Symbolize feature layers
When data is contained in a feature layer, you can change the way data is represented by symbolizing the feature layer. ArcGIS Pro provides many symbolization methods, known as primary symbologies, for feature layers:
  • Single symbol—Draw all features in a layer with a common symbol.
  • Unique values—Apply a different symbol to each category of features within the layer based on one or more fields.
  • Graduated colors—Show quantitative differences in feature values with a range of colors.
  • Graduated symbols—Show quantitative differences in feature values with varying symbol sizes.
  • Bivariate colors—Use graduated colors to show quantitative differences in feature values between two fields.
  • Unclassed colors—Show quantitative differences in feature values with a range of colors not broken into discrete classes.
  • Proportional symbology—Represent quantitative values as a series of unclassed, proportionally sized symbols.
  • Dot density—Draw quantities as point symbols distributed within polygons. This method is only available for polygon features.
  • Charts—Draw quantities from multiple fields using chart symbols.
  • Heat map—Draw the density of points as a continuous color gradient.
  • Dictionary—Apply symbols to data using multiple attributes.
Most feature layers use one of these symbology types. Depending on the type of data, you can choose from a few or all of the symbology types. Once applied, these choices symbolize the features in the layer with default symbols.
You can change symbols from the Format Symbol mode of the Symbology pane by clicking the symbol on the Primary symbology tab. The Format Symbol mode has the following two tabs:
When you work with one symbol at a time, you can change any of its properties and even restructure it by adding or removing components. When more than one symbol is selected, you can only change basic symbol properties, which vary based on symbol type as shown in the following table:
Symbol type
Basic properties
Polygon
  • Color
  • Outline color
  • Outline width
Line
  • Color
  • Line width
Point
  • Shape fill symbol, the polygon symbol used to fill the shape. The subproperties of this property are also accessible:
    • Color
    • Outline color
    • Outline width
  • Size
  • Angle
  • Halo
  • Angle alignment, in the context of a 2D map only
  • Billboard, in a 3D context only
  • Rotation order, in a 3D context only
Mesh
  • Color
Apply symbology to feature layers
Complete the following steps to apply symbology to feature layers:
  1. Highlight a feature layer by clicking its title in the Contents pane.
    The Feature Layer contextual tab appears on the ribbon.
  2. On the Feature Layer tab, in the Drawing group, click the arrow below Symbology to choose how to symbolize the layer:
    The Symbology pane appears, allowing you to further customize the way the layer is classified and symbolized.
  3. Click a symbol in the Symbology pane to open the Format Symbol mode of the Symbology pane to make changes.
    To change the basic properties of more than one symbol at a time, press Shift or Ctrl while clicking the symbols to make a selection. Right-click the selection, and choose Format symbols. To change all symbols, click More > Format all symbols.
  4. On the Format Symbol mode of the Symbology pane, choose a new symbol from a style to apply to all selected symbols, or modify aspects of the current symbol or symbols:
    Clicking a symbol in the Gallery immediately applies it to the selected class or classes in the layer.
  5. Optionally, change the current symbol or symbols on the Symbol tab under Properties.
    1. You can preview the appearance of symbols in the selection in the preview window at the bottom of the Format Symbol mode of the Symbology pane. Click the arrows on the side of the preview to scroll through a series of symbols one at a time if you have more than one symbol selected. To learn how to preview symbols, see Preview current symbol.
    2. Click Apply to commit the symbol changes to the layer and redraw the map.
  6. Click the back button to return to the Symbology pane.
Tip:
You can also open the Format Symbol mode of the Symbology pane directly by clicking a symbol in the Contents pane.
After applying primary symbology to a feature layer, you can further modify the symbols by applying a visual variable. Visual variables can symbolize additional attributes in the data beyond what is symbolized by the primary symbology.
Supported visual variables include the following:
Depending on the geometry type of your data, not all visual variables may be available for use. You can find a list of available variations on the Vary symbology by attribute tab of the Symbology pane. With unique values symbology, you can also classify the categorical data with additional attributes.
Apply a legend patch
For single symbol, unique values, graduated colors, and graduated symbols (lines only) symbology, you can further symbolize feature layer data by changing the legend patch of any line or polygon feature layer. Legend patches change the preview shape of the symbol shown in the Symbology and Contents panes, as well as in layout legends.
You can pick one of the default patch shapes, choose one from a style, or create a custom patch shape.
