| Name | Description | |
![]() | CIMLASDatasetLayer Constructor |
The following tables list the members exposed by CIMLASDatasetLayer.
![]() | AllowDrapingOnIntegratedMesh | Gets or sets a value indicating whether layer can be draped on integrated mesh. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | AnalysisToolsResolution | Gets or sets the analysis tool resolution. |
![]() | Attribution | Gets or sets the attribution text that appears on a map that draws this layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | BlendingMode | Gets or sets the blending mode for the layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | Charts | Gets or sets identifier the layer's charts. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | CustomProperties | Gets or sets the custom properties of the layer. Custom properties are limited to key / value pairs of strings and developers are fully responsible for stored content. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | DataConnection | Gets or sets the data connection to the LAS dataset. |
![]() | Description | Gets or sets the description. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | DisplayCacheType | Gets or sets the display cache type. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | DisplayField | Gets or sets the display field. |
![]() | EnableLayerEffects | Gets or sets a value indicating whether to enable any type of effects on the layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | Expanded | Gets or sets a value indicating whether this layer is expanded in the contents pane. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | EyeDomeLighting | Gets or sets eye-dome lighting properties. |
![]() | FileExtentSymbol | Gets or sets the file extent symbol. |
![]() | FileNameSymbol | Gets or sets the file name symbol. |
![]() | FullResolutionScale | Gets or sets the full resolution scale. |
![]() | IsFlattened | Gets or sets a value indicating whether this layer is flattened. |
![]() | LASDatasetFilter | Gets or sets the LAS dataset filter. |
![]() | Layer3DProperties | Gets or sets the 3D layer properties. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | LayerEffects | Gets or sets the layer effects for the layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | LayerElevation | Gets or sets the layer elevation. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | LayerMasks | Gets or sets the URIs of the layers used as masks. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | LayerScaleVisibilityOptions | Gets or sets the layer's scale visibility options. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | LayerTemplate | Gets or sets the layer template. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | LayerType | Gets or sets the map layer type. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | MaintainCurrentSurface | Gets or sets a value indicating whether the current surface should be maintained. |
![]() | MaxDisplayCacheAge | Gets or sets the maximum display cache age. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | MaxScale | Gets or sets the maximum scale for layer draw (set as the denominator of the scale's representative fraction). (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | MetadataURI | Gets or sets the metadata URI. (Inherited from ArcGIS.Core.CIM.CIMDefinition) |
![]() | MinScale | Gets or sets the minimum scale for layer draw (set as the denominator of the scale's representative fraction). (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | Name | Gets or sets the name. (Inherited from ArcGIS.Core.CIM.CIMDefinition) |
![]() | PointBudget | Gets or sets the point budget. |
![]() | PointCountPerCentimeter | Gets or sets the point count per centimeter. |
![]() | PopupInfo | Gets or sets the pop-up info. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | RasterizeOnExport | Gets or sets a value indicating whether layer should be rasterized when exporting. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | RefreshRate | Gets or sets the amount of time to wait between refreshing the layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | RefreshRateUnit | Gets or sets the units for the amount of time to wait between refreshing the layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | Renderers | Gets or sets the renderers. |
![]() | ScaleSymbols | Gets or sets a value indicating whether to scale symbols. |
![]() | Searchable | Gets or sets a value indicating whether or not this layer should be included in the search. This property is honored only by layers that support search. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | Selectable | Gets or sets a value indicating whether the layer is selectable. |
![]() | SelectionColor | Gets or sets the selection color. |
![]() | ServiceLayerID | Gets or sets identifier that will be used to identify the layer in server. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | ShowFileExtent | Gets or sets a value indicating whether to show the file extent. |
![]() | ShowFileName | Gets or sets a value indicating whether to show the file name. |
![]() | ShowLegends | Gets or sets a value indicating whether or not to show legends. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | ShowMapTips | Gets or sets a value indicating whether or not the value of the display field or expression is shown when hovering over a layer in the view. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | ShowPopups | Gets or sets a value indicating whether or not to show pop-ups. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | ShowResolution | Gets or sets a value indicating whether to show the resolution. |
![]() | SourceModifiedTime | Gets or sets the time the source was last modified, as of the last sync. Used to detect when another sync is needed. (Inherited from ArcGIS.Core.CIM.CIMDefinition) |
![]() | SourcePortalUrl | Gets or sets the source portal URI of the item. Set if sourced from an external item such as an item on a portal. (Inherited from ArcGIS.Core.CIM.CIMDefinition) |
![]() | SourceURI | Gets or sets the source URI of the item. Set if sourced from an external item such as an item on a portal. (Inherited from ArcGIS.Core.CIM.CIMDefinition) |
![]() | Transparency | Gets or sets the transparency of the layer as a percentage. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | URI | Gets or sets the URI of the definition. Typically set by the system and used as an identifier. (Inherited from ArcGIS.Core.CIM.CIMDefinition) |
![]() | UseDynamicLOD | Gets or sets a value indicating whether to use dynamic level-of-detail. |
![]() | UseFullResolutionScale | Gets or sets a value indicating whether to use the full resolution scale. |
![]() | UseSelectionColor | Gets or sets a value indicating whether to use the selection color. |
![]() | UseSourceMetadata | Gets or sets a value indicating whether the CIM definition accesses metadata from its data source (the default behavior), or if it has its own metadata stored in the project. (Inherited from ArcGIS.Core.CIM.CIMDefinition) |
![]() | UseVisibilityTimeExtent | Gets or sets a value indicating whether or not to use a fixed time extent for layer visibility. When true, the map time must overlap this extent for the layer to be visible. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | Visibility | Gets or sets a value indicating whether or not this layer is visible. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | VisibilityTimeExtent | Gets or sets the fixed time extent for layer visibility. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | WebMapLayerID | Gets or sets an identifier that will be used to identify the layer in a web map. This value is present if the layer originated in a web map and facilitates matching the layer back to its origin when updating the web map. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | Clone | Creates a deep copy of CIMLASDatasetLayer. |
![]() ![]() | FromJson | Reconstructs the CIMLASDatasetLayer with a specified state from a JSON encoding. |
![]() | GetSchema | Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ReadXml | Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ToJson | Overridden. Creates a JSON encoding of the CIMLASDatasetLayer and its current state. |
![]() | WriteXml | Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | RaisePropertyChanged | Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ReadXmlElement | Overridden. Reads the child element inside the reader. |
![]() | WriteXmlElements | Overridden. Writes a child element to the writer. |
![]() | PropertyChanged | Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject) |
