ArcGIS.Core.CIM Namespace / CIMTMElevationGuideBarElement Class
    CIMTMElevationGuideBarElement Class Properties
    For a list of all members of this type, see CIMTMElevationGuideBarElement members.
    Public Properties
     NameDescription
    Public Property Gets or sets the anchor position of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets a value indicating whether properties of the surround should update automatically based on changes in the map. (Inherited from ArcGIS.Core.CIM.CIMMapProductSurround)
    Public Property Gets or sets the custom properties of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets a value indicating whether to draw the element to specification size or allow user to manually resize element. (Inherited from ArcGIS.Core.CIM.CIMMapProductSurround)
    Public Property Gets or sets elevation bands feature class, the number of bands in the bar is dependent on the number of bands identified in feature class.
    Public Property Gets or sets a value indicating whether this element is expanded in the contents pane. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the geometry of a frame for an element. (Inherited from ArcGIS.Core.CIM.CIMFrameElement)
    Public Property Gets or sets the graphic symbology of an element's frame. (Inherited from ArcGIS.Core.CIM.CIMFrameElement)
    Public Property Gets or sets the high band symbol in the elevation guide bar.
    Public Property Gets or sets the highest band symbol in the elevation guide bar.
    Public Property Gets or sets the symbol used for line elements in the elevation guide bar.
    Public Property Gets or sets a value indicating whether the element is locked. Each element in the contents pane has a lock icon. If the icon is shown as locked, you can not select that feature in the layout using the select tool. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets a value indicating whether the aspect ratio for an element is locked. If locked, the width and height values stretch proportionally. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the low band symbol in the elevation guide bar.
    Public Property Gets or sets the map frame associated with the map surround. (Inherited from ArcGIS.Core.CIM.CIMMapSurround)
    Public Property Gets or sets the maximum scale. (Inherited from ArcGIS.Core.CIM.CIMMapSurround)
    Public Property Gets or sets the medium band symbol in the elevation guide bar.
    Public Property Gets or sets the minimum scale. (Inherited from ArcGIS.Core.CIM.CIMMapSurround)
    Public Property Gets or sets the name of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the number of bands displayed in the Elevation Guide Bar, if data is from source that does not have Bands field.
    Public Property Gets or sets the map product specification type of the surround. (Inherited from ArcGIS.Core.CIM.CIMMapProductSurround)
    Public Property Gets or sets the rotation of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the location of the anchor in page units.This is also the location the feature is rotated around. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the symbol used for text elements in the elevation guide bar.
    Public Property Gets or sets a value indicating whether the element is visible. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Top
