Unique values
Unique values symbology symbolizes feature layers into qualitative categories. Examples include habitat types, planning zones, voting preferences, and soil classifications.
Unique value symbology can be based on one or more attribute fields in the dataset, or you can write an Arcade expression to generate values on which to symbolize.
Tip:
If you have access to a style that has symbols named to match the symbol class values, you can use the Match Layer Symbology To A Style geoprocessing tool to apply predefined unique values symbology to the layer.
To symbolize a feature layer with unique values symbology, you work with the Symbology pane. The Primary symbology tab
of the Symbology pane has two subtabs to establish unique values symbology:
The Classes tab is where you manage the symbol, its patch shape, the values, the descriptive labels, and grouping of the symbol classes.
The Scales tab is where you specify the scale ranges in which each symbol class draws.
To symbolize using unique values, complete the following steps:
To open the Symbology pane, select a feature layer in the Contents pane of the map or scene, and on the Feature Layer tab, in the Drawing group, click Symbology
.In the Symbology pane, on the Primary symbology tab
, under the Primary Symbology heading, choose Unique Values from the list.On the Field 1 menu, choose a field on which to symbolize.
Optionally, use an expression instead of values directly from a field. Click the expression button
to open the Expression Builder dialog box. Write an expression and click Verify
to validate it.Optionally, click Add Field to add symbol permutations.
You can use up to three symbology fields to establish the symbol classes. Only the first field can use an expression.
Optionally, choose a color scheme from the Color scheme drop-down list.
Depending on the number of unique values, the color schemes from project styles are filtered so that only relevant color schemes are presented to you. For example, if you have only five unique values, you see quantitative color schemes showing five colors. In addition, you can also choose from random color schemes. Check the Show all check box to see all available color schemes. Color schemes stored in your Favorites style or custom styles appear in this list, regardless of their type or number of colors. Click Color scheme properties to modify a scheme.
The colors in the color scheme are applied to all symbol classes by default. To apply the color scheme to a subset of symbol classes only, select those classes by highlighting them in the table on the Classes tab in the Symbology pane. (Press and hold Shift or Ctrl while clicking in the Value or Label columns to select symbol classes.) With symbol class rows selected, choose a color scheme from the Color scheme drop-down list at the top of the Symbology pane.
The number of selected rows is reported at the top of the table of symbol classes on the Classes tab. Click Clear
to deselect symbol class rows as necessary.
Set the color scheme target
If you are symbolizing polygons, click the Color scheme options button
to choose the target for the color scheme. You can apply the colors to the polygon fills, outlines, or both.
When you change the color scheme target, the other symbol layers of the polygons symbolizing each symbol class are not updated. For example, when you set the color scheme target to Apply to outline, the fill symbol layers are not updated, and setting it to Apply to fill does not alter the outlines of the polygons. This is to ensure that customized symbology is not lost. Symbol layers that are color locked are not updated by changes to the color scheme, regardless of the color scheme target setting.
To update all symbol layers to match the color scheme target setting, click the More drop-down menu and click Regenerate all symbols.
Color scheme target |
Result |
Result after regenerating symbols |
Apply to fill |
The color scheme is applied to the fills (fill symbol layers) of the polygon symbols. |
The color scheme is applied to the fills of the polygon symbols. Polygon outlines (stroke symbol layers) are solid gray lines.
Apply to outline |
The color scheme is applied to the outlines (stroke symbol layers) of the polygon symbols. |
The color scheme is applied to the outlines of the polygons. Polygon fills are fully transparent.
Apply to fill and outline |
The color scheme is applied to the fills and outlines (fill symbol layers and stroke symbol layers) of the polygon symbols. |
The color scheme is applied to the outlines of the polygons. The color scheme is applied to the fills of the polygons as hatches.
Control the visibility of symbol classes
You can control the visibility of each unique value symbol class independently using check boxes in the Symbology pane or in the Contents pane. The visibility is matched by legends on a layout so that only visible symbol classes appear in the legend.
Caution:
A layer cannot be shared to a web map if one or more symbol classes are not visible. Prior to sharing, either make all symbol classes visible , or remove the symbol classes you do not want to display.
Video length: 0:46
This video was created with ArcGIS Pro 3.4.
Control symbol class visibility from the Symbology pane
To turn symbol classes on or off from the Symbology pane, follow these steps:
, on the Classes subtab, use the check boxes next to each symbol class to control whether it is drawn on the map.Symbol classes that are turned off are still listed in the expanded view of the layer in the Contents pane.
Optionally, control the visibility of all symbol classes simultaneously by checking the box in the heading of the table.
A square in the heading check box indicates that some symbol classes are on and some are off.
Control symbol class visibility from the Contents pane
To control the symbol class visibility from the Contents pane, you must first enable the layer to show the check boxes there, as outlined in the following steps:
, on the Classes subtab, click More to open the menu.On the More menu, check Use the Contents pane for class visibility.
Check boxes appear next to each unique value symbol class in the Contents pane for the selected layer.
Use the check boxes to control the visibility of each symbol class.
The check boxes in the Contents pane are in sync with those on the Symbology tab, so you can use either set to control the visibility.
You cannot control the visibility of symbol classes from the Contents pane if the layer is also classified by size categories or by color categories and the extended legend is shown. In this situation, symbol class visibility can be managed from the Symbology pane only.
Modify unique values symbology
You make most changes to unique value symbology from the Primary symbology tab of the Symbology pane
. This tab includes the Classes and Scales subtabs, its subtab tools, the More menu, and an interactive table that shows unique values with their corresponding symbols and headings.
To organize unique value symbology, you can use the following tools:
Click Add unlisted values
to open a table in the Select values to add subpane and add symbol classes. This table lists all values not currently symbolized. Click Options and click Add new value
to type a new value. When you add new values, they are added with the symbol of the <all other values> symbol class.Tip:
If you are working with complex symbols, you can use this as a way to symbolize many symbol classes at once with a symbol and make changes to each class as necessary.
Drag a symbol class row to a new position in the table or click Move selected values up
or Move selected values down
to change the order of the symbol classes.On the Scales tab, you can add alternate symbols to further refine the appearance of features within certain scale ranges.
To set masking per feature, click the Advanced symbology options tab
and expand Feature level masking.
In the unique value symbol classes table, you can do the following:
Click a symbol in the Symbol column of the table to open the Format Symbol pane and modify the symbol or choose a different symbol.
For line and polygon features, click the drop-down arrow next to the symbol to set the symbol's legend patch. To change multiple patches at the same time, hold Shift or Ctrl while clicking the symbols, right-click the selection, and select Update legend patch to choose the patch shape.
Right-click the Value or Label heading and click Sort Ascending
or Sort Descending
to sort values. The symbol class order is reflected in the Contents pane and also in legends on layouts.Click the label in the Label column and type a new label. Click another column or press Enter to apply the label.
Right-click a symbol class and click Remove
to remove the symbol class. No data is deleted, but the associated features do not draw. Note that they may still be symbolized by an All other values group at the bottom of the table that collectively draws all values that are not otherwise symbolized by a symbol class.Right-click the All other values symbol class and click Remove
, or click More and uncheck Include all other values so that only features participating in symbol classes are drawn. If the symbol class is removed from the legend, the total feature count for all other values is listed at the bottom of the pane.
From the More drop-down menu, you can perform the following tasks:
Click Show count to show the total feature count of each symbol class. To update the count, click the More drop-down menu again and choose Refresh count.
Click Show description to add the Description column to the unique values table. You can double-click a description cell to edit or update the description on the pop-up dialog box. Click Update to apply the description. The description appears with its symbol class in layout legends.
Click Reverse symbol order to reverse the size of the symbols in your feature layer.
Click Format all symbols to make changes to all symbols. To change the basic properties of more than one symbol at a time, press Shift or Ctrl while clicking the symbols to make a selection. Right-click the selection, and choose Format symbols.
Click Regenerate all symbols to reset each symbol class to its default symbol based on current symbology parameters. You may want to do this after you've changed the color scheme target or to discard individual symbol edits and revert to a default state.
Click Remove all to remove all symbol class values from the symbology.
Organize symbol classes into groups and headings
When there are a lot of symbol classes in a layer, it may help to group values together and to arrange symbol classes under headings.
Use grouping to make a combined symbol class from more than one unique value. For example, a roads layer may have the following road type values with five corresponding symbol classes:
Road type value |
Symbol class label |
1 |
Divided highways |
2 |
Highways |
3 |
Major roads |
5 |
Minor roads |
7 |
Streets |
You could simplify this layer to show just three classes by grouping data values as follows:
Road type value |
1, 2 |
Highways |
3 |
Major roads |
5,7 |
Roads |
Group values
To group values together into one symbol class, follow these steps:
While pressing the Ctrl key, click multiple symbol class rows from the table to select them.
Right-click the Value or Label cell of one of the selected values and click Group values
to combine selected classes into one group.
Ungroup a grouped class by right-clicking it and clicking Ungroup values
Create headings
Use headings to organize similar symbol classes together in the legend and give them a collective name. Headings are reflected in the Contents pane and also in legends on layouts. Follow these steps to create headings for symbol classes:
Click a symbol class row to select it, or while pressing the Ctrl key, click multiple symbol class rows to select them.
Right-click the Value or Label cell of one of the selected values and click Move to heading
.Click New heading to place the selected symbol classes under a new heading. Rename the heading as necessary.
Click the name of the existing heading (Heading by default) to place the selected symbol classes under the existing heading.
Optionally, reorder headings. Click the Heading options button
next to the heading name and click Move heading and classes up
or Move heading and classes down
.The symbol classes within the heading stay with the heading and are also moved.
To remove a heading from the layer, click the Heading options button
next to the heading name and click Remove heading and classes
.The symbol classes within the heading are also removed. Click Add unlisted values
to add them back, if necessary.
Vary unique value symbology by transparency, rotation, size, or color
In addition to specifying qualitative symbology with unique values, you can also symbolize additional attributes by varying the transparency, rotation, size, and color of the unique value symbols. While all of these visual variables can be applied simultaneously, be aware that too many variations make the layer difficult to interpret. It is recommended that you apply secondary symbology sparingly.
Learn more about symbolization concepts
In the Symbology pane, click the Vary symbology by attribute tab
.Expand Transparency, Rotation, Color, or Size.
With polygon features, Outline width replaces Size, and Rotation is not available.
Learn more about varying symbology by transparency
Learn more about varying symbology by rotation
If a visual variable is set on the primary symbology, a sample size used to calculate statistics for the variable is set to 10,000 records. To change the maximum sample size, on the Advanced symbology options tab
, expand Sample size and modify the maximum sample size value.
