ArcGIS.Core.CIM Namespace / CIMGroupEditingTemplate Class
Properties Methods Events
    CIMGroupEditingTemplate Class Members
    The following tables list the members exposed by CIMGroupEditingTemplate.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the base name.
    Public Property Gets or sets the base part.
    Public Property Gets or sets a value indicating whether this template will attempt to create associations between features being created. This property is only used with group templates in layers participating in a utility network.
    Public Property Gets or sets the default tool GUID. (Inherited from ArcGIS.Core.CIM.CIMEditingTemplate)
    Public Property Gets or sets the description. (Inherited from ArcGIS.Core.CIM.CIMEditingTemplate)
    Public Property Gets or sets the excluded tool GUIDs. (Inherited from ArcGIS.Core.CIM.CIMEditingTemplate)
    Public Property Gets or sets the name. (Inherited from ArcGIS.Core.CIM.CIMEditingTemplate)
    Public Property Gets or sets the parts.
    Public Property Gets or sets the tags. (Inherited from ArcGIS.Core.CIM.CIMEditingTemplate)
    Public Property Gets or sets the per-tool options. (Inherited from ArcGIS.Core.CIM.CIMEditingTemplate)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMGroupEditingTemplate.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMGroupEditingTemplate with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMGroupEditingTemplate and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Extension Methods
     NameDescription
    Public Extension Method Adds a component part to the group template. This method must be called on the MCT. Use QueuedTask.Run.
    Public Extension Method Allows a construction tool on the template.
    Public Extension Method Excludes a construction tool from the template.
    Public Extension Method Gets the default construction tool.
    Public Extension Method Gets the excluded construction tools on the template.
    Public Extension Method Read the Tags from a CIMEditingTemplate.
    Public Extension Method Sets the default construction tool.
    Public Extension Method Sets the excluded construction tools on the template.
    Public Extension Method Write an array of tags to a CIMEditingTemplate.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
