ArcGIS.Desktop.Mapping Namespace / MapView Class
    MapView Class Properties
    For a list of all members of this type, see MapView members.
    Public Properties
     NameDescription
    Public Propertystatic (Shared in Visual Basic) Gets the active map view. Returns null if there is no active map view.
    Public Property Gets the name of the active range definition in the map view.
    Public Property Gets the animation for the view.
    Public Property Gets the current Camera of the view.
    Public Property Gets whether the mapview can be printed
    Public Property Gets the current active TOC content type for the map view.
    Public Property Gets or sets the paused state on the map view.
    Public Property Gets the current extent of the view.
    Public Property Gets the field of view angle of the scene view.
    Public Property Gets or sets the floor filter settings which determine which floor-aware data is visible in the map view.
    Public Property Gets whether the MapView is a link chart view
    Public PropertyGets a value that indicates whether the MapView can be accessed. This property is false while the map view processes major operations like initializing or when a 3D view changes between SceneLocal and SceneGlobal.
    Public Property Gets a value indicating whether the cursor of the stereo model is fixed.
    Public Propertystatic (Shared in Visual Basic) Gets or sets the method used to link views.
    Public Property Gets the locator manager attached to this mapview.
    Public Property Gets the current look at Camera of the view.
    Public Property Gets the map or scene associated with the view.
    Public Property Gets or sets the range extent visible in the map view.
    Public Property Gets the range names defined on layers in the map view.
    Public Property Gets the current drawing mode of the scene view.
    Public Property Gets or sets the time range visible in the map view.
    Public Property Gets the perspective of the view.
    Top
