ArcGIS.Core.CIM Namespace / CIMBinningFeatureReduction Class
Properties Methods Events
    CIMBinningFeatureReduction Class Members
    The following tables list the members exposed by CIMBinningFeatureReduction.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the bin type in which features are aggregated.
    Public Property Gets or sets a value indicating whether binning should be performed on the client side, even when the data source has binning capabilities.
    Public Property Gets or sets a value indicating whether feature reduction is enabled in the feature layer. (Inherited from ArcGIS.Core.CIM.CIMFeatureReduction)
    Public PropertyGets or sets the number of features to use when ThresholdType is set to BinsToPointsThresholdType.FeatureCount.
    Public Property Gets or sets the fields that should be shown with the aggregated features. (Inherited from ArcGIS.Core.CIM.CIMAggregationFeatureReduction)
    Public Property Gets or sets the bin level at which bins will be drawn. If -1, the bin level will be automatically chosen based on the minimum bin size.
    Public PropertyGets or sets the maximum scale to use when ThresholdType is set to BinsToPointsThresholdType.MaxScale.
    Public Property Gets or sets the minimum size (in points) to maintain as the bins are drawn at different scales.
    Public Property Gets or sets the popup info for the aggregated features. (Inherited from ArcGIS.Core.CIM.CIMAggregationFeatureReduction)
    Public Property Gets or sets the spatial reference in which features are aggregated.
    Public Property Gets or sets the threshold at which points are shown.
    Public Property Gets or sets the visualization used by the bins.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMBinningFeatureReduction.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMBinningFeatureReduction with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMBinningFeatureReduction and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
