ArcGIS.Core.CIM Namespace / CIMGlossaryTable Class
    CIMGlossaryTable Class Properties
    For a list of all members of this type, see CIMGlossaryTable members.
    Public Properties
     NameDescription
    Public Property Gets or sets the anchor position of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets a value indicating whether properties of the surround should update automatically based on changes in the map. (Inherited from ArcGIS.Core.CIM.CIMMapProductSurround)
    Public Property Gets or sets the custom properties of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the delimiter character that is displayed between columns.
    Public Property Gets or sets the text symbol for the delimiter displayed between columns.
    Public Property Gets or sets a value indicating whether to draw the element to specification size or allow user to manually resize element. (Inherited from ArcGIS.Core.CIM.CIMMapProductSurround)
    Public Property Gets or sets a value indicating whether this element is expanded in the contents pane. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the fields displayed in the glossary table.
    Public Property Gets or sets the fitting strategy.
    Public Property Gets or sets the geometry of a frame for an element. (Inherited from ArcGIS.Core.CIM.CIMFrameElement)
    Public Property Gets or sets the graphic symbology of an element's frame. (Inherited from ArcGIS.Core.CIM.CIMFrameElement)
    Public Property Gets or sets the gap between column headings and rows. Values are in points.
    Public Property Gets or sets the horizontal gap around field values. Values are in points.
    Public Property Gets or sets a value indicating whether the element is locked. Each element in the contents pane has a lock icon. If the icon is shown as locked, you can not select that feature in the layout using the select tool. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets a value indicating whether the aspect ratio for an element is locked. If locked, the width and height values stretch proportionally. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the map frame associated with the map surround. (Inherited from ArcGIS.Core.CIM.CIMMapSurround)
    Public Property Gets or sets the URI to a Layer or Standalone table in the project.
    Public Property Gets or sets the maximum scale. (Inherited from ArcGIS.Core.CIM.CIMMapSurround)
    Public Property Gets or sets the limit when reducing font sizes. Values are in points.
    Public Property Gets or sets the minimum scale. (Inherited from ArcGIS.Core.CIM.CIMMapSurround)
    Public Property Gets or sets the name of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the map product specification type of the surround. (Inherited from ArcGIS.Core.CIM.CIMMapProductSurround)
    Public Property Gets or sets a value indicating whether right to left orientation should be applied.
    Public Property Gets or sets the rotation of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the location of the anchor in page units.This is also the location the feature is rotated around. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the gap between rows. Values are in points.
    Public Property Gets or sets the title of the element.
    Public Property Gets or sets the gap between title and column headings. Values are in points.
    Public Property Gets or sets the text symbol for title text.
    Public Property Gets or sets the vertical gap around field values. Values are in points.
    Public Property Gets or sets a value indicating whether the element is visible. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Top
