ArcGIS.Desktop.Framework Namespace / OperationManager Class / DoAsync Method
The operation to perform.
    DoAsync Method (OperationManager)
    Performs the specified operation asynchronously and adds it to the undo stack.
    Syntax
    Public Overridable Function DoAsync( _
       ByVal operation As Operation _
    ) As Task
    public virtual Task DoAsync(
       Operation operation
    Parameters
    operation
    Return Value
    A task that represents the work queued to execute in the ThreadPool.
    Exceptions
    ExceptionDescription
    Thrown when an invalid operation is passed in.
    Remarks
    The specified operation is performed by calling its ArcGIS.Desktop.Framework.Contracts.Operation.DoAsync method and it is added to this OperationManager's undo stack. If operations are currently being grouped by means of CreateCompositeOperation, the operation will not directly appear on the stack and will instead be incorporated into the composite operation created.
    Whenever an operation is completed via DoAsync or Do, the redo stack is cleared of all operations belonging to the same category.
    Requirements
