ArcGIS.Core.CIM Namespace / CIMAttachmentFrame Class
Properties Methods Events
    CIMAttachmentFrame Class Members
    The following tables list the members exposed by CIMAttachmentFrame.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the anchor position of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the custom properties of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the text to display when no attachment images are available.
    Public Property Gets or sets the text symbol for the empty placeholder text.
    Public Property Gets or sets the list of excluded grid cells. Cells that are excluded are left blank when the report is exported.
    Public Property Gets or sets a value indicating whether this element is expanded in the contents pane. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the attachment filter type. The filter attachment type determines which attachments from the feature that are used in the exported report.
    Public Property Gets or sets the filter value. When using the First or Last attachment filter type, the value indicates the number of attachments to use in the grid configuration. When using the Index attachment filter type, the value indicates the index and is zero-based.
    Public Property Gets or sets the geometry of a frame for an element. (Inherited from ArcGIS.Core.CIM.CIMFrameElement)
    Public Property Gets or sets the graphic symbology of an element's frame. (Inherited from ArcGIS.Core.CIM.CIMFrameElement)
    Public Property Gets or sets the number of attachment image columns.
    Public Property Gets or sets a value indicating whether the grid layout is in row major order.
    Public Property Gets or sets the number of attachment image rows. If less than 0, the number of rows is automatically calculated.
    Public Property Gets or sets the graphic symbology of each attachment image frame.
    Public Property Gets or sets the height of each attachment image.
    Public Property Gets or sets the rotation of all attachment images. The value is in degrees counterclockwise.
    Public Property Gets or sets the rotation of each attachment image using an expression. This value overrides the ImageRotation value.
    Public Property Gets or sets the width of each attachment image.
    Public Property Gets or sets a value indicating whether the element is locked. Each element in the contents pane has a lock icon. If the icon is shown as locked, you can not select that feature in the layout using the select tool. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets a value indicating whether the aspect ratio for an element is locked. If locked, the width and height values stretch proportionally. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets maximum number of image attachments to display. If -1, all images attachments will be available.
    Public Property Gets or sets the name of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the rotation of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the location of the anchor in page units.This is also the location the feature is rotated around. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets a value indicating whether to show a text placeholder when no attachment images are available.
    Public Property Gets or sets field name to sort.
    Public Property Gets or sets sort order of image attachments.
    Public Property Gets or sets a value indicating whether the first attachment image should start on a new page.
    Public Property Gets or sets a value indicating whether the element is visible. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the where clause that queries the attachment table. The where clause is used before applying the filter type. For example, CONTENT_TYPE = 'image/jpeg'.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMAttachmentFrame.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMAttachmentFrame with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMAttachmentFrame and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
