ArcGIS.Core.CIM Namespace / CIMSpatialMapSeries Class
Properties Methods Events
    CIMSpatialMapSeries Class Members
    The following tables list the members exposed by CIMSpatialMapSeries.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the category of the page.
    Public Property Gets or sets a value indicating whether map clipping is synchronized with the current series index feature.
    Public Property Gets or sets the current page Id. (Inherited from ArcGIS.Core.CIM.CIMMapSeries)
    Public Property Gets or sets a value indicating whether the map series is enabled on the layout. (Inherited from ArcGIS.Core.CIM.CIMMapSeries)
    Public Property Gets or sets the extent fitting options.
    Public Property Gets or sets the URI of the index layer.
    Public Property Gets or sets the URI of the MapFrame to which MapSeries is linked. (Inherited from ArcGIS.Core.CIM.CIMMapSeries)
    Public Property Gets or sets the value of the margin.
    Public Property Gets or sets the type of margins.
    Public Property Gets or sets the units of the margin.
    Public Property Gets or sets the name of the specified page.
    Public Property Gets or sets the number of the specified page.
    Public Property Gets or sets the page specific rotation.
    Public Property Gets or sets field that specifies the page specific scale.
    Public Property Gets or sets the specified value to which the scale rounds to.
    Public Property Gets or sets a value indicating whether to sort in ascending or descending order.
    Public Property Gets or sets the required field that specifies the field used to determine /// sort order.
    Public Property Gets or sets the spatial reference of the page.
    Public Property Gets or sets the starting page number. (Inherited from ArcGIS.Core.CIM.CIMMapSeries)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMSpatialMapSeries.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMSpatialMapSeries with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMSpatialMapSeries and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
