| Name | Description | |
![]() | NAWasteCollectionSolver Constructor |
The following tables list the members exposed by NAWasteCollectionSolver.
![]() | AccumulateAttributeNames | Gets and sets the accumulate attribute names. (Inherited from ArcGIS.Core.CIM.NASolverDefinition) |
![]() | AllowRouteConstraintViolations | Gets and sets whether to allow route constraint violations upon solve. |
![]() | AppliedTravelMode | Gets and sets the applied travel mode. (Inherited from ArcGIS.Core.CIM.NASolverDefinition) |
![]() | AppliedTravelModeJSON | Gets and sets the applied travel mode as JSON. (Inherited from ArcGIS.Core.CIM.NASolverDefinition) |
![]() | AttributeNames | Gets and sets the attribute names. (Inherited from ArcGIS.Core.CIM.NASolverDefinition) |
![]() | AttributeParameterValues | Gets and sets the attribute parameters values. (Inherited from ArcGIS.Core.CIM.NASolverDefinition) |
![]() | DirectionsLanguage | Gets and sets the directions language. (Inherited from ArcGIS.Core.CIM.NADirectionsCapableSolverDefinition) |
![]() | DirectionsLengthAttributeName | Gets and sets the directions length attribute name. (Inherited from ArcGIS.Core.CIM.NADirectionsCapableSolverDefinition) |
![]() | DirectionsLengthUnits | Gets and sets the directions length units. (Inherited from ArcGIS.Core.CIM.NADirectionsCapableSolverDefinition) |
![]() | DirectionsOutputSpatialReference | Gets and sets the directions output spatial reference. (Inherited from ArcGIS.Core.CIM.NADirectionsCapableSolverDefinition) |
![]() | DirectionsOutputType | Gets and sets the directions output type. (Inherited from ArcGIS.Core.CIM.NADirectionsCapableSolverDefinition) |
![]() | DirectionsStyleName | Gets and sets the directions style name. (Inherited from ArcGIS.Core.CIM.NADirectionsCapableSolverDefinition) |
![]() | DirectionsTimeAttributeName | Gets and sets the directions time attribute name. (Inherited from ArcGIS.Core.CIM.NADirectionsCapableSolverDefinition) |
![]() | DistanceUnits | Gets and sets the distance units. |
![]() | HierarchyAttributeName | Gets and sets the name of the hierarchy attribute to be used in analysis. (Inherited from ArcGIS.Core.CIM.NASolverDefinition) |
![]() | HierarchyLevelCount | Gets and sets the hierarchy level count. (Inherited from ArcGIS.Core.CIM.NASolverDefinition) |
![]() | HierarchyMaxValues | Gets and sets the maximum value of the hierarchy attribute. (Inherited from ArcGIS.Core.CIM.NASolverDefinition) |
![]() | HierarchyNumTransitions | Gets and sets the number of lower level junctions to explore before searching the next hierarchy level. (Inherited from ArcGIS.Core.CIM.NASolverDefinition) |
![]() | IgnoreInvalidLocations | Gets and sets a boolean which indicates whether or not to ignore invalid locations. (Inherited from ArcGIS.Core.CIM.NASolverDefinition) |
![]() | ImpedanceAttributeName | Gets and sets the impedance attribute name. (Inherited from ArcGIS.Core.CIM.NASolverDefinition) |
![]() | IsDirectionsGenerationEnabled | Gets and sets whether or not to generate directions on solve. (Inherited from ArcGIS.Core.CIM.NADirectionsCapableSolverDefinition) |
![]() | MaxRouteTotalTime | Gets and sets the route maximum total time span in time units. |
![]() | NetworkBuildHash | Gets and sets the associated network build hash. (Inherited from ArcGIS.Core.CIM.NASolverDefinition) |
![]() | OutputGeometryPrecision | Gets and sets the output geometry precision. (Inherited from ArcGIS.Core.CIM.NASolverDefinition) |
![]() | OutputGeometryPrecisionUnits | Gets and sets the output geometry precision units. (Inherited from ArcGIS.Core.CIM.NASolverDefinition) |
![]() | ResetHierarchyRangesOnBind | Gets and sets a boolean which indicates if the hierarchy ranges will be reset to the network dataset's hierarchy settings when the solver is bound. (Inherited from ArcGIS.Core.CIM.NASolverDefinition) |
![]() | RestrictionAttributeNames | Gets and sets the restriction attribute names. (Inherited from ArcGIS.Core.CIM.NASolverDefinition) |
![]() | RestrictUTurns | Gets and sets a setting which indicates how U-Turns should be restricted in the analysis. (Inherited from ArcGIS.Core.CIM.NASolverDefinition) |
![]() | RouteStartTime | Gets and sets the route start time. |
![]() | SolverOverrides | Gets and sets the associated solver overrides. (Inherited from ArcGIS.Core.CIM.NASolverDefinition) |
![]() | StopCollectionMode | Gets and sets the stop collection mode. |
![]() | TimeUnits | Gets and sets the time units. |
![]() | UseHierarchy | Gets and sets a boolean which indicates if the hierarchy attribute for the network should be used in analysis. (Inherited from ArcGIS.Core.CIM.NASolverDefinition) |
![]() ![]() | FromJson | Reconstructs the NAWasteCollectionSolver with a specified state from a JSON encoding. |
![]() | GetSchema | Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ReadXml | Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ToJson | Overridden. Creates a JSON encoding of the NALastMileDeliverySolver and its current state. |
![]() | WriteXml | Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | RaisePropertyChanged | Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ReadXmlElement | Overridden. Reads the child element inside the reader. |
![]() | WriteXmlElements | Overridden. Writes a child element to the writer. |
![]() | PropertyChanged | Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject) |
