color scheme style items are searched. This information is shown in a tooltip for each color scheme.
Choose a color scheme from the dialog box and click OK, or click Cancel to close the dialog box without applying a color scheme.
Color schemes for special uses
The best color scheme for your symbology depends on the audience of your map. In some cases, the gradation of a color scheme is well defined, such as with elevation or meteorological data. In other cases, a measured approach to selecting colors is required, as is customary of the developmental process of cartography.
The color model of a map can be changed to use either the RGB or CMYK color model. To support both models, the ColorBrewer Schemes (RGB) and ColorBrewer Schemes (CMYK) system styles provide an assortment of sequential, divergent, and qualitative color schemes.
Many of the color schemes included in the ColorBrewer Schemes style are color blind safe. You can search for the color blind safe tag when choosing color schemes.
In the ArcGIS Colors system style, the Inferno, Magma, Plasma, and Viridis color schemes are scientifically designed to minimize data misinterpretations caused by color. These color schemes can be used with imagery, LAS symbology, unclassed, and graduated colors symbology.
Edit a color scheme
To modify or customize a color scheme, use the Color Scheme Editor window, where you can change the color scheme type, save the color scheme to a style, or modify additional settings.
Tip:
When a color scheme is edited, a temporary version is created and added to the Color scheme drop-down menu while the pane is active. Temporary versions are deleted when the Symbology pane is closed or the primary symbology changes. To retain them for reuse, you can save them to a style. On the Color Scheme Editor dialog box, click Save to a style. Type a name and, optionally, a category and tags and choose a style to save to. Save to your Favorites style to have the color scheme available in all your projects.
To modify a color scheme, complete the following steps:
, click the Color scheme drop-down menu.Click Color scheme properties to open the Color Scheme Editor dialog box.
See the sections below for detailed information about editing each type of color scheme.
Once the color scheme has been modified, optionally click Save to a style to save the new color scheme as a style item for reuse.
Click OK to close the Color Scheme Editor dialog box and apply the color scheme to the feature layer, or click Cancel to close the dialog box without applying the scheme to the layer.
The options available in the color scheme editor depend on the color scheme type. The color scheme type is shown at the bottom of the Color Scheme Editor dialog box. The color scheme type options are detailed below.
Continuous color schemes
Continuous color schemes use color blending techniques between two color stops. The segments between color stops determine the appearance of a color scheme. The selected segment is shown by a black bar to the left of the selected color stop. In each color scheme segment, the Algorithm option determines the path traversed through the color space between two color stops (HSV or CIE Lab), and Polar Direction determines the direction traversed around the color wheel for variations in hue (shortest path or longest path).
You can hover over a color stop to view its approximate position, algorithm, and transparency values. To edit the color stop, click it and modify the values under Settings.
Click the Add color button
to add a color stop to the color scheme, or click the Remove color button
to remove the selected color stop. Click the Reverse color scheme button
to reverse the order of all the stops. Check the Evenly distribute color stops check box to arrange all stops evenly along the length of the color scheme.
Tip:
Add a transparent color stop to a continuous color scheme to create a ramp that fades away to gradually show more map content below it. This is a good way to map phenomena with imprecise or unknown boundaries. To ensure a gradual fading effect, set the fully transparent color stop to the identical color values as the nearest color, but with transparency set to 100. This will ensure better results than using an unrelated base color set to fully transparent.
For example, if the scheme goes from blue (RGB 0, 120, 240 with 0% transparency) to transparent, set the second color stop to RGB 0, 120, 240 with 100% transparency.
Discrete color schemes
to add a color block to the color scheme, or click the Remove color button
to remove the selected color block.
Each color block comprises the same percent of the scheme. Click the Reverse color scheme button
to reverse the order of the blocks. Optionally, drag color blocks to the left or right to manually rearrange the order of the blocks.
Random color schemes
Random color schemes are regenerated each time they are opened or applied. In the Color Scheme Editor, the preview shows only the first 14 randomly generated colors, but the scheme generates a random color for every feature in the dataset.
If you are not satisfied with the set of randomly generated colors, you can regenerate the scheme. Click the Regenerate button
to manually form a new arrangement of random interim colors between the minimum and maximum values. This updates the seed value. If you find an arrangement you want to return to, note the seed value and reenter it when you apply the scheme.
Dive in:
To change the minimum and maximum colors, choose colors from the color picker or click More colors. Regardless of the native color mode of the selected color, colors are converted to the HSV color space, and those respective values are used as the limits for all interim colors generated along the scheme.
Transparency does not vary along the length of the random color scheme; it is a single value applied to the entire scheme. The default transparency setting is 0 percent, which is fully opaque. Transparency is indicated visually in the scheme when an underlying gray checkerboard shows through.
Multipart color schemes
When you create a multipart color scheme, the editor window is empty. To get started, choose a subscheme type from the Sub-schemes drop-down menu, and click Add to add it to the subschemes list. Click Remove
to remove it from the list. You can reorder subschemes or add new subschemes at any time.
When a multipart color scheme contains two or more subschemes, the color scheme preview labels show the percentage weight of each subscheme. Drag Change sub-scheme weight
left or right to change the percentages between two subschemes.
Click Edit
to modify the subscheme's color settings. Click Back
to return to the whole scheme.
Dive in:
Continuous subschemes always contain two color stops, one at each end of the subscheme. The Add color button, Remove color button, and Position spinner control are not present in the continuous subscheme component. Instead, a multipart scheme that contains only continuous subschemes in which each end color is equal to the subsequent start color is converted to a continuous scheme when it is reopened.
Bivariate color schemes
To change a color in a bivariate color scheme, in the Color Scheme Editor window, click a color cell. The chosen cell is indicated by a gray border. Under Settings, you can change the color or transparency value of that cell. You can also click the Rotate button
to change the orientation of the color scheme 90 degrees, or click the Reset button
to return the color scheme to its original settings.
Create a custom color scheme
A wide selection of ready-made color schemes is available with ArcGIS Pro. You can also create custom color schemes by modifying existing ones or constructing them from scratch.
All color schemes are managed in styles. A color scheme can be created, edited, and saved to a personal style, such as your Favorites style, for later use. To learn how to create a color scheme, see Create symbols and style items in a style.
