| Name | Description | |
![]() | CIMRasterFlowColorizer Constructor |
The following tables list the members exposed by CIMRasterFlowColorizer.
![]() | AuthoringInfo | Gets or sets the authoring info. Stores UI authoring metadata used by clients to restore their state when reopening the renderer. |
![]() | Brightness | Gets or sets the brightness value. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer) |
![]() | Color | Gets or sets the single streamline color used when no color visual variable is active. Default is white. |
![]() | Contrast | Gets or sets the contrast value. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer) |
![]() | Density | Gets or sets the density of the streamlines. Controls how many streamlines are seeded. Values above 1 increase density, values between 0 and 1 decrease it, and a value of 0 shows no streamlines. Very high values may be limited by screen size and trail length. |
![]() | DirectionBandIndex | Gets or sets the direction band index. When IsUVComponents is true, this is the V-component band index. |
![]() | FlowRepresentation | Gets or sets the flow representation type indicating whether data is interpreted as flow-from or flow-to. |
![]() | FlowSpeed | Gets or sets the flow speed multiplier. Multiplies animation speed without changing trail length. A value of 0 stops animation. |
![]() | IsUVComponents | Gets or sets a value indicating whether flow is composed from U and V components. |
![]() | MagnitudeBandIndex | Gets or sets the magnitude band index. When IsUVComponents is true, this is the U-component band index. |
![]() | MaxPathLength | Gets or sets the maximum path length in points. Controls how far a trail can travel before looping. |
![]() | Name | Gets or sets the name. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer) |
![]() | NoDataColor | Gets or sets the no data color. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer) |
![]() | ReferenceSystem | Gets or sets the reference system for symbol rotation. |
![]() | ResamplingType | Gets or sets the raster resampling type. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer) |
![]() | TrailCap | Gets or sets the trail cap style. Round only applies when TrailWidth is greater than 3pt. Square is not applicable. |
![]() | TrailLength | Gets or sets the trail length in points. Controls the visible lit portion of the streamline. This will be longer where the particle is moving faster, and shorter where the particle is moving slower. |
![]() | TrailWidth | Gets or sets the trail width in points. |
![]() | UseColorVisualVariable | Gets or sets a value indicating whether the color visual variable in VisualVariables is active. When false, Color is used instead. |
![]() | VisualVariables | Gets or sets the visual variables. Supports magnitude-driven color, opacity, and size overrides. |
![]() | Clone | Creates a deep copy of CIMRasterFlowColorizer. |
![]() ![]() | FromJson | Reconstructs the CIMRasterFlowColorizer with a specified state from a JSON encoding. |
![]() | GetSchema | Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ReadXml | Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ToJson | Overridden. Creates a JSON encoding of the CIMRasterFlowColorizer and its current state. |
![]() | WriteXml | Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | RaisePropertyChanged | Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ReadXmlElement | Overridden. Reads the child element inside the reader. |
![]() | WriteXmlElements | Overridden. Writes a child element to the writer. |
![]() | PropertyChanged | Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject) |
