ArcGIS.Desktop.Mapping Namespace / SelectionEnvironment Class
    SelectionEnvironment Class Methods
    For a list of all members of this type, see SelectionEnvironment members.
    Public Methods
     NameDescription
    Public Methodstatic (Shared in Visual Basic) Sets the selection combination mode. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Sets the default selection color. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Sets the default highlight selection color. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Sets the default selection fill color. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Sets whether the default selection fill color (if any) will be hatched or solid. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Sets the value indicating whether click tolerance is enabled. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Sets a value indicating whether to keep invisible features selected with a new selection. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Sets a value indicating whether to save layer and standalone table selection with maps. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Sets the SelectionMethod. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Sets the search tolerance in device units. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Sets a value indicating whether to display the Selection Chip, when coincident or overlapping features are selected. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Sets a value indicating whether to display the selection graphic during selection. This method must be called on the MCT. Use QueuedTask.Run.
    Top
