ArcGIS.Core.CIM Namespace / CIMSubtypeGroupTable Class
Properties Methods Events
    CIMSubtypeGroupTable Class Members
    The following tables list the members exposed by CIMSubtypeGroupTable.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the active range name. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets a value indicating whether the SQL in a definition query can contain native SQL syntax. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets a value indicating whether to automatically generate row templates from the renderer. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets the bind variables. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets the table's charts. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets the custom properties of the standalone table. Custom properties are limited to key / value pairs of strings and developers are fully responsible for stored content. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public PropertyGets or sets overrides for database relationships as relationship info. By default this property is null. This will contain relationship info elements for those database relationships that have overrides. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets the data connection for the table. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets the definition expression that can subset the rows in the layer or table. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets the name of the active definition expression. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets the definition filter choices. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets the description. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public PropertyGets or sets the expression information used for coming up with a string that represents a row or a feature. This property takes precedence over DisplayField. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets the name of the attribute field that will be used as a label that represents each row in the layer or table. The display field must be able to be represented as a string (string or numeric). (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets a value indicating whether or not the layer or table can be edited. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets a value indicating whether this group table is expanded in the contents pane.
    Public Property Gets or sets the field descriptions. Field descriptions for fields may only be written if values are overridden from defaults. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets floor-aware properties for the layer or table used in floor filtering. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets the form information for the layer or table. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets the metadata URI. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the name. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the page definition which allows for using current map series page to filter rows. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets the pop-up info. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets the range definitions. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets the relates. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets the route identifier field of a route feature class. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets the row templates. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets a value indicating whether or not this table should be included in the search. This property is honored only by tables that support search. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets the URI of the selection set for the layer or table. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets a value indicating whether related data should be selected when creating a new selection. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets identifier that will be used to identify the layer in server. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets a value indicating whether or not to show pop-ups. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets the time the source was last modified, as of the last sync. Used to detect when another sync is needed. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the source portal URI of the item. Set if sourced from an external item such as an item on a portal. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the source URI of the item. Set if sourced from an external item such as an item on a portal. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the standalone tables as an array of table repository paths.
    Public Property Gets or sets the subtype value that should be used in the feature layer definition. This property is honored only when feature layer is a member of SubtypeLayer. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets the time definition. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets the time definition fields. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets the time display definition. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets the time fields. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets the URI of the definition. Typically set by the system and used as an identifier. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets a value indicating whether the CIM definition accesses metadata from its data source (the default behavior), or if it has its own metadata stored in the project. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets a value indicating whether or not the SubtypeValue should be used. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets a value indicating whether or not to use the visibility time extent. When true the map time must overlap the visibility time extent for the table to be visible. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets the visibility time extent. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Public Property Gets or sets an identifier that will be used to identify the standalone table in a web map. This value is present if the standalone table originated in a web map and facilitates matching the standalone table back to its origin when updating the web map. (Inherited from ArcGIS.Core.CIM.CIMStandaloneTable)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMSubtypeGroupTable.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMSubtypeGroupTable with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMSubtypeGroupTable and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
