| Name | Description | |
![]() | CIMReport Constructor |
The following tables list the members exposed by CIMReport.
![]() | CMYKColorProfile | Gets or sets the name of the CMYK color profile for a layout. (Inherited from ArcGIS.Core.CIM.CIMLayout) |
![]() | ColorModel | Gets or sets the color model for a layout. (Inherited from ArcGIS.Core.CIM.CIMLayout) |
![]() | CustomProperties | Gets or sets the custom properties of the layout. Custom properties are limited to key / value pairs of strings and developers are fully responsible for stored content. (Inherited from ArcGIS.Core.CIM.CIMLayout) |
![]() | DateExported | Gets or sets the date exported property for a layout. (Inherited from ArcGIS.Core.CIM.CIMLayout) |
![]() | DatePrinted | Gets or sets the date printed property for a layout. (Inherited from ArcGIS.Core.CIM.CIMLayout) |
![]() | DefaultColorVisionDeficiencyMode | Gets or sets the color vision deficiency mode that new views of this layout are opened with. (Inherited from ArcGIS.Core.CIM.CIMLayout) |
![]() | Elements | Gets or sets a collection of elements. (Inherited from ArcGIS.Core.CIM.CIMLayout) |
![]() | Height | Gets or sets the Height of the report. |
![]() | MapSeries | Gets or sets the map series for a layout. (Inherited from ArcGIS.Core.CIM.CIMLayout) |
![]() | MetadataURI | Gets or sets the metadata URI. (Inherited from ArcGIS.Core.CIM.CIMDefinition) |
![]() | Name | Gets or sets the name. (Inherited from ArcGIS.Core.CIM.CIMDefinition) |
![]() | Page | Gets or sets the CIMPage for the layout. (Inherited from ArcGIS.Core.CIM.CIMLayout) |
![]() | PDFAccessibilityReadingOrder | Gets or sets the ordered list of element names that defines the reading order for assistive technologies such as screen readers. (Inherited from ArcGIS.Core.CIM.CIMLayout) |
![]() | RGBColorProfile | Gets or sets the name of the RGB color profile for a layout. (Inherited from ArcGIS.Core.CIM.CIMLayout) |
![]() | SimulateOverprint | Gets or sets a value indicating whether to simulate overprint for a layout. (Inherited from ArcGIS.Core.CIM.CIMLayout) |
![]() | SourceModifiedTime | Gets or sets the time the source was last modified, as of the last sync. Used to detect when another sync is needed. (Inherited from ArcGIS.Core.CIM.CIMDefinition) |
![]() | SourcePortalUrl | Gets or sets the source portal URI of the item. Set if sourced from an external item such as an item on a portal. (Inherited from ArcGIS.Core.CIM.CIMDefinition) |
![]() | SourceURI | Gets or sets the source URI of the item. Set if sourced from an external item such as an item on a portal. (Inherited from ArcGIS.Core.CIM.CIMDefinition) |
![]() | StartPage | Gets or sets the starting page for the report. |
![]() | URI | Gets or sets the URI of the definition. Typically set by the system and used as an identifier. (Inherited from ArcGIS.Core.CIM.CIMDefinition) |
![]() | UseSourceMetadata | Gets or sets a value indicating whether the CIM definition accesses metadata from its data source (the default behavior), or if it has its own metadata stored in the project. (Inherited from ArcGIS.Core.CIM.CIMDefinition) |
![]() | Watermarks | Gets or sets a collection of watermark for the report. |
![]() | Clone | Creates a deep copy of CIMReport. |
![]() ![]() | FromJson | Reconstructs the CIMReport with a specified state from a JSON encoding. |
![]() | GetSchema | Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ReadXml | Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ToJson | Overridden. Creates a JSON encoding of the CIMReport and its current state. |
![]() | WriteXml | Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | RaisePropertyChanged | Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ReadXmlElement | Overridden. Reads the child element inside the reader. |
![]() | WriteXmlElements | Overridden. Writes a child element to the writer. |
![]() | PropertyChanged | Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject) |
