ArcGIS.Core.CIM Namespace / CIMTableFrameField Class
Properties Methods Events
    CIMTableFrameField Class Members
    The following tables list the members exposed by CIMTableFrameField.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the field background symbol.
    Public Property Gets or sets the field border symbol.
    Public Property Gets or sets the display name for the field. (Inherited from ArcGIS.Core.CIM.CIMTableField)
    Public Property Gets or sets a value indicating whether to wrap field values that don't fit the width.
    Public Property Gets or sets the zero based display order. (Inherited from ArcGIS.Core.CIM.CIMTableField)
    Public Property Gets or sets a value indicating whether this is a grouping field. (Inherited from ArcGIS.Core.CIM.CIMTableField)
    Public Property Gets or sets the field name/alias text symbol.
    Public Property Gets or sets a value indicating whether the field is visible. (Inherited from ArcGIS.Core.CIM.CIMTableField)
    Public Property Gets or sets the field name and unique identifier. (Inherited from ArcGIS.Core.CIM.CIMTableField)
    Public Property Gets or sets the options when this field is used for sorting. (Inherited from ArcGIS.Core.CIM.CIMTableField)
    Public Property Gets or sets the zero based sort order. -1 indicates field isn't used for sorting. (Inherited from ArcGIS.Core.CIM.CIMTableField)
    Public Property Gets or sets the field value text symbol.
    Public Property Gets or sets the symbol for vertical lines on sides of field.
    Public Property Gets or sets the width of field. A value of 0 indicates "auto size". (Inherited from ArcGIS.Core.CIM.CIMTableField)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMTableFrameField.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMTableFrameField with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMTableFrameField and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
