ArcGIS.Core.CIM Namespace / CIMTinContourRenderer Class
Properties Methods Events
    CIMTinContourRenderer Class Members
    The following tables list the members exposed by CIMTinContourRenderer.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the contour description.
    Public Property Gets or sets the contour interval.
    Public Property Gets or sets the contour interval scale breaks. The scale breaks should be ordered from the smallest scale to the largest. The last scale break's upper bound will always be treated as 0, indicating no upper bound.
    Public Property Gets or sets the contour label.
    Public Property Gets or sets the contour symbol.
    Public Property Gets or sets a value indicating whether or not to illuminate. (Inherited from ArcGIS.Core.CIM.CIMTinRenderer)
    Public Property Gets or sets the index contour description.
    Public Property Gets or sets the index contour factor.
    Public Property Gets or sets the index contour label.
    Public Property Gets or sets the index contour symbol.
    Public Property Gets or sets the maximum scale for renderer draw (set as the denominator of the scale's representative fraction). Values less than or equal to 0 indicate there is no maximum scale and the renderer will draw at any scale above the minimum. (Inherited from ArcGIS.Core.CIM.CIMTinRenderer)
    Public Property Gets or sets the minimum scale for renderer draw (set as the denominator of the scale's representative fraction). Values less than or equal to 0 indicate there is no minimum scale and the renderer will draw at any scale below the maximum. (Inherited from ArcGIS.Core.CIM.CIMTinRenderer)
    Public Property Gets or sets the reference contour height.
    Public PropertyGets or sets a value indicating whether scale-dependent intervals are used. If true, ContourIntervalScaleBreaks are used; if false, ContourInterval is used at all scales.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMTinContourRenderer.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMTinContourRenderer with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMTinContourRenderer and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
