ArcGIS.Core.CIM Namespace / CIMKnowledgeGraphCoordinatePropertyValue Class
Properties Methods Events
    CIMKnowledgeGraphCoordinatePropertyValue Class Members
    The following tables list the members exposed by CIMKnowledgeGraphCoordinatePropertyValue.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the field names of this property value.
    Public Property Gets or sets a value indicating whether the coordinate should be interpreted as long,lat (true) or lat,lon(false,default). This value only has meaning when the coordinate is ambiguous. For example, the coordinate "34N 22E" is not ambiguous as the latitude and longitude are both defined by the coordinate. However, "34 22" is ambiguous since it could mean either "34N 22E" or "34E 22N". In this situation the value of this property determines the recognized coordinate.
    Public Property Gets or sets the spatial reference of the coordinates.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMKnowledgeGraphCoordinatePropertyValue.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMKnowledgeGraphCoordinatePropertyValue with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMKnowledgeGraphCoordinatePropertyValue and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
