ArcGIS.Desktop.Framework.Contracts Namespace / DockPane Class
    DockPane Class Properties
    For a list of all members of this type, see DockPane members.
    Public Properties
     NameDescription
    Public Property Gets or sets the DockPane's caption.
    Public PropertyGets or sets the supplementary text that appears with the Tooltip only when the command is disabled. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets the DockPane's position.
    Public Property Gets or sets a boolean to specify whether the control is enabled. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets the DAML identifier. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets a boolean indicating whether the pane has been fully initialized or not. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Public Property Gets a boolean to let clients know the DockPane is currently processing a Task.
    Public Property Gets the DockPane's floating state.
    Public Property Gets or sets the DockPane's visibility.
    Public Property Gets or sets the large representation of the command, this may be an image or a xaml element. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets the OperationManager associated with the DockPane.
    Public Property Gets or sets the small representation of the command, this may be an image or a xaml element. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets or sets the dockpane's lower tab text. This appears only when the dock pane is grouped with other tabs.
    Public Property Gets or sets a brief description of the command that appears in a small pop-up window when a user pauses the mouse pointer over an element, such as over a Button. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets or sets a one or two word label that appears above the tooltip. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Top
    Protected Properties
     NameDescription
    Protected Internal Property Gets or sets the content portion of the DockPane.
    Protected Internal Property Gets or sets the help topic ID to show.
    Top
