ArcGIS.Core.Data.UtilityNetwork.Trace Namespace / DownstreamTracer Class / Trace Method / Trace(TraceArgument) Method
The input arguments to the trace.
Example
    Executes a downstream trace.
    Syntax
    Public Overloads Overrides Function Trace( _
       ByVal traceArgument As TraceArgument _
    ) As IReadOnlyList(Of Result)
    Parameters
    traceArgument
    Return Value
    A IReadOnlyList of concrete Result whose type corresponds to ResultType set in TraceArgument.ResultTypes.
    Exceptions
    Example
    Trace a utility network with the digitized direction
      // This routine demonstrates how to perform a trace using the digitized direction of features
      static void TraceWithDigitizedDirection(UtilityNetwork utilityNetwork, Element startElement)
        using TraceManager traceManager = utilityNetwork.GetTraceManager();
        // Trace configuration with digitized direction
        TraceConfiguration traceConfiguration = new TraceConfiguration()
          IncludeIsolatedFeatures = true,
          IncludeBarriersWithResults = true,
          UseDigitizedDirection = true
        // Trace argument
        List<Element> startElements = new List<Element> { startElement };
        TraceArgument traceArgument = new TraceArgument(startElements);
        traceArgument.Configuration = traceConfiguration;
        // Results
        DownstreamTracer downstreamTracer = traceManager.GetTracer<DownstreamTracer>();
        IReadOnlyList<Result> traceResults = downstreamTracer.Trace(traceArgument);
        foreach (Result traceResult in traceResults)
          // Iterate trace results
    Requirements
    ArcGIS Pro version: 3.2 or higher.
