ArcGIS.Core.CIM Namespace / CIMRasterClassifyColorizer Class
Properties Methods Events
    CIMRasterClassifyColorizer Class Members
    The following tables list the members exposed by CIMRasterClassifyColorizer.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether or not to automatically update class labels whenever a class upper value is changed.
    Public Property Gets or sets the brightness value. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer)
    Public Property Gets or sets the class breaks of the renderer.
    Public Property Gets or sets the classification method.
    Public Property Gets or sets the color ramp.
    Public Property Gets or sets the contrast value. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer)
    Public Property Gets or sets the exclusion color.
    Public Property Gets or sets the exclusion description.
    Public Property Gets or sets the exclusion label.
    Public Property Gets or sets the exclusion ranges as an array of doubles.
    Public Property Gets or sets the exclusion values as an array of doubles.
    Public Property Gets or sets the renderer field.
    Public Property Gets or sets the legend heading.
    Public Property Gets or sets the minimum break of the classification.
    Public Property Gets or sets the name. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer)
    Public Property Gets or sets the no data color. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer)
    Public Property Gets or sets the normalization field.
    Public Property Gets or sets the normalization total.
    Public Property Gets or sets the normalization type.
    Public Property Gets or sets the number format applied to values.
    Public Property Gets or sets the raster resampling type. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer)
    Public Property Gets or sets a value indicating whether or not to show class gaps.
    Public Property Gets or sets a value indicating whether or not to show classes in ascending order.
    Public Property Gets or sets a value indicating whether or not to use the exclusion color.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMRasterClassifyColorizer.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMRasterClassifyColorizer with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMRasterClassifyColorizer and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
